| stranger12 |
 stranger12 World Chat Champion
| Islander |
 Islander World Chat Champion
| stranger12 |
 Posted: 12:53 - 10 Jan 2014 Post subject: |
| lihp |
 lihp World Chat Champion
 Posted: 12:57 - 10 Jan 2014 Post subject: |
Chances are if you have damaged the thread, then a tap and die set isn't likely to help, unless you have enough material to drill out to the next bolt size, you are however likely to then need drill bits that you won't get in normal sets for the correct bolt size.
You would likely be better with something like this https://www.ebay.co.uk/itm/TOOLSHACK-M-8-00-x-1-25-Coarse-pitch-V-Coil-thread-repair-kit-/111250055284?pt=LH_DefaultDomain_3&hash=item19e7052074
I use the V-Coil ones primarily because I had to try one when HeliCoil didn't make them in a size I needed (M7) but was very impressed with the quality of them and they worked perfect.
Just search ebay for VCoil bolt size x thread pitch, so say VCoil m8 x 1.00
They come with the correct size drill bit, and the correct size tap, but again you need to have enough material to drill it out. ____________________ covent.gardens: lihp is my most favourite member ever |
| stranger12 |
| lihp |
 Posted: 13:12 - 10 Jan 2014 Post subject: |
the tap and dies are designed to cut new threads into freshly drilled holes, what I posted is a thread repair kit.
If your bolt is m8 x 1.00 you buy the m8 x 1.00 kit, you drill the hole out with the drill bit in the kit, use the tap that comes with the kit and then use the included tool to screw the insert into the new hole.
The inside of that insert is the same thread size as the original, meaning you don't need to use larger bolts. They are also generally stronger than the original thread in aluminium too.
By 1/2 do you mean 1 or 2 threads, or half the threads? If just 1 or 2 threads, I would test the bolt and see if you can get the correct torque, if half the threads have stripped then it's unlikely you will get the correct torque.
As I said, the regular tap and die set you posted will only cut new threads, meaning that without an insert, you can't get that bolt back to the same size as you have no material to cut a thread into, meaning that you are going to have to go the next bolt size up so m10 from m8 or you need to use an insert to repair it to the same size. ____________________ covent.gardens: lihp is my most favourite member ever |
| DrDonnyBrago |
 Posted: 13:17 - 10 Jan 2014 Post subject: |
| stranger12 wrote: | well when getting the bolt out as the bolt was under pressure and I was stupied enough to ignore it , and continue putting pressure on it to undo, the bolt cam out but saw 1/2 threads out of the 20 or so on the bolt so means damaged internal thread.
What is the difference between tap and die and the one you posted ? |
If you have a hole with no threads and want to cut new threads, you use a tap.
If you have a piece of bar with no threads, and want threads, you use a die.
You can also use a tap/die to clean up dirty/damaged threads if they are still present, but you can not use it to add more/repair stripped threads.
If you have a previously threaded hole that you stripped all of the threads out of, you drill the hole bigger, use a tap to cut new threads, then use a helicoil to make the new big threaded hole small enough to fit the original bolt. It's like a spring that sits in the larger hole, so the inside is the size you want.
| stranger12 |
| lihp |
| DrDonnyBrago |
| stranger12 |
| dydey90 |
 dydey90 World Chat Champion
 Posted: 12:20 - 20 Jan 2014 Post subject: |
I think 100nm is around 100kg of force?
This table may help with bolt sizes as per the OP.
https://www.boltdepot.com/fastener-information/bolts/metric-bolt-head-size.aspx
From my experience, you should be looking at the DIN column. Although the ISO one should be the standard, I have never encountered an M12 bolt with less than a 19mm head. ____________________ This post is probably not serious and shouldn't be taken literally.
Past: CBR125,ER6f NINJA 650, ZZR600 Current: VFR750 |
| stranger12 |
| Vincent |
 Vincent Banned
| Northern Monkey |
 Northern Monkey World Chat Champion
 Posted: 16:40 - 20 Jan 2014 Post subject: |
100Nm is a force of 100N applied at a distance of 1m from the fulcrum.
As Torque = Force(f) x Radius(r), then it could be 1000N at 10cm, or 200N at 50cm or 100N at 1m.
100N is roughly the same as 10kg of force |
| Hugh Farking Cant |
 Hugh Farking Cant Scooby Slapper
| stranger12 |
 Posted: 19:09 - 20 Jan 2014 Post subject: |
| Northern Monkey wrote: |
I am totally confused by
so is 1000n at 10cm = 200n at 50 ?
100N x 1 =110nm thus 100N per meter
1000N x 10= 10000 N ( cantimeter ?) which is then divided by 100 thus 100 NM ?
So in a way how you hold the torque wrench also plays a role thus if I do not put pressure on from the handle then I may get a false reading ? ____________________ SV650 Red
R6 Red |
| Bezzer |
 Bezzer World Chat Champion
| Vincent |
 Vincent Banned
The last post was made 12 years, 265 days ago. Instead of replying here, would creating a new thread be more useful? |
