Tip for cold starting a grabby hydraulic clutch
Bike Chat Forums Index -> Biking News & Rumours
buddy1065
PostPosted: 14:09 - 14 Jan 2014    Post subject: Tip for cold starting a grabby hydraulic clutch Reply with quote
I have a 1995 Triumph Trident. It starts fine when warm but after a few days after shifting from neutral to first gear the clutch grabs, the bike lurches and the bike stalls. I am hoping to take it in for repair but in the meanwhile I found that if I shift into 2nd instead of first during a cold start the bike will start fine without stalling out. Guess it's the clutch plates needing replacement but I just thought I would mention it as a temporary fix. It will probably work on other brand bikes with the same problem.
PostPosted: 14:14 - 14 Jan 2014    Post subject: Reply with quote
I'd bleed/adjust the clutch before replacing the plates.
Andy_Pagin
PostPosted: 14:23 - 14 Jan 2014    Post subject: Reply with quote
chris-red wrote:
I'd bleed/adjust the clutch ...
Hydraulic flexible pipes can collapse internally, so may be worth replacing if you're bleeding the clutch anyway.
The last post was made 12 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 3.82 - MySQL Queries: 13 - Page Size: 35.5 Kb
