Forks sticking?
Lardedah
PostPosted: 21:11 - 14 Jan 2014    Post subject: Forks sticking? Reply with quote
I recently fitted new front end (handlebars, tripple trees, forks, wheel)to my keeway speed 125. I did a 30 mile journey up the A50 and have noticed that they compress down a little bit with each bump until they are all the way down (and ride is rock hard) and they just don't want to come back up and need to yank the bars up to bring them back to proper position. :S I put 140 ml of fork oil into each after reading about it on the old web. Hoped someone might be able to suggest any other issues I may have overlooked or just been purely ignorant of. Confused
Don't know a thing.
Fisty
PostPosted: 21:45 - 14 Jan 2014    Post subject: Reply with quote
Are there springs in the forks?
Fatter and faster than Fret
Lardedah
PostPosted: 21:51 - 14 Jan 2014    Post subject: Reply with quote
"Quietly and consistently taking the piss."
yep !
Don't know a thing.
Raffles
PostPosted: 21:56 - 14 Jan 2014    Post subject: Reply with quote
Did you remember to re-install the caps at the top of the fork stanchions?
Fisty
PostPosted: 23:40 - 14 Jan 2014    Post subject: Reply with quote
yep !
Was a serious question, I once purchased a set of forks from ebay and the springs had been removed!
temeluchus
PostPosted: 01:47 - 15 Jan 2014    Post subject: Reply with quote
put the bike on the centre stand, grab the fork bottoms and pull the forks front to back. check if there is any movement. your fork bushes may be fucked.
PostPosted: 02:00 - 15 Jan 2014    Post subject: Reply with quote
Does sound like it is acting as though there are not springs in there, or missing spacers Laughing .
However check that the forks are straight (assuming 2nd hand, might have come from a crashed bike) and are not twisted in the yokes.
Teflon-Mike
tl;dr
PostPosted: 14:18 - 15 Jan 2014    Post subject: Reply with quote
What grade fork oil did you use?
Did you flush them?
It 'sounds' like gross over-damping; that would happen to lesser degree with too heavy a fork oil, or the damper plunger / orifice ' fouled.
If the forks were left dry of oil, and or not properly cleaned could have gone rusty inside?
Have you stripped them?
Otherwise, as suggested, the fork bushes could be buggered, and or the stanchions not straight... you can get such effect from a fork that doesn't 'look' bent, as in the classic kink you get from a front end smash, but are slightly banana'd along their entire length.
kestrel
PostPosted: 19:31 - 15 Jan 2014    Post subject: Re: Forks sticking? Reply with quote
Are the replacement yokes identical to the originals? If the fork centre dimension is different, even by a very small amount, then you need to adjust the wheel spacers accordingly. Mis-matched yokes and spacers introduce fork stiction which will cause them to operate in the manner you describe. Are you sure that the wheel spacers are actually present and correctly fitted?
Isle of Man.........Road Racing Capital Of The World
Lardedah
PostPosted: 20:11 - 15 Jan 2014    Post subject: Reply with quote
So, I've taken them off springs and spacers both present and correct and in pretty good condition. I fitted the new forks to the bike the same way the old ones came off, literally just cycled through steps backwards.
And have just noticed there's a slight bend in the top half. Warped way near the top but assume could be other related damage further down.
:edit:
Had to replace old forks (worked fine) because previous owner had done a proper bodge job and knackered the threads on top nut and fork where they bite, don't suppose anyone know somewhere/someone around staffordshire/cheshire who could rethread them to save me buying another set??
Also, new forks were from 2012 model (mines a 59 plate). And the 'bottom half' were slightly longer and the chrome top half was shorter to compensate. Yokes were identical (but much shinier)
Don't know a thing.
The last post was made 12 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 67.25 Kb
