CBF 125 oil filter cleaning
Screw Loose
PostPosted: 21:56 - 11 Jan 2014    Post subject: CBF 125 oil filter cleaning Reply with quote
So after putting it off for almost a year I've bit the bullet and decided I need to clean the oil filter, so I've ordered all the bits and bobs and am going to sort it on thursday. Now, having looked through the Haynes manual, they reckon the clutch cover should be tightened to 10NM,
Surely this can't be correct, given that the spark plug is supposed to be 25NM?
Also, seeing as though I've got the clutch cover off anyway, is it worthwhile cleaning the centrifugal filter also? I'm just a bit cautious about working on my bike as I don't trust myself and lack confidence, however if I don't start soon I never will haha.
Cheers in advanced Thumbs Up
MBK Nitro 50cc -> CBF 125 <\s>
CBT: February 2012 - Full licence August 2013
Screw Loose
PostPosted: 22:04 - 11 Jan 2014    Post subject: Reply with quote
P.S. where the hell can i get hold of paraffin?
Apparently you have to be over 21 to buy it from B&Q ...
lukamon
PostPosted: 23:19 - 11 Jan 2014    Post subject: Reply with quote
errrrr, the centrifugal filter is the only filter on the cbf (unless you count the tea strainer)
its the reason I change the oil every 1k. it's only a litre and if you buy Halfords oil on offer that's £2.50 every 1000 miles Thumbs Up at 5k I took the cover off and washed the strainer under the oil pump pickup, which was fair full of crap (mostly clutch fibres). I will not do the centrifugal filter ever because I cleaned the one in my cub 90 at 25k, and it had only the merest little bit of sludge in it. keeping the oil clean / fresh makes much more difference.
edit: I never have used a torque wrench, especially on spark plugs. if its a new plug with a crush washer, its hand tight + a quarter turn. used plugs / crush washers are 1/8th turn, and tapered washer-less plugs are also 1/8th turn.
killa wrote: Im an ass man myself
mentalboy
PostPosted: 23:22 - 11 Jan 2014    Post subject: Reply with quote
Torques given sound ok to me. Spark plug has all the joys of compression happening which a cover doesn't. Overtighten your cover screws and you'll end up cussing and playing with a helicoil set (or worse)
Make mine a Corona.
Screw Loose
PostPosted: 23:35 - 11 Jan 2014    Post subject: Reply with quote
Bad news is my torque wrench starts at 16NM ...
So roughly how tight would 10nm be?
If 20 odd is a quarter turn then surely 10 nm is roughly hand tight?
Aff
PostPosted: 23:37 - 11 Jan 2014    Post subject: Reply with quote
Just hold the ratchet as close to the bolt as possible and nip it up, you really should be able to feel if your are about to strip it.
Electric Bike Project
Screw Loose
PostPosted: 23:39 - 11 Jan 2014    Post subject: Reply with quote
So just nipping it up?
For some reason I was expecting them to be really tight Embarassed
Thanks for letting me know before i start anything though Thumbs Up Karma
Nobby the Bastard
Harley Gaydar
PostPosted: 23:54 - 11 Jan 2014    Post subject: Reply with quote
Paraffin is diesel without the added tax....
Triumph Sprint ST 1050
Screw Loose
PostPosted: 00:05 - 12 Jan 2014    Post subject: Reply with quote
Does that mean I can use diesel to clean my chain, and oil filter??
stuarthouston
PostPosted: 00:16 - 12 Jan 2014    Post subject: Reply with quote
A nip should do it. The torques are similarly low on my CG as well. I figure if you do it up and there's a bit of oil seepage, it's easier to tighten them up a touch more than deal with a sheared bolt.
If you don't know the history of the bike, there's no harm in cleaning the centrifugal filter. If nothing else, it'll give you an insight as to how often the oil has been changed on it.
'96 Honda CG125 BR-T
neil.
PostPosted: 08:12 - 12 Jan 2014    Post subject: Reply with quote
The spark plug is torqued to 16Nm on the CBF. With the cover screws at 10Nm they won't rattle loose. The strainer gets blocked with fluffy crap which I assume comes from the clutch, so you should clean it as a matter of priority. Subsequently it will be much better the next time you do it.
As for the centrifugal filter, the ones I've seen only catch a thumbnail's amount of gunk, not much at all. I broke an impact driver trying to get the bastard thing apart and never cleaned it since, 31'000 miles since. I don't think it's nearly as important as the first clean out of the strainer.
Have a look at my guide for the strainer if you like: https://cbf125rider.wordpress.com/2011/12/11/how-to-clean-the-engine-oil-filter-strainer/
yen_powell
PostPosted: 10:12 - 12 Jan 2014    Post subject: Reply with quote
Stand outside B&Q and keep asking grown ups to buy some for you if you give them the money. Seems to work for drink at my local supermarket. Very Happy
XT1200Z and a DR350 in bits
The last post was made 12 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 75.75 Kb
