Battery powered lights
WD Forte
PostPosted: 12:51 - 17 Jan 2014    Post subject: Reply with quote
All manner of things come to mind
Is this to fit alongside existing lights as an emergency measure
or on a say a bike with a daylight MOT or a work in progress?
I was in a big tescos the other day and they have cheap but highly
visible front and rear bicycle lights plus multi led white illuminators about 30mm thick that you could stick to a nonworking headlight.
In a pinch, these may get you home on well lit roads without getting pulled as you could argue you've made yourself visble to other road users.
If its a long term built in system you want, all sorts of options are open to you
bikers smell of wee
PostPosted: 12:53 - 17 Jan 2014    Post subject: Reply with quote
Travel in an area with 30mph limits and streetlighting. Laughing Minimal lighting required.
Fizzer Thou
PostPosted: 18:59 - 17 Jan 2014    Post subject: Reply with quote
Pro-Racing do complete kits for CR125 motocross bikes
https://www.proracing.co.uk/xc_lighting_honda_cr125_250_500.htm
Always have a 'Plan B'
Copycat73
PostPosted: 19:04 - 17 Jan 2014    Post subject: Reply with quote
the current drain for the set up you describe is 7.6 amps.
3000mA = 3A
I would be lookin @ a lead acid battery
caveat emptor
Robby
Dirty Old Man
PostPosted: 11:44 - 18 Jan 2014    Post subject: Reply with quote
Does the bike have any kind of alternator as standard for the ignition, or is it a total loss jobbie with a battery to make sparks?
If there is some kind of alternator, find a way to get power out of it. If not, it must have some manner of battery, so use that as your power source.
I would avoid going down the RC battery route. A small lead acid battery will still last a good while and RC batteries seem to give good energy density at the expense of failing in an expensive and destructive way when you cock up the charging or damage them. Damage is a factor when you're using an off-road bike.
Copycat73
PostPosted: 11:50 - 18 Jan 2014    Post subject: Reply with quote
_Iain_ wrote:
https://item.mobileweb.ebay.co.uk/viewitem?itemId=121200586223&cmd=VIDESC
This perhaps?
I'll look into stator kits and such but the idea was to keep it sub £75 all in Thumbs Up
yes,
that will give up to 2 hours light but after an hour or so it will be fading.
the hardest part will be where to stash the battery otherwise it should be easy to set up.
caveat emptor
The last post was made 12 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 66.87 Kb
