Honda XR 125 Connection problem
adam2013
PostPosted: 19:01 - 21 Jan 2014    Post subject: Honda XR 125 Connection problem Reply with quote
Hi, I have a 2004 Honda XR125 and it has a connection problem(Turn the key and nothing, no power anywhere)
I have spent hours trying to find out the problem but got to the bottom of it. Behind the headlight is 3 big connectors, I disconnected all three the reconnected one by one (just for reference the colours)
please note that i disconnected the headlight connector but does not effect this diagnostics
1.clear connector connected - nothing
2 black connector connected with the clear one - got power
3 white connector connected with all - nothing again
(the white connector goes to the start button)
I disconnected the white one and got power again, Cleaned up the connections and tried again nothing (with a multi meter power is getting to the white connector from the main wiring harness. also when the start button part of the white connector is connected it is also getting power to all but one wire, no power wire colour is - solid black - believed to be ground/negative
Do you have any ideas what it could be - any help much appreciated
Thanks in advance
Adam Very Happy
Current: '04 Honda XR 125L
Project: '86 Yamaha DT 125LC
adam2013
PostPosted: 19:17 - 21 Jan 2014    Post subject: Reply with quote
I would Just like to add with the headlight wire connected but not the white wire thats causing the problem there is not power at all, then I disconnect the headlight wire again without the white connector there is power
Sorry for confusing people but I'm trying my best to explain this
The last post was made 12 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 32.56 Kb
