zzr600 front brakes
mic
PostPosted: 00:05 - 15 Jan 2014    Post subject: zzr600 front brakes Reply with quote
Yoooo
So when I push the bike in and out of the garage I can hear a ssshh ssshh ssshh noise. Or maybe shhhh shhhh shhhh. I'm gonna assume it's a sticky caliper, can anyone confirm? And if it is, how much will it cost to put right? Still on standard callipers.
Cheers ta
zzr600
kerr
PostPosted: 00:17 - 15 Jan 2014    Post subject: Reply with quote
Could be a warp in the disk?
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
mic
PostPosted: 00:18 - 15 Jan 2014    Post subject: Reply with quote
Dunno. One disc has a groove in it.
zzr600
recman
PostPosted: 02:01 - 15 Jan 2014    Post subject: Re: zzr600 front brakes Reply with quote
mic wrote:
YooooAnd if it is, how much will it cost to put right?
Not a lot.
https://www.youtube.com/watch?v=FNz00OTRLzM
DrSnoosnoo
PostPosted: 10:33 - 15 Jan 2014    Post subject: Reply with quote
Could be a warp in your disc or it could be a sticky piston, those tokicos are renowned for being crap tbh.
whip em off and give em a clean like what is in that youtube link above. you have to keep on top of these calipers to keep them working well, so they should be on your maintenance list
misscrabstick
PostPosted: 11:18 - 15 Jan 2014    Post subject: Reply with quote
Could be nothing, disc brake pads often drag against the disc after the pistons have retracted, then you get a bit of overnight light rusting on the discs and then a noise, get that front wheel off the ground and spin it , see if the brake is causing drag.
totalllama82
PostPosted: 21:01 - 16 Jan 2014    Post subject: Reply with quote
+1 to this. Make sure you have a problem before you start. Wheel in the air and spin it, if it spins less than once then i'd take action.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
SteveZZR
PostPosted: 04:30 - 17 Jan 2014    Post subject: Reply with quote
Have a look and work out what it is.
If it's caliper related (not disc) and it'll cost ANYTHING to fix it, throw them on ebay spares / repair and buy some Honda Nissin calipers. They're a huge upgrade and go straight on if you use the conversion bolts available on eBay.
StevenF
PostPosted: 10:17 - 17 Jan 2014    Post subject: Re: zzr600 front brakes Reply with quote
recman wrote:
Not a lot.
Excellent video, cheers Thumbs Up
The last post was made 12 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 59.71 Kb
