| merky69 |
 merky69 Borekit Bruiser
| Kickstart |
 Kickstart The Oracle
| merky69 |
| merky69 |
| andy_uk |
 andy_uk World Chat Champion
| bladerunner |
 bladerunner World Chat Champion
 Posted: 03:25 - 12 Jan 2014 Post subject: |
Something is stopping it going together so fair does for not just bolting it up and hoping that worked! Sometimes it can be gears not meshing....so try turning gear shafts,crank,water pump.....balancer shafts etc to see if that helps it drop in......failing that take it apart and strip the cases....if they go together....fit the crank and try again....then the gearbox etc etc....at least that way you find out what the problem is. Slow but you'll know for next time! Try the fit each time! Also worth checking your crank is central on the mains as if the bearings don't slide fully home your in for short engine life. Also worth setting the piston to TDC and your balancer shaft with the weight at BDC as the marks on the 122 motor are known to be miles out giving you dumper truck levels of vibration if you take them as correct!  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| merky69 |
| merky69 |
| Pete. |
 Pete. Super Spammer
 Posted: 12:31 - 12 Jan 2014 Post subject: |
Inspect the shaft for burrs and make sure there's no old bearing fit on the surface where it's been assembled before. If you can get the bearing out of the case you can try pressing it onto the shaft by pressing on the inner race, then assembling the lot into the cases afterwards. ____________________ a.k.a 'Geri'
| merky69 |
| Pete. |
 Pete. Super Spammer
 Posted: 18:07 - 12 Jan 2014 Post subject: |
Are you sure you have assembled the clusters properly? ____________________ a.k.a 'Geri'
| andy_uk |
| andys675 |
 andys675 World Chat Champion
| merky69 |
The last post was made 12 years, 267 days ago. Instead of replying here, would creating a new thread be more useful? |
