| Rurtbeynolds |
 Rurtbeynolds L Plate Warrior
| Lord Percy |
 Lord Percy World Chat Champion
| Rurtbeynolds |
| Mark65 |
 Mark65 World Chat Champion
 Posted: 16:16 - 15 Jan 2014 Post subject: |
HT leads and suppressor cap all sealed?, fuel mixture correct?,choke working properly?, you can pick up headlights of ebay I think or wemoto, try those first, my CG popped a bit but I tweaked the idle mixture screw and it stopped. Oh and hows the spark plug?
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:09 - 15 Jan 2014 Post subject: |
What state is the choke in while you're going through this ordeal? On my CG125-copyengine, I only needed full choke to get it started in the coldest of weather, and was off the choke within a minute. ____________________ Biking is 1/20th as dangerous as horse riding.
| mudcow007 |
 mudcow007 World Chat Champion
| Rurtbeynolds |
| Mark65 |
 Posted: 21:23 - 15 Jan 2014 Post subject: |
Plug sounds like rich mixture, if its dying in the rain it may be the cap mine was doing it got a new one from brooks barn for about £3 and its fine now, the rubber bits must have worn over the years, mine sounded like it was running out of fuel sputtering then died and would then restart straight away.
https://www.brooksbarn.co.uk/NGK-PLUG-CAP-LB05F-R-EACH_A18KI5.aspx
The rich running may be your problem when cold so try a plug chop to see what its like at normal speed if its ok then your idle mixture may need changing. Let me know if you need any thing from a haynes manual I can photo copy it for you.
| kramdra |
 kramdra World Chat Champion
 Posted: 22:33 - 15 Jan 2014 Post subject: |
HT lead is the thing connecting sparkplug to the coil.
Check your fuel to be sure no water/rust in it, my chinky bike has similar issues with wet weather and does not run well from cold.
Sell bike asap and get one that works is not a CG  |
| Rurtbeynolds |
| mudcow007 |
The last post was made 12 years, 269 days ago. Instead of replying here, would creating a new thread be more useful? |
