Trickle charger
Jonathan A
PostPosted: 21:38 - 16 Jan 2014    Post subject: Trickle charger Reply with quote
Since its been cold, my bikes battery has been becoming weak after more than a few days of standing. I'm guessing that it needs a trickle charger? Confused
Also i'm thinking of connecting the charger via the cigarette lighter socket on my bike, for ease of use (by replacing the clips with a lighter plug) is this a good idea?
Cheers Very Happy
delsol
PostPosted: 22:12 - 16 Jan 2014    Post subject: Re: Trickle charger Reply with quote
Cheers Very Happy
Another option, direct to battery via waterproof socket as included with https://www.amazon.co.uk/OptiMate-4-Battery-charger-conditioner/dp/B000R5936U/ref=sr_1_1?ie=UTF8&qid=1389906099&sr=8-1&keywords=optimate+battery+charger
Really good charger that flashes its lots of lights a lot.
Cheaper option (if you hurry on down)
https://www.lidl.co.uk/cps/rde/SID-5A04A70F-BF3A6BEE/www_lidl_uk/hs.xsl/our-offers-2491.htm?action=showDetail&id=9103
Unless you are messing about with batteries that are going fubar, the cheaper one is all you need.
I have both, swapping them around on 2 different bikes I cannot tell the difference, (multimeter tells me the same).
One bike has a 6th month old batt, other has 7 year old batt, both stored in cold cave.
Islander
PostPosted: 22:14 - 16 Jan 2014    Post subject: Reply with quote
I'd recommend an Optimate or other reputable smart charger. If your battery is flagging then this type of charger will attempt to revive it for you. They come with battery connectors that you can leave fitted too so connecting them is a breeze. Thumbs Up
Jonathan A
PostPosted: 22:34 - 16 Jan 2014    Post subject: Reply with quote
Well money is tight at the moment, so I guess i'll be heading to lidl tomorrow Wink
either that or this: https://www.argos.co.uk/static/Product/partNumber/7405392.htm
arry
PostPosted: 23:15 - 16 Jan 2014    Post subject: Reply with quote
Imo buy the optimate. It's available for 50 quid delivered so it's not exactly mega money over the cheaper ones. Comes with the battery lead to leave connected and works really well
It's already recovered my car battery and sorted the Ybr battery too. Paid for itself
doggone
PostPosted: 23:38 - 16 Jan 2014    Post subject: Reply with quote
The optimate will do you for years, it really is worth it because there's always going to be spells you can hardly use the bike for a few weeks.
It will extend a batterys life if you keep on top of it.
That included battery tender lead is about £10 to buy separate.
Is your cigarette socket live with ignition off?
Jonathan A
PostPosted: 23:47 - 16 Jan 2014    Post subject: Reply with quote
I will have a think in that case, and yes the lighter socket is live with the igntion off.
Jonathan A
PostPosted: 16:46 - 17 Jan 2014    Post subject: Reply with quote
Also, Ideally I would like to extend the 12 volt wires on the charger to about 15 metres, So I don't have to mess about with any 240 volt stuff out side. Would such long wires cause a problem?
Islander
PostPosted: 17:07 - 17 Jan 2014    Post subject: Reply with quote
As long as they are large enough (cross sectional area) to carry the current without causing a voltage drop then they're fine.
As a general principle though, it's better to extend the mains end.
Copycat73
PostPosted: 18:25 - 17 Jan 2014    Post subject: Reply with quote
possibly 15,cos that's how long I`ve had mine. Wink
caveat emptor
The last post was made 12 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 63.84 Kb
