derbi senda unusual noise
charrington96
PostPosted: 21:58 - 13 Jan 2014    Post subject: derbi senda unusual noise Reply with quote
I have a derbi senda 50cc 2 stroke engine, I realised that there was a noise coming from near the front (engine/exhaust area), it was a deep popping sound, its been derestricted,
I have done a compression test and its good results
Its only when I slow down (engine braking), with no throttle, breaking or pulling in the clutch, it doesn't make the noise at standstill or accelerating
Any ideas?
mentalboy
PostPosted: 22:04 - 13 Jan 2014    Post subject: Reply with quote
Yo blud, ur bike is pwoper twicked up like
Make mine a Corona.
charrington96
PostPosted: 22:14 - 13 Jan 2014    Post subject: Reply with quote
What do you mean?
SQL
PostPosted: 22:15 - 13 Jan 2014    Post subject: Reply with quote
Popping on decel may indicate its running lean, do a plug chop and check what color the plug is at WOT
charrington96
PostPosted: 22:18 - 13 Jan 2014    Post subject: Reply with quote
Thanks Smile what if it is running too lean?
mentalboy
Sigh.
Running slightly lean, usually found on highly tuned engines, not ordinarily a problem. Has this just developed or have you derestricted/purchased this recently? (ie have you been tinkering?)
Make mine a Corona.
SQL
PostPosted: 22:20 - 13 Jan 2014    Post subject: Reply with quote
If it is running too lean then it could melt the piston.
charrington96
PostPosted: 22:24 - 13 Jan 2014    Post subject: Reply with quote
The bike is stock... Tops of 55mph even though Ive never tried
I need have a lost circlip to the jet needle once and replaced it.
charrington96
PostPosted: 22:30 - 13 Jan 2014    Post subject: Reply with quote
I have had *
mentalboy
PostPosted: 22:35 - 13 Jan 2014    Post subject: Reply with quote
Nice clean air filter or is it missing? As SQL said if you are running very lean then you can expect problems sooner rather than later. Not sure if the needle has multiple positions for circlip, if so did it go back as before? Has the mixture screw been tweaked recently?
Make mine a Corona.
charrington96
PostPosted: 22:40 - 13 Jan 2014    Post subject: Reply with quote
Just replaced air filter, well I never used to have one as it wasn't connected... I know it can do serious damage and the bike shop had adjusted all the mixture screw after I replaced the air filter... I only heard it today, and I know the cold affects 2 strokes
bikersupermot...
PostPosted: 04:00 - 14 Jan 2014    Post subject: Reply with quote
it doesnt affect my 2 strokes - any of them! even in aviemore in scotland in winter - they still run the same as they did in norfolk last summer! - the outside temps made no difference at all.
something else is causing your popping - maybe the cold is affecting your ears? Laughing
tinybikes
charrington96
PostPosted: 08:45 - 14 Jan 2014    Post subject: Reply with quote
It could be Laughing maybe my ears are popping
PostPosted: 10:10 - 14 Jan 2014    Post subject: Reply with quote
Is your piston or exhaust perchance fouled with carbon build-up?
Hugh Farking Cant
PostPosted: 11:55 - 14 Jan 2014    Post subject: Reply with quote
Nobody else think this could be a header pipe gasket issue ?
PostPosted: 12:41 - 14 Jan 2014    Post subject: Reply with quote
Could be, but I imagine that OP should be able to hear it blowing when on the throttle if there's a leak. 2 stroke though, I dunno, literally.
charrington96
PostPosted: 17:30 - 14 Jan 2014    Post subject: Reply with quote
The spark plug is fine, chocolate tan colour... I have a problem with checking for carbon build up, my exhaust is rotten, been putting WD on the bolts for a few days... Its due an MOT in 2 weeks, bike shop know me well so I'll ask them about it
Robby
Dirty Old Man
PostPosted: 18:20 - 14 Jan 2014    Post subject: Reply with quote
On a bike in standard tune, popping and banging on the overrun is usually caused by a leak in the air inlet or exhaust - so a holed exhaust or a split inlet rubber.
If the exhaust is not holed and the inlet rubber not split, and you have been cocking around with it, sort the bits that you have cocked around with first.
charrington96
PostPosted: 18:41 - 14 Jan 2014    Post subject: Reply with quote
Ive looked at the manual, gonna put carb to its original setting and see how it runs
mentalboy
PostPosted: 10:52 - 15 Jan 2014    Post subject: Reply with quote
... the bike shop had adjusted all the mixture screw after I replaced the air filter...
I think you'll find your answer here!
Make mine a Corona.
charrington96
PostPosted: 17:52 - 15 Jan 2014    Post subject: Reply with quote
Yep, I adjusted the mixture screw and now no loud noises, thanks Smile
The last post was made 12 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 105.79 Kb
