| Chesh |
 Chesh Derestricted Danger
 Posted: 13:49 - 29 Nov 2013 Post subject: Mega low compression in two cylinders - '97 zx7r |
Hi guys,
A few weeks ago I noticed my bike had no coolant. Which was odd because it had never used any before. I filled it up but over the next couple of days I noticed the bike was getting hotter than usual.
Up until then the bike had never gotten any hotter than to make it rise off the bottom line, unless sat in traffic, but it was now rising up to halfway sometimes. I also noticed it was struggling to start.
Sounds like typical symptoms of a head gasket gone doesn't it
I did a coolant flush and replace and let her run up to temp, took her for a ride and she still pulls and feels relatively normal when on the move, except the temperature still rises up to an unacceptable level.
I have just done a compression test and got the following readings:
Cyl 1: 175psi
Cyl 2: 160psi
Cyl 3: 7psi
Cyl 4: 70psi
The compression should be between 149-228psi.
I've read that low compression over two adjacent cylinders means that it's pretty much definitely a blown head gasket, but are these normal numbers for a blown head gasket??? They seem so low that it makes me think I might have done something wrong??
I wouldn't have thought it would even run with compression that low! It doesn't sound like it's running on 2 cylinders.
Any opinions would be greatly appreciated
Thanks! |
| davebike |
 davebike World Chat Champion
 Posted: 14:12 - 29 Nov 2013 Post subject: |
Yes probably head gasket
There is a chemical test called a 'sniff test' where air from the top of the radiator is drawn though a test solution that will confirm if oil /exhaust gases are getting into the water
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| hmmmnz |
 hmmmnz Super Spammer
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| 69chris |
 69chris Trackday Trickster
 Posted: 16:12 - 29 Nov 2013 Post subject: |
7 psi ???? im stunned it would run with a figure that low
does that s/plug looked 'steam cleaned' ?
where are you ? if your nr swindon i have a block tester so checking would take minutes  |
| Chesh |
| Wafer_Thin_Ham |
| 69chris |
 Posted: 14:55 - 30 Nov 2013 Post subject: |
| Chesh |
| Robby |
 Robby Dirty Old Man
| Chesh |
| Robby |
 Robby Dirty Old Man
| lihp |
 lihp World Chat Champion
| stevo as b4 |
The last post was made 12 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
