Adjusting the chain
gmc38609
PostPosted: 21:57 - 13 Jan 2014    Post subject: Adjusting the chain Reply with quote
I could hear a clunking noise from my chain when I went for a ride.
I went to adjust it but found it to be very slack at one point but also tight at others.
Can I assume that being such extremes the chain is knackered and needs replacing, as I adjusted the slack but the chain is now so tight it resctricts the wheel movement, but If I loosen it the slack will hit the bike
Or is something else wrong do you think?
mentalboy
PostPosted: 22:12 - 13 Jan 2014    Post subject: Reply with quote
Ideal world = replace chain
You can get a bit more life out of it by working the stiff links until they move nicely, pliers are good for this but at times I have resorted to encouraging movement with a hammer. This is easiest done off the bike so you can soak it well in oil before starting to free up each link. You won't get a lot of extra life if you've got a machine that eats chains for a pastime (like my Zed Sad )
Make mine a Corona.
gmc38609
PostPosted: 08:23 - 14 Jan 2014    Post subject: Reply with quote
Thanks I thought it must be knackered so ordered a new one.
My bike has done 19k so dont know if thats the first replacement or not I never thought to ask when I bought it
bodger
PostPosted: 09:41 - 14 Jan 2014    Post subject: Reply with quote
Hope you ordered a pair of sprockets to go with the chain you ordered, or you may find the new chain not lasting too long. The teeth on the sprockets are probably knackered as well if the description of the chain was anything to go by
gmc38609
PostPosted: 09:47 - 14 Jan 2014    Post subject: Reply with quote
Yes, I got sprockets and chain.I changed the gearing and added 2 teeh to the back to give it a bit more zip in the take off Very Happy
Aff
PostPosted: 09:53 - 14 Jan 2014    Post subject: Reply with quote
I think that Hornet doesn't have a wheel driven speedo?
If it doesn't your +2 on the back will make your speedo over read by about 5%.
Electric Bike Project
gmc38609
PostPosted: 10:24 - 14 Jan 2014    Post subject: Reply with quote
Oh will it, I never knew that So if it says 50mph i will only be going 45mph etc.
I just hope its worth it because without fuel injection it does seems a bit gutless until you reach 5k + over that and its white knuckle time lol. Ideal for beginners that though
The last post was made 12 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 50.43 Kb
