Electric start problem? Starter?solenoid?cdi?Any help?
goldmansean
PostPosted: 10:20 - 10 Jan 2014    Post subject: Electric start problem? Starter?solenoid?cdi?Any help? Reply with quote
Hi all. I'm sure similar questions have been posted before but I cant seem to find what I'm looking for.
Maybe someone here can give me a few pointers?
My son has a 2006 reiju rs2 matrix 50 and been having some starting problems.
Basically the push start 'winds' lovely and fast but will not start the engine. The batteries in these bikes seem a bit tame tbh so constant start attempts just drains the battery. However it is still possible to bump start the bike. Any suggestions on what I should be checking? Starter motor? Solenoid? Cdi unit?or any suggestions would be appreciated? Could I be over looking something simple?
Many thanks
goldmansean
PostPosted: 10:49 - 10 Jan 2014    Post subject: Reply with quote
Here goes.
You can push the electric start button continually but does not start the engine- just drains the battery
The starter motor turns and I'm sure I can hear the solenoid 'clicking'
I think what you call a push start I call a bump start.
I was thinking I may have a dodgy earth connection somewhere
The electric start was working ok but not brilliantly up until about a week ago?
Maybe something has come loose whilst riding. Just looking for suggestions.
Thanks
bikenut
PostPosted: 10:56 - 10 Jan 2014    Post subject: bump start Reply with quote
:D so the bike starts and runs readily when it bump or push started.......but will not start with the electric start??
when the electric start is used with a fully charged battery, it starts the engine cos the electric starter works and whizzes the engine over fast???????
or
whizzes the engine over very very very slowly and refuses to start??????
or
just makes a continual clicking noise??????
sounds like a fried starter motor, does/did it get very hot???????
do any connections from the battery to the starter motor get hot ( including the earths ) ????????
nuts about bikes
Islander
PostPosted: 11:45 - 10 Jan 2014    Post subject: Reply with quote
Is the starter motor actually turning the engine over?
Have you tried fully charging the battery before trying to start it with the starter motor?
goldmansean
PostPosted: 13:31 - 10 Jan 2014    Post subject: Reply with quote
The starter motor is turning. Just had another go and after several spins got that long wheezing sound then the click of the solenoid.
Still 'whizzes'very fast but refuses to start the engine.
Runs fine once push/bump started
Battery fully charged and have tested with two batteries
I'm edging my bets toward an intermittent starter.
Just need to check any hot connections. I guess this indicates that the battery is being over worked to turn the starter?
Thanks for your input. Nice to get second opinions
bikenut
PostPosted: 15:05 - 10 Jan 2014    Post subject: Reply with quote
so the starter motor whizzes ( makes the engine crank rotate inside the engine, turns eng over as if a kick starter would but fast, or like the engine turns over fast when bump or push started?????? ) THE ENGINE turns OVER FAST BUT ENGINE REFUSES TO START??
i assume there is petrol in it ( its happened dude )?????
does by chance the stater buttomn have a "kill" function or is it just a starter button.?? pic might help
since it starts easily when push or bump started, and runs ok, then fuel, cdi etc systems are ok............
nuts about bikes
Robby
Dirty Old Man
PostPosted: 15:24 - 10 Jan 2014    Post subject: Reply with quote
I'm not clear on whether or not the starter motor is turning the engine over, or just spinning by itself. It is unusual for a bike starter motor to fail in a way that stops it turning the engine over.
If the starter motor is not engaging with the engine, you have a problem with the connection between the engine and the starter motor, probably a sprag clutch. Worth trying to strip and clean it, or a replacement part is unlikely to be expensive.
If the engine is turning over but not firing and you can start it easily with a bump start, that is unusual. The only likely cause that jumps out would be if it needs to have a brake or clutch lever held on to start the bike, and one of the brake or clutch switches has failed.
Islander
PostPosted: 15:48 - 10 Jan 2014    Post subject: Reply with quote
This is what I was driving at when I asked whether the starter motor was actually turning the engine over. This is the question that needs to be answered clearly. Smile
goldmansean
PostPosted: 11:20 - 11 Jan 2014    Post subject: Reply with quote
Thanks for your replies and the suggestions.
It make a change to ask on a forum and get sensible comments.
I was hoping to have another look this morning but son and bike have gone so i assume it started ok?
I think its a combination of poor connections and impatience??
Like most 16 year old lads it has to be done now and just like his bike- at 60mph! Very Happy
sidewinder
PostPosted: 12:35 - 11 Jan 2014    Post subject: Reply with quote
Might be worth a shot to pull out the starter and give it a good clean .might just be a solenoid sticking Thumbs Up
The last post was made 12 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 71.98 Kb
