| Damon |
 Damon World Chat Champion
 Posted: 18:17 - 09 Jan 2014 Post subject: GSXR Water in Oil! |
Hi Guys,
Haven't posted here for ages but need a bit o' help with a problem with my road bike.
I've got a problem with the bike leaking water into the oil. I first noticed it after removing the thermostat because it was running hot, due to it not opening at all. After this it seemed to fog up the sight glass with a layer of white emulsion.
First thing I did was rebuild the water pump with new seals, took it for a ride and the sight glass was completely clear... Great I thought!
However, an hour later I came back to the bike and there is now a nice thick mayo sitting on top of the oil line. There is also a pretty thick hellmanns on the underside of the oil filler cap.
The coolant level has also dropped so it is definitely getting in some how!
I know everyone is going to scream head gasket but the bike doesn't seem down on power at all. Runs clean as a whistle with no smoke and is as responsive as it always has been.
There no oil in the coolant whatsoever... which is strange?
So... I have 2 other thoughts. A crack in the casings causing water to mix (although you would have thought oil would have entered the water too?)
or core plugs popped? If the GSXR has freeze plugs that is.
I'm going to do a leakdown test shortly to see if it is indeed a headgasket failure but I have a feeling it's something else.
What should be the next port of call after the above?
Thanks for your help in advance... Here's a picture of the beast!
https://s22.postimg.org/d3hjqtg4x/1000726_10153380348515497_1963587715_n.jpg
Damo |
| Robby |
 Robby Dirty Old Man
| Damon |
| misscrabstick |
 misscrabstick Crazy Courier
| Walloper |
 Walloper Super Spammer
| bladerunner |
| davebike |
 davebike World Chat Champion
 Posted: 08:05 - 10 Jan 2014 Post subject: |
As said sniff test but I say head gasket blown water to oil
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| misscrabstick |
| devojunior |
 devojunior Brolly Dolly
| Walloper |
| Damon |
| stevo as b4 |
The last post was made 12 years, 310 days ago. Instead of replying here, would creating a new thread be more useful? |
