ZX6R models - parts compatibility
Wahlberg
PostPosted: 00:57 - 17 Jan 2014    Post subject: ZX6R models - parts compatibility Reply with quote
Hi guys
Someone mentioned to me a while back that parts from later model ZX6R's are compatible with the '97 F3 models?
Anyone found this to be true?
I only ask because I have found some parts are are as abundantly available as rocking horse turds!
If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape! Smile
misscrabstick
PostPosted: 01:04 - 17 Jan 2014    Post subject: Reply with quote
Cradley Heath Kawasaki, google them, use their parts finder to get the part numbers and compare them, only accurate way.
PostPosted: 01:24 - 17 Jan 2014    Post subject: Re: ZX6R models - parts compatibility Reply with quote
Very few are, as far as I know - it was basically a complete redesign.
I'd have thought you'd find more in common with the B model ZX9R.
Lots are compatible between G and J/A of course and also for C/E/F ZX9Rs.
SteveZZR
PostPosted: 04:29 - 17 Jan 2014    Post subject: Reply with quote
https://zx6r.com/mechanical-technical/15021-parts-compatibility-list.html
There you go!
You can actually bolt a G or J engine into an F if you get the respective engine mounts, and all swingarms from the 89' D up to the 06 636 (and beyond I think) will interchange mod-free at the spindle end (obviously some fiddling to make exhausts, rearsets and such clear correctly and wheels to line up).
With a friend with a lathe you can do anything, i.e. a 2007 ZX10R front end on a 1995 ZZR 600 E. I can get lathe work done at a fair rate if you PM me.
The last post was made 12 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 39.63 Kb
