| muz379 |
 muz379 Derestricted Danger
 Posted: 00:16 - 18 Jan 2014 Post subject: YBR 125 few problems ,rear brake and electric start |
New biker on a very big mechanical learning curve off work for a few weeks waiting to start a new job in feb when the bike is going to get a hell of a lot more mileage put on it traveling , decided ill do some preemptive maintenance and service it now rather than in the middle of my rigorous training for a new job .
First Problem - Ive just changed the chain and sprockets , but When going to remove the rear whee I couldn't loosen or undo the bolt on the brake torque arm , No problem I thought ill just take the sprocket holder out of the back wheel and change the sprocket , put it all back together but now obviously the rear brake isnt working as it did before because the wheel is now further forward than it was with the worn chain .
Ive adjusted the nut on the brake rod as far as I can but thats not doing anything I still have to push the rear brake pedal right to the end of its travel to get any brake force on the rear wheel , Is this because the brake toque arm is still holding the rear brake mechanism in the same position or have I dont something else wrong ? .
If needs be can I use a dremel to cut the nut off and replace it with a new one , and is the bolt for the brake toque arm on this bike just a normal bolt if not where would I get hold of one .
Another problem ive had with the bike since ive got it is that It wont reliably start with the button , I dont mind kick starting it from cold and once ive gone a few miles it will start on the button but eventually I want to sell this and for that reason I wanna get it back to starting reliably on the button , Im gonna take the spark plug out in the next few days and look at it / potentially replace it and look at the air filter/potential replace it , is there anything else It could benefit from having looked at to make it start with the electric start from cold . |
| YBR Ric |
 YBR Ric Spanner Monkey
| muz379 |
| zark |
 zark Trackday Trickster
| Mark65 |
 Mark65 World Chat Champion
 Posted: 09:00 - 22 Jan 2014 Post subject: |
Never had a problem undoing my 07 YBR torque bolt when I had it, try some plus gas on it, the bolt is recessed but should not be that hard to undo as it has a split pin for safety, reassemble with waterproof grease on it.
Starter, try taking the starter motor off and cleaning the contacts, check the brushes.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| zark |
| qarka |
 qarka Spanner Monkey
| zark |
 Posted: 18:14 - 23 Jan 2014 Post subject: |
Ah... since getting all "sodding bike won't start" it's repaid me by starting on the button first time every time...
my cable and connector wiggling must be spot on...
in other news - took the bike to a nearby mechanic and asked him to help remove my torque arm nut... His lad mucked about hammering sockets onto it for ages with no luck - and eventually cut through it with a grinder
he's obviously a knob - and cut through the whole bolt, rather than cutting half the nut away and breaking it off (which is what i was thinking he'd do) then replaced it with a standard bolt and locking washer type thing. i'm not too happy that there's no place to fit a retaining cotterpin in the new bolt - so i'll probably replace that back to OEM spec as soon as i can. I'm thinking adding a second lock-nut in the meantime... i can't see it falling off anytime soon - but yamaha must fit them for a reason, yeah? |
| YBR Ric |
| zark |
| muz379 |
| zark |
The last post was made 12 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
