Yamaha YBR Keeps Cutting Out. (2009)
WackeyMills
PostPosted: 14:41 - 11 Jan 2014    Post subject: Yamaha YBR Keeps Cutting Out. (2009) Reply with quote
Hi Guys! New to this forum.
Right here goes.
This morning I decided to change my front light bulb as the default ones are just terrible, dangerous at night in fact. Can't see a bloody thing with them. After I changed the lightbulb, I put it all back together as it should be. So i decided i'd go out for a spin for a little while. I put the key in the ignition and switched it on, but to my disgust, nothing worked! Just nothing. I kickstarted which worked for around 1-10 secs with the enging light blicking aslong as the engine lasts. The speedo and the rev + the fuel guage isn't working. also the lights on the bike are very faint, like it isn't getting enough power.
What can this be guys? could you help! much appreciated.
YBR Ric
PostPosted: 16:31 - 11 Jan 2014    Post subject: Reply with quote
Fuse - blown by a damaged bulb holder connector.
Musketeer
PostPosted: 21:08 - 11 Jan 2014    Post subject: Reply with quote
Wrong powerband. You need to change it before you fry your wiring loom completely.
simonjb
PostPosted: 21:42 - 11 Jan 2014    Post subject: Reply with quote
Sounds like bulb's too powerful! You want a 35/35w bulb in there, literally fitted a 35/35w halogen myself today and it's way better than the stock.
Make sure all the wires in and behind the headlight fitting are all still connected and nothing is shorting out - the fact that your gauges are messed up could indicate some wirings been messed up in the headlight. Then check your fuse in the battery compartment (YBR only has a 15A one) - though if it'd have blown nothing should work. If you're lucky you've not fried anything and it should work once you disconnect the headlight (or just take out the bulb) - that's if it is the bulb that's caused it.
Current Bike: 2008 Yamaha YBR 125
The last post was made 12 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 39.62 Kb
