Damn you ice. Broke bike, how fix?
James83
PostPosted: 15:24 - 14 Jan 2014    Post subject: Damn you ice. Broke bike, how fix? Reply with quote
Found some ice, ice won. Usual damage, indicators gone, mirror gone, bodywork scuffed. Wouldn't have been to bad except for this:
https://i1104.photobucket.com/albums/h327/Linkorz/Bike%20pics/20140114_1334171_zps40d6a041.jpg
Pic showing its location
https://i1104.photobucket.com/albums/h327/Linkorz/Bike%20pics/20140114_1334471_zps0d4e2178.jpg
According to this its a generator cover. However, all the oil in the bike pissed out of this hole before I was even on my feet. I thought generators would be separate to the oil system.
Full disclosure, I haven't been able to do anything with the bike beyond push it home yet, so its possible that the oil came from somewhere else, but I can't see any other (significant) damage.
Bike is a Kawasaki zx6r f3 (97)
So, my questions then:
What are dis?
If it is the generator cover, why did all the oil come out of it?
Can I replace it with a used one?
If so, does it require stripping the engine down?
Is it likely to have done despicable things to my engines insides? i.e. even if I can, should I replace it, or should I go straight to the new engine option?
ukguy This post is not being displayed because the poster is banned. Unhide this post / all posts.
James83
PostPosted: 15:37 - 14 Jan 2014    Post subject: Reply with quote
So I should expect to find something else broke when I get the fairing off? Titties Sad
Fisty
PostPosted: 15:40 - 14 Jan 2014    Post subject: Reply with quote
Yes it's the generator cover and yes there is oil behind it. Buy a second hand cover off eBay. Fit new cover with a new gasket, change the oil and ride it.
Fatter and faster than Fret
dydey90
PostPosted: 15:42 - 14 Jan 2014    Post subject: Reply with quote
If the above post is correct and there shouldn't be oil in there, you may have ruptured/dislodged a hose somewhere.
Potentially, you should be able to replace the scrapy bits and carry one.
Fisty
PostPosted: 15:44 - 14 Jan 2014    Post subject: Reply with quote
https://bit.ly/1d3lr61
Engine case on eBay.
James83
I did wonder why it had a gasket if there was no oil in there.
Is it a reasonably simple bolt off, bolt on thing, or do I need to do some kind of disassembly job on the engine?
ukguy - Yes, there's zip in the window. Didn't try starting it because of the lack of oil.
Hugh Farking Cant
PostPosted: 15:45 - 14 Jan 2014    Post subject: Reply with quote
"So, my questions then:
Q. What are dis?
Q. If it is the generator cover, why did all the oil come out of it?
Q. Can I replace it with a used one?
Q. If so, does it require stripping the engine down?
Q. Is it likely to have done despicable things to my engines insides? i.e. even if I can, should I replace it, or should I go straight to the new engine option?"
A. I have no clue whatsoever as to what " dis" appertains .
A. Yes; it is indeed the generator cover. The oil came out because the crash smashed a hole in it.
A. You could indeed replace it with a pre-used item.
A. It would require the damaged casing to be replaced along with the gasket.The stator will need to be transferred from inside the damaged casing to the replacement cover.
A. It would only have damaged the engine if allowed to run without sufficient oil for an extended period.A new engine will hardly be required.
DrSnoosnoo
PostPosted: 15:46 - 14 Jan 2014    Post subject: Reply with quote
There should be oil in there. FACT.
Buy a new Generator cover and gasket, take old one off, scrape old gasket off and rebuild, fill up with new oil and win
Perhaps think of investing in some crash bobbins
James83
PostPosted: 15:48 - 14 Jan 2014    Post subject: Reply with quote
Thanks for the help guys. Feeling much better about the prospects of a repair now.
And yes, crash bobbins are now on my "Why didn't you have these already you dolt" list
Chalky.
PostPosted: 15:49 - 14 Jan 2014    Post subject: Reply with quote
Why do people answer questions in the workshop when they don't have a clue?
James83
PostPosted: 15:52 - 14 Jan 2014    Post subject: Reply with quote
For some reason I thought adding a modern youth pronunciation would be humorous. I'll blame the adrenaline in this instance.
Hugh Farking Cant
PostPosted: 15:57 - 14 Jan 2014    Post subject: Reply with quote
To whom do you refer ?
Hugh Farking Cant
PostPosted: 16:00 - 14 Jan 2014    Post subject: Reply with quote
I am still unable to decipher this question; please elaborate.
Chalky.
The twat that replied first.
Hugh Farking Cant
PostPosted: 16:03 - 14 Jan 2014    Post subject: Reply with quote
Mushrooms or bobbins will not prevent this type of damage.
You require a more substaintial casing;
https://www.bikehps.com/acatalog/Kawasaki_ZX6R_2005-2006_Engines_Case_Covers.html
but even those are not infallible.
Hugh Farking Cant
PostPosted: 16:08 - 14 Jan 2014    Post subject: Reply with quote
To whom do you refer ?[/quote]
The twat that replied first.[/quote]
Thank you for your most elequent reply Chalky.
Chalky.
PostPosted: 16:16 - 14 Jan 2014    Post subject: Reply with quote
I do try.
James83
PostPosted: 16:49 - 14 Jan 2014    Post subject: Reply with quote
True, still daft not to have had them though.
To answer previous - 'what are dis' is twat speak for 'What is this?'
kerr
PostPosted: 18:01 - 14 Jan 2014    Post subject: Reply with quote
The twat would appear to be this guy
ukguy wrote:
you are correct that is the cover and oil will not be in there as its a stator
have you checked oil level and have you checked under enough and started the bike to see if you get a oil warning light
Start the bike to see if the oil light comes on? are you having a laugh??
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
misscrabstick
PostPosted: 18:06 - 14 Jan 2014    Post subject: Reply with quote
Oil in this casing is usual, many stators run in oil, Pm'd you James as I have spare engine parts for the F model.
James83
PostPosted: 18:22 - 14 Jan 2014    Post subject: Reply with quote
Received, replied and slightly speechless at the generosity of strangers. Thank you!
PostPosted: 18:34 - 14 Jan 2014    Post subject: Reply with quote
Did she offer to play with your dip stick Shocked
Tighten things up for you Shocked
Dat generosity Cool
Hopefully you are back on the road asap Thumbs Up Thumbs Up
The last post was made 12 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 123.94 Kb
