| Doomsnite |
 Doomsnite Traffic Copper
| simonjb |
 simonjb Nova Slayer
 Posted: 20:15 - 11 Jan 2014 Post subject: |
Firstly when you mention the sidestand cut out switch - the sidestand switch is only supposed to cut the engine if the bike is in gear, can you confirm this is what you meant?
When trying to start it, do you get anything on the engine management light, such as a constant flashing, or a series of slow and fast flashes?
If you're able to bump start it, it could just be a flat battery, but you should be able to kick start it on a flat battery if you give enough of a kick.
Lastly you say it's on an 09 plate, but it has the chrome style exhaust from the 2005/2006 carb versions as I've never seen that exhaust on a post-2007 YBR. Just to check its the fuel injection model (easier to troubleshoot than the carbs) check if there's a fuel tap or choke down by the tank somewhere - if there isn't you've got the right year  ____________________ Current Bike: 2008 Yamaha YBR 125 |
| Doomsnite |
 Posted: 20:37 - 11 Jan 2014 Post subject: |
It was in gear but I had the clutch in.
The engine light was doing something but can't remember what - does that show you what kind of fault? I seem to remember it getting slower in flashing as it was dying off. Turning over got more strained. Will have to try it again in the morning and see.
When I was stuck at the garage, I forgot it had a kick start… Wasn't until I got home that the wife reminded me Will have to give it a proper kick in the morning and see.
Could it really be flat battery if I had just been riding it for half an hour and it started before that - it should have charged it? If it is, whats the cure? Replacement?
Pretty sure it hasn't got a choke - what am I looking for and which side? /novice ____________________ Triumph Street Triple-R
Sold: Honda Hornet CB600F-Y / Yamaha YBR125 |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 21:10 - 11 Jan 2014 Post subject: |
| simonjb |
 simonjb Nova Slayer
 Posted: 21:31 - 11 Jan 2014 Post subject: |
Fuel tap would be on one of the side pods or underneath, if you can't see it then you haven't got one, as it's pretty obvious!
Firstly make sure the oil is at a healthy level - drain some if necessary. If you can kick and bump start it fine and it runs ok then it could well be the battery being flat - whether it's a knackered battery or something more sinister such as a faulty regulator or rectifier (parts of the charging circuit) I don't know.
If you have a battery charger or maintenance charger (such as oxford oximiser or optimate) then let it charge the battery to full, then try again.
Try to find out what the orange engine management light is doing. If it's flashing fast constantly, it could be the sidestand switch, clutch switch, or neutral switch, all part of the safety circuit. Try starting the bike off the kickstand (while you're on it), make sure the neutral light is on (make sure it is in neutral), and try pulling the clutch in at the same time as starting.
If the management light gives a fast flash at first, then a series of pulsed flashes, then it's giving you an error code. For example after the initial quick few flashes.. ONE slow flash then NINE faster flashes means error code 19. If it is giving you an error code post it here or video it and I'll look it up in the Hayne's manual (or if you've got one, fault codes are on page 3B-6). ____________________ Current Bike: 2008 Yamaha YBR 125 |
| Doomsnite |
| simonjb |
 simonjb Nova Slayer
 Posted: 21:46 - 11 Jan 2014 Post subject: |
The light will continue to flash. Try to start it, if you see anything on the engine management light, let go of the starter and pay close attention to the light. Good luck! ____________________ Current Bike: 2008 Yamaha YBR 125 |
| Doomsnite |
| Doomsnite |
| simonjb |
 simonjb Nova Slayer
 Posted: 12:07 - 12 Jan 2014 Post subject: |
Definitely worth checking the voltage, though its very unlikely it will have dropped below an unrecoverable level. So get it on charge when you can, if the battery voltage is low. If you charge the battery, and it works fine then that's a start, but if the problem comes back it means either your battery is knackered, or your charging circuit is faulty. As aforementioned, this is commonly regulator or rectifier, though not seen this issue on a YBR for a while. Hopefully it might just be cold starts etc. But make sure that you've got nothing on the bike like heated grips or an alarm etc. that could be drawing current from the battery. I've got a set of heated grips on mine but I always remember to switch em off  ____________________ Current Bike: 2008 Yamaha YBR 125 |
| Doomsnite |
| Doomsnite |
 Posted: 12:46 - 12 Jan 2014 Post subject: |
Just tested it… 11.8 with ignition off, 11.1 with ignition on, so battery is discharged. Just have to get a charger now and see if it holds it and whether there may be another problem. Still wouldn't mind knowing how long a decent battery should hold a charge for - what does yours do?
Thanks for all your help thus far, much appreciated  ____________________ Triumph Street Triple-R
| simonjb |
 simonjb Nova Slayer
 Posted: 13:18 - 12 Jan 2014 Post subject: |
You shouldn't lose charge in a week with a healthy battery and charging circuit. I tend to use a charger because of the many cold starts, short journeys and the fact that I constantly use a set of heated grips when I'm riding. But on it's own the battery shouldn't lose charge unless you're doing many short journeys.
Once the battery is charged - check the charging circuit by getting your multimeter, set it on the 20v setting and put it across the battery when the bike is off, should read between 12.4 and 12.8 for a battery charged over 75%. Then start the bike and see what the charging voltage is, it should be considerably higher than the battery voltage, should be well above 13.0 but no higher than 14.4. ____________________ Current Bike: 2008 Yamaha YBR 125 |
| Doomsnite |
 Posted: 15:47 - 12 Jan 2014 Post subject: |
To check the charging voltage is it to read the voltage as its starting or whilst its running?
Gonna order it today so might be a few days. Got something else to fix today - the noggin on the body panel fascia covering the battery has snapped off Will try and superglue it but don't hold out much hope! ____________________ Triumph Street Triple-R
| simonjb |
 simonjb Nova Slayer
 Posted: 16:02 - 12 Jan 2014 Post subject: |
Whilst it's running mate - check the voltage whilst it's idling and rev it a bit - see how the charging voltage changes. If it runs perfectly once started it's unlikely to be a problem with the alternator, but we don't know that there IS a problem so just have to wait.
You can order the side panels on ebay if you want to replace it - the lock that you put your key in screws off from the inside. I put WD-40 on the pins because those panels are a nightmare to get off! ____________________ Current Bike: 2008 Yamaha YBR 125 |
| YBR Ric |
 YBR Ric Spanner Monkey
| _Iain_ |
 _Iain_ Banned
 Posted: 12:01 - 13 Jan 2014 Post subject: |
Sounds like battery is toast.
You need a YTX7L-BS for a YBR125ED which is what I suspect you have, however pull the battery out & check the code on the side.
We'd charge £30 for a Dynavolt/Rob Hunter battery, or £40 for the genuine Yuasa battery. ____________________ Please be aware that the above post may be full of complete nonsense.
| Doomsnite |
| Doomsnite |
| simonjb |
 simonjb Nova Slayer
 Posted: 12:47 - 13 Jan 2014 Post subject: |
You can get a decent maintenance free battery on ebay. Just make sure its not your charging circuit! ____________________ Current Bike: 2008 Yamaha YBR 125 |
| Doomsnite |
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
| Doomsnite |
 Posted: 14:41 - 13 Jan 2014 Post subject: |
Yeah I ordered that one off ebay last night... £24.99. A lot better than the £50 Halfords are quoting in stock - I nearly bought it at the weekend but realised I was in now rush as I had the kick start  ____________________ Triumph Street Triple-R
| Doomsnite |
| simonjb |
 simonjb Nova Slayer
 Posted: 17:34 - 13 Jan 2014 Post subject: |
They'll both do the same job fine - the optimate 3+ doesn't have a screen I don't think - so you'll just have to use a multimeter to check the voltage. When I connect my oxford I usually park it in the alley under it's cover and trail the cable through the letterbox so I can see the voltage without getting the cover off or even going outside not a major loss though. ____________________ Current Bike: 2008 Yamaha YBR 125 |
The last post was made 12 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
