Any difference between a brake and clutch master cylinder?
0l0dom0l0
PostPosted: 21:11 - 21 Jan 2014    Post subject: Any difference between a brake and clutch master cylinder? Reply with quote
Buying a Brembo 19x18 off a friend. Just wondered if I could use this on the clutch side or brake side?
Fizzer Thou
PostPosted: 21:18 - 21 Jan 2014    Post subject: Reply with quote
Please tell me that this is a trick question Rolling Eyes
Always have a 'Plan B'
0l0dom0l0
PostPosted: 21:19 - 21 Jan 2014    Post subject: Reply with quote
No, why would it be?
PostPosted: 21:33 - 21 Jan 2014    Post subject: Reply with quote
I too am curios as my KTM clutch and brake MC look identical, just switched round.
Islander
PostPosted: 21:35 - 21 Jan 2014    Post subject: Reply with quote
Apart from them being handed? Razz
0l0dom0l0
PostPosted: 21:46 - 21 Jan 2014    Post subject: Reply with quote
Embarassed
cb1rocket
PostPosted: 02:48 - 22 Jan 2014    Post subject: Reply with quote
You just need to check the master cylinder is a compatible size. Brake mastercylinders are bigger iirc
barrkel
PostPosted: 03:19 - 22 Jan 2014    Post subject: Reply with quote
Apart from the handedness...
Hydraulic systems are levers as well as force transmitters. They use the relative areas of the pistons at either end as a force multiplier. Pushing a narrow piston is easier than pushing a big piston, since narrow pistons need move much less fluid for the same distance travelled. Thus brake master cylinders have small single pistons and the calipers have multiple big pistons. Force at the lever is multiplied when it gets to the pads. Correspondingly, lever movement is much larger than the pad movement.
So the application does matter. If the master cylinder piston size is very different from the designed original for the clutch, the clutch may end up very hard to pull with little lever travel for feathering (too big), or may require too much lever travel to go from fully engaged to fully disengaged (too small).
Islander
PostPosted: 11:16 - 22 Jan 2014    Post subject: Reply with quote
That would have been my next point. Thumbs Up
The last post was made 12 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.78 - MySQL Queries: 13 - Page Size: 61.43 Kb
