bike keeps diein on me help
killergibbo
PostPosted: 03:58 - 21 Dec 2004    Post subject: bike keeps diein on me help Reply with quote
i have a tzr50 and i warm it up before i ride but everythime i ride its dies on me i can hear the ratator makin a noise wen am riding.
the temputure and oil lite come on wen am ridin and wen i try and go full rev it dies and sum times wen am ridin i have the trottle half way to keep it goin and it jumpin pullin......
whats wrong with my bike i have changed the anti-freeze today and stilln have the problem with it what can i do
jamie192
PostPosted: 12:32 - 21 Dec 2004    Post subject: Reply with quote
have you changed any settings put on any new parts or has it just started doing this??
If its just started doing this your carb might be needing cleaning out and its restricting the amount of fuel going in. Check your sparkplug, you may need a new one or it might just need cleaning. If its not giving enough of a spark it wont run properly.
Does it idle properly or rev high?
Ride Fast, Brake hard, don't fall off!
killergibbo
PostPosted: 04:48 - 22 Dec 2004    Post subject: Reply with quote
i think my bikes fucked!!! cos i was ridin home and i come off a roundabout and then the bike just died down alittle and was still runining but wud not move and as i reved the bike the rev hand was jumpin everywhere very fast but the bike was not makin noise from me revin.
it was makin the same noise if i reved it full and if i dint rev it the bike just sounds like its doin bubbles but it will not move for any1
what happen is my piston gone or got a hole in it what happen????
simon1221
PostPosted: 20:11 - 23 Dec 2004    Post subject: Reply with quote
check that you havent:
Arrow ran out of fuel
Arrow changed the mixture settings
Arrow put super unleaded or something else in to bugger up the settings
swampy
PostPosted: 12:26 - 24 Dec 2004    Post subject: Reply with quote
What kind of noise was the radiator making ? Hissing ? You say the oil light was coming on, have you checked the 2 stroke level recently ? Have you checked that the throttle cable has not snapped ? This might explain 'revving' the bike with nothing happening (doesnt explain the rev counter jumping about though). I doubt you have holed the piston, as I know to my cost that this generally stops the bike running, often just after a loud bang Very Happy
And dude, your post's would be easier to read if you tried spelling and punctuating properly Thumbs Up
Robby
Dirty Old Man
PostPosted: 12:29 - 24 Dec 2004    Post subject: Reply with quote
Temp and oil light is suggesting you've fucked it.
Is there any 2 stroke oil in the bottle?
Frost
PostPosted: 12:39 - 24 Dec 2004    Post subject: Reply with quote
Does it run for a bit, then bog down when the thing warms up?
If so then thats the piston seizing as it has no oil in it.
simon1221
PostPosted: 19:18 - 24 Dec 2004    Post subject: Reply with quote
maybe your just being picky, and the noise is that the radiator actually works
sounds like you have run out of oil, or possibly the oil cable or throttle cable has snapped or is about to
dont ride it until you have fixed it, as the throttle could suddenly rise and you would get thrown off
killergibbo
PostPosted: 03:26 - 28 Dec 2004    Post subject: Reply with quote
right
i start the bike bike up, i rev it and as i rev the bike the revs jump like a bitch wen am revin it like to 2,000 and its oin to 10,000 but not makin any noise from that. its the same noise as if u was just not revin it
and wen i try and ride it in gear it jumps along tuggin but no power its movin but very very slow
and yes i have oil in the bottle but where is the screw for the oil to put more into the engine......
simon1221
PostPosted: 00:12 - 02 Jan 2005    Post subject: Reply with quote
it maybe something to do with the gears then if it only happens while in gear
check gearbox oil
satans_BIG_helper
PostPosted: 00:57 - 02 Jan 2005    Post subject: Reply with quote
could be a few things..... from past experience this is what it might be i could be wrong so dont go n carry out repairs for this lot LOL
1) fekked battery... i had a TZR 250 that ran very similar to that it turned out the battery was knackered n everything went eratic.
2) Shit in carb..
3) knackered plug ?? could be your plug or maybe the HT lead shorting out against the frame/cylinder if its split
4) Or worst comes to the worse u could have partially seized your engine ??? which could cause the problems your experiencing...
Did you recently purchase your bike ?? and if so was it from a dealer ??
TZR 50's are a pretty new bike from my memory so it shud be under some kind of warranty if it is ???
Aikman666
PostPosted: 18:18 - 06 Jan 2005    Post subject: Reply with quote
Sounds like your piston hasnt been properly lubricated by your oil. It only cuts out completely when its been ran for a while, correct?
This would mean that the piston has heated and expanded. Also i'd remove the cylinder head and just take a look, if you cant remove it youre piston has probably seized due to overheating, and if you can you should be able to see any physical damage. Id check your using the right fuel:oil mixture and not using a cheap 2-stroke oil.......Im assuming it is a 2-stroke.....
Will work for petrol
My Design Blog
The last post was made 21 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 71.84 Kb
