Thank god I wasn't wearing earplugs
dragstaar
PostPosted: 22:39 - 20 Jan 2014    Post subject: Thank god I wasn't wearing earplugs Reply with quote
So, the one time I wasn't wearing earplugs, I was riding home from work.
On the way back, I notice a slight rattling noise, as if I had an uber slack chain. "funny", I thought to myself, "it was fine on the ride in this morning".
I was almost at the gym where I was headed to, so I carried on. Got there, and hopped off, had a look at the chain, expecting it to be a bit slack. As i'm wiggling the chain, the whole rear sprocket moved!
Turns out, the nuts holding the sprocket on had somehow rattled loose and come off. The bloody thing was on with just 2 bolts. Thank god for the underseat tool-kit.
Used a spanner to tighten it up as well as I could and nursed it home, no hard acceleration or braking. Got it home. But blimey, has anyone had this happen before?
And any tips to stop it happening again once I have new bolts (other than using a torque wrench) lol.
PostPosted: 22:41 - 20 Jan 2014    Post subject: Reply with quote
Little dab of loctite, or use nyloc nuts. Thumbs Up
FirebladeRuss
PostPosted: 22:48 - 20 Jan 2014    Post subject: Reply with quote
Had the same on my bandit. Wasn't quite as bad as the bolts had only come loose rather than falling out.
Twitter is for people who can't STFU even when they're by themselves
stuarthouston
PostPosted: 23:00 - 20 Jan 2014    Post subject: Reply with quote
Happened to me too. To make matters worse, the loose nut began to foul the swing arm and bent the stud as well. Thankfully, I was changing the chain, sprocket and rear tyre anyway, so replaced the stud at the same time.
That said, my sprocket wasn't moving at all, as it's mainly held in place by a big circlip on the CG.
'96 Honda CG125 BR-T
dragstaar
PostPosted: 23:11 - 20 Jan 2014    Post subject: Reply with quote
hmmm, not as rare as I thought. So a dab of loctite should hold them right?
They're pretty pricey for a set of nuts lol. Egay is approx £25 and thats for the anodised tat. The originals seem to be a bit more.
sidewinder
PostPosted: 23:21 - 20 Jan 2014    Post subject: Reply with quote
Glad you never had a spill due to it Thumbs Up
Something else to check weekly I think
Skyblue
PostPosted: 23:22 - 20 Jan 2014    Post subject: Reply with quote
Why do you normally wear ear plugs are you a speed merchant!
Sid_The_Sloth
PostPosted: 00:09 - 21 Jan 2014    Post subject: Reply with quote
Just weld it on you'll be fine Razz
2013 Honda Shadow VT750C2B Black Spirit, 1994 CBR600 f2
PostPosted: 00:10 - 21 Jan 2014    Post subject: Reply with quote
In fairness, I find earplugs tend to make the high-pitched, clattery noises more noticeable.
And yes, nylocks. New ones. They generally come with a kind of locking-ish nut but after a few times being done up and undone, any pretence of them actually locking goes out of the window.
Is there a lot of play on the cushdrive that could be giving them a hard time?
The Artist
PostPosted: 00:14 - 21 Jan 2014    Post subject: Reply with quote
Don't they normally have tab washers like this?
https://www.jackphelps.com/vstrom/images/sprocket6.jpg
I know that is a front sprocket but all the ones I have seen on the rears have tabs like this to prevent them undoing.
Derivative
PostPosted: 01:11 - 21 Jan 2014    Post subject: Reply with quote
70mph is enough to damage your ears after 10 or 15 minutes.
Not an issue if you don't ride often but if you commute for years on end it's certainly something to be aware of.
suzukiGN125
PostPosted: 17:43 - 21 Jan 2014    Post subject: Reply with quote
i had the entire rear wheel fall off my suzuki, had it about 2 weeks from the garage just pulled out my house and off it came, luckily i was only doing about 5 mph.
flumpy7
PostPosted: 19:05 - 21 Jan 2014    Post subject: Reply with quote
No that wouldn't work cause of the axle lol
You can have this type on the nuts though
https://www.ydsparts.com/132tabwasher.jpg
2012 Sinnis apache
The Artist
PostPosted: 19:32 - 21 Jan 2014    Post subject: Reply with quote
That is what I meant but couldn't find an exact picture. Thumbs Up
dragstaar
PostPosted: 22:04 - 21 Jan 2014    Post subject: Reply with quote
I have never seen that thing in my life. What is that? Does it sit under two of the sprocket nuts?
I wear the ear plugs because even though I don't do motorway commuting, the exhaust can is loud, and my hearing is shit anyway, and I don't want it getting worse. Besides, I find its nicer to ride with them in, and I feel less tired when I get off the other side. There's something about constant wind noise which is just tiring!
flumpy7
PostPosted: 22:58 - 21 Jan 2014    Post subject: Reply with quote
Yeah but TBH I think I've only seen it once. Better just to make sure your nuts are tight nudge nudge Wink Wink
2012 Sinnis apache
illuminateTHE...
PostPosted: 23:09 - 21 Jan 2014    Post subject: Reply with quote
Question here is how much can you bench and squat?
Theory: PASSED Module 1: PASSED Module 2: PASSED 12/2012!!!
yzf r125 [SOLD] sv650 [CURRENT]
ViniH
PostPosted: 13:51 - 22 Jan 2014    Post subject: Re: Thank god I wasn't wearing earplugs Reply with quote
You should get some ear plugs that protect your ears but don't mess up your hearing.
I bought some of these yesterday and they are *really* good.
https://www.auritech.info/products/biker/
Currently Riding: MT-07 Previous: XJ 600 N
Shinigami
PostPosted: 15:19 - 22 Jan 2014    Post subject: Reply with quote
had bolts come ever so slightly loose before on my 125 rear sprocket, that was likely me not doing them up tight enough though as it was my first chain and sprocket change i'd ever done
The last post was made 12 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 100.71 Kb
