Any plumbers on here? Has my circulation pump gone?
400bandit
PostPosted: 20:07 - 20 Jan 2014    Post subject: Any plumbers on here? Has my circulation pump gone? Reply with quote
Hi all,
My heating was tripping an RCD the second the boiler ignited.
At first I thought it was the programmer or the boiler itself but I don't think that is the case.
I noticed a 'pop' coming from the circulation pump when the system tripped, I turned the speed setting on the pump to 2 (from 3 as it has always been since moving in a few months ago) and now the system doesn't trip.
However, it seems the pump, on setting 1 or 2 doesn't do anything and as such the boiler shuts down shortly after igniting.
The pump seems to rotate freely but I can't hear it operate when it should.
I'm guessing the popping noise I could hear was the capacitor in the pump?
The pump in question is a Myson CP53 that according to the good people of the internet, is a pretty shoddy unit? It's probably the best part of 15 years old now to be fair.
Any plumbers out there concur with my suspicions?
Any help would be much appreciated.
Thanks,
Joe
doggone
PostPosted: 20:29 - 20 Jan 2014    Post subject: Reply with quote
They are relatively easy to replace, there should be a valve either side you can turn with a flat screwdriver.
400bandit
PostPosted: 21:31 - 20 Jan 2014    Post subject: Reply with quote
I'm going to give replacing it myself a go, like tou said, it looks easy enough.
Just wanted to see if anyone else agreed that it is the problem?
Thanks,
Joe
Al
PostPosted: 18:30 - 21 Jan 2014    Post subject: Reply with quote
What your saying sounds fairly likely but you could check the pump is at fault by disconnecting where it is wired to the heating system and sticking a three pin plug on the end, try running the pump without the rest of the heating system on and see if it still trips.
There might be an easier way but with my limited electrical knowledge thats what I'd try Smile
Yamaha FZR400RR 3tj
My Instagram Thingy
Moxey
PostPosted: 10:28 - 22 Jan 2014    Post subject: Reply with quote
First turn the boiler off then look where the pump is housed (usually on the head of the unit) there should be 4 Allen head bolts, remove these and you can remove the pump, usually the impeller needs a bit of a clean and after 15 years I would expect it to.
If the pump itself is actually faulty then as Al suggested, but I would first try cleaning it Thumbs Up
map
Mr Calendar
PostPosted: 11:01 - 22 Jan 2014    Post subject: Reply with quote
Don't know if this will help you but might be worth a try.
A few years ago my old pump failed after heating off most of the summer (I don't do that now).
Anyhow pump had a big screw in the middle that you could undo. Did this a a little water leaked out. Behind screw is another slot for a screwdriver. Turn this and it freed the pump. Put cap screw back on and all good (until it failed totally but I estimated it was nearly 20 years old as installed when house built).
kitty kat
PostPosted: 19:48 - 22 Jan 2014    Post subject: Reply with quote
Apparently, after talking to Mr KK, you need a new pump power head, should be about £60 from somewhere like plumbcentre, but make sure it is not an A rated one as that won't fit.
400bandit
PostPosted: 20:04 - 22 Jan 2014    Post subject: Reply with quote
Thanks all,
After a bit of tinkering yesterday, I feel more confident the pump needs replacing, the pump itself turns freely and there's nothings blocked inside the pump.
Upon taking the electrical cover off I could smell a "burnt electrics" smell (is this what KK is referring to?)
I should have a new pump with me tomorrow to fit.
Thanks,
Joe
400bandit
PostPosted: 20:42 - 23 Jan 2014    Post subject: Reply with quote
New pump fitted and all is good again Thumbs Up
henry hoover
PostPosted: 17:05 - 09 Feb 2014    Post subject: Reply with quote
This would only affect you if your hot water primaries were gravity fed if they are fully pumped then you shouldn't have to switch on the heating in the summer.
Cbr600rr 2010 Sold
Zx6r 636 2006 sold
Gsxr 750 L1 current
The last post was made 12 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 65.99 Kb
