Beginner tool kit
Doomsnite
PostPosted: 23:36 - 13 Jan 2014    Post subject: Beginner tool kit Reply with quote
I want to be able to do some basic stuff like oil change, air filter change, gear lever adjustment, chain adjustment, etc so need the necessary tools. I didnt get one with thr bike, is there any budget recommended set?
I see Halfords have one for a tenner but is it a pile of wank?
Triumph Street Triple-R
Sold: Honda Hornet CB600F-Y / Yamaha YBR125
wr6133
PostPosted: 00:07 - 14 Jan 2014    Post subject: Reply with quote
If you keep an eye on Halfords webshite they often put their professional range of toolkits on sale sometimes 66% discounts.
I doubt you'll get much of a toolkit for a tenner
Raffles
PostPosted: 00:13 - 14 Jan 2014    Post subject: Re: Beginner tool kit Reply with quote
Doomsnite wrote:
I want to be able to do some basic stuff....so need the necessary tools....is there any budget recommended set?
Do yourself a favour....Don't buy budget shit.
For not a lot more money than budget shit, you can purchase a superb range of quality tools from the Draper Expert range. They are more than adequate for amateur/semi-pro use.
PostPosted: 00:37 - 14 Jan 2014    Post subject: Re: Beginner tool kit Reply with quote
If it was me, I would go for these two:
https://www.amazon.co.uk/socket-tool-professional-quality-NEILSEN/dp/B004UKPEIE/ref=sr_1_4?ie=UTF8&qid=1389655589&sr=8-4&keywords=94+piece+socket+set
https://www.amazon.co.uk/Silverline-SP100-Metric-Professional-Spanner/dp/B000LFTQMC/ref=sr_1_1?ie=UTF8&qid=1389655574&sr=8-1&keywords=silverline+6+32
A much better range of tools than a Halfords set for similar money I'd say - 6-32mm in both sockets and spanners.
The other Paul Rudd
PostPosted: 00:38 - 14 Jan 2014    Post subject: Reply with quote
Hammer, screwdriver, and pliers. The screwdriver should be a 6 inch long flat blade with a tip that's too wide to be useful and the shaft bent half way at 15 degrees.
This site can be pretty good. Most of it is over priced but they do have the odd very cheap socket set on clearance, so I advise you price check against other sites first and ignore Ebay prices. There was a heavily discounted Beta set on there that is larger than the usual Halfords set for roughly the same price.
https://www.primetools.co.uk/
J.M.
PostPosted: 00:49 - 14 Jan 2014    Post subject: Reply with quote
You will need surprisingly few tools to do those jobs. Ratchet, couple of sockets, couple of spanners, screw driver.
If your budget is very small, consider only buying the few tools that you need (but at an okay/good quality). Otherwise, save up for a good kit (around £80) that will cover you for most jobs.
2004 R1 & 2018 XSR900
PostPosted: 01:06 - 14 Jan 2014    Post subject: Reply with quote
You could try on your local freecycle too, might even get lucky and get some good stuff!
Doomsnite
PostPosted: 10:33 - 14 Jan 2014    Post subject: Reply with quote
I think i need a torque wrench for the oil change so will have to look at getting one of them too. Want to adjust gear lever first so just need to find out what I need for that.
Lupo
PostPosted: 10:54 - 14 Jan 2014    Post subject: Reply with quote
Worth keeping and eye on Aldi: https://www.aldi.co.uk/en/specialbuys/sunday-12th-january/ and Lidl: https://www.lidl.co.uk/cps/rde/SID-9D3FF6F3-0B0BA980/www_lidl_uk/hs.xsl/index.htm
Quite often they do have some sets or tools at good prices, for the occasional use they are ok. Same for Halfords and Homebase.
A por ellos, que son pocos y cobardes.
J.M.
PostPosted: 11:16 - 14 Jan 2014    Post subject: Reply with quote
You don't need one, you can do it without.
In fact, the last time I did an oil change I ignored my torque wrench. It felt too tight.
Doomsnite
PostPosted: 11:23 - 14 Jan 2014    Post subject: Reply with quote
Wouldnt want to do it too loose though, how can you be sure?
Northern Monkey
PostPosted: 11:45 - 14 Jan 2014    Post subject: Reply with quote
As tight as you can get it using one finger on the end of the spanner.
workboots
PostPosted: 00:12 - 15 Jan 2014    Post subject: Reply with quote
Avoid silverline spanners like the plague.
PostPosted: 00:44 - 15 Jan 2014    Post subject: Reply with quote
Why?
I've been very impressed by my set and others on here have too.
I believe Halfords is now selling basically the same set, but with their logos on, of course.
workboots
PostPosted: 00:05 - 17 Jan 2014    Post subject: Reply with quote
G wrote:
Why?
I brought a silverline for a cheap replacement.
the spanner was very thin and slips on nuts and bolts - but to be fair, it was only a pound lol.
i guess the spanners you linked to are alot better now then.
PostPosted: 00:12 - 17 Jan 2014    Post subject: Reply with quote
I suspect you can get other silverline spanner designs that aren't as good.
This are appropriately sized and I've not had any problems with them slipping.
stuarthouston
PostPosted: 00:51 - 17 Jan 2014    Post subject: Reply with quote
Agree. And the ones with the larger ranges are often woefully inaccurate at either end of the range.
'96 Honda CG125 BR-T
Doomsnite
PostPosted: 09:13 - 17 Jan 2014    Post subject: Reply with quote
Well just went for a 12 piece spanner set from halfords to start and did the gear lever adjustment... Great success. Will just have to see how they hold up with bigger jobs
sickpup
Old Timer
PostPosted: 10:44 - 17 Jan 2014    Post subject: Reply with quote
Now why do you say this?
The last post was made 12 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 99.43 Kb
