Overtaking?
mikesaa309
PostPosted: 22:16 - 24 Jan 2014    Post subject: Overtaking? Reply with quote
I'm just wondering on overtaking. I'm currently on a 125cc bike so not many opportunities arise for me to overtake but there have been surprisingly quite a few times I've been able to overtake. Normally if vehicles in front are doing 50 in a 60 zone I'm able to make it past them at a good rate especially with the wind behind me.
Obviously normally on a bigger more capable bike overtaking is a case of a few questions such as "is anything coming the other way?", "can I easily get back to my side of the road?" and things like checking for any debris in the road or seeing if there is a chance of cars pulling in and out of somewhere or even tractors etc turning in to farm gateways. On a 125 not only do you have to do all that but I also have to make sure cars are going to stay the speed they're at. If drivers suddenly put their foot down I stand no chance. So I also have to know why they are going so slow. Is it a slow moving vehicle at the front like a lorry or tractor or is it just someone not wanting to go fast? I then also have to make sure that my bike has enough power left to be able to get up to speed in time. For this reason when I overtake on my bike I tend to run up to the car in front so I'm already going faster than them. This isn't the right thing to do I know but I need to check that 1. my bike can go fast enough. If i realize that actually my bike isn't going to be able to get a good enough speed I shut the throttle of and fall back a bit to remain a safe distance. And 2, I need to make sure the car in front isn't going to put his/her foot down when they realize I'm about to overtake especially with the younger drivers.
I want to know what kind of rear view checks you should do. Should you check your mirrors and a life saver or just check mirrors? I once was riding out and caught up with my friend doing his CBT. The instructor knew who I was as I did my CBT with the same instructor. Anyway I over took the group and later on my friend mentioned the instructor said I didn't do a life saver although I did do a mirror check. I tend not to do a life save while overtaking just doesn't seem like there is enough time in my opinion and also I've just read an article on some advanced motorcycling website that you shouldn't do a life saver as your so close to cars in front. So what is the exact procedure to overtaking as you never get taught it on your CBT same as filtering. After two years of riding I've done around 38,000 miles and still not 100% sure what is acceptable or not when it comes to filtering. I've seen bikers filter what I'd call dangerously or where I don't think that it's safe to do so and yet they still manage to do it and I've seen bikers filter past slow moving traffic and been told you shouldn't do that etc.
Islander
PostPosted: 22:31 - 24 Jan 2014    Post subject: Reply with quote
Get into the habit of performing a lifesaver after mirror checks and directly before a manoeuvre. Your mirrors have blind spots which is why a lifesaver is called a lifesaver. Thumbs Up
mikesaa309
PostPosted: 22:55 - 24 Jan 2014    Post subject: Reply with quote
I do life savers for most things like roundabouts and turning. Plus I also have brought blind spot mirrors for my bike to help my rear view vision even more, they're a great help in seeing in blind spots. I also have a riderscan mirror allowing 180 degree vision behind you except for the view that you block. Just sometimes I find them quite pointless like when moving off from traffic lights doesn't seem to be much of a point although I still do it anyway.
BakesBeans
PostPosted: 22:56 - 24 Jan 2014    Post subject: Reply with quote
Who's to say another car or bike won't overtake you and the car at the same time? You wouldn't want to pull into their path would you. Do a lifesaver.
Current: Kawasaki ZX636
Previous Bike: Honda CBR600F ABS, Yamaha XJ6 F Diversion ABS, Honda VFR400 NC30
Islander
PostPosted: 23:00 - 24 Jan 2014    Post subject: Reply with quote
Or come speeding up to a changing light intending a close overtake...
gavbriggs
PostPosted: 23:01 - 24 Jan 2014    Post subject: Reply with quote
Whenever your changing direction or speed seems to be the easiest way to determine if a lifesaver is required.
As you are doing both when overtaking then it's confirming the need!
Northern Monkey
PostPosted: 23:06 - 24 Jan 2014    Post subject: Reply with quote
I was in my car, overtaking a van, and a lorry. The van driver decided to overtake the lorry as I was coming up along side him.
Result - new rear 1/4 for van, new front wing for my car.
Imagine van was you on your bike. No lifesaver = squashed by my car.
PostPosted: 23:12 - 24 Jan 2014    Post subject: Reply with quote
You can have all the mirrors you want but it's still worth doing life savers.
-Monty-
PostPosted: 23:13 - 24 Jan 2014    Post subject: Reply with quote
A remember a while back I was riding my scooter and was about to do an overtake. It was on a 50mph road so the car in front must have been going at a reasonable rate so - as you mentioned - I started to accelerate before I reached the car to get a run up, then started to move out to overtake (didn't do a life saver). I must have been inches away from crossing the white line and a car screamed past me going way faster than both me and the car in front.
Had I moved out 1 or 2 seconds earlier I almost certainly would have been killed.
Should definitely check mirrors and do a life saver when overtaking.
As for filtering in traffic, I would always do a lifesaver then as well as you might not be the only one filtering (even if it means slowing right down almost to a stop to make sure you don't rear end the car in front while your head is turned). Even if no harm was done, it would still be pretty embarrassing pulling out into the course of another bike.
Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition]
mikesaa309
PostPosted: 23:16 - 24 Jan 2014    Post subject: Reply with quote
Most of the time though on a bike you're already sitting near the central line getting the best view of the road ahead virtually stopping cars from getting past too easy and a mirror check will cover enough area to check for anything overtaking. Most car drivers wouldn't even check they're mirrors at all. There's been so many times I've been behind cars at traffic lights sitting so i can see them in their mirrors and not once do they even glance in there mirrors while I'm always checking my mirrors every like 20 - 30 seconds or so especially if there wasn't a car behind me as I stopped so I'm checking to make sure any car approaching is going to stop and not go into the back of me and I also like to know what's behind me and what is going on. Car drivers never seem to check there mirrors, let alone shoulder checks.
I was once behind a car driven by a girl between the age of 18 - 22 I'd say, she looked everywhere like what was happening on the path or something directly to her left or right but she hardly checked her mirrors. I think it's safe to say that a majority of cars I'm behind would know I'm there. That said I have been behind other motorcyclists and they don't check mirrors either though it's near enough always the learner riders on 125cc bikes. The bigger bikes do normally check mirrors.
mikesaa309
PostPosted: 23:28 - 24 Jan 2014    Post subject: For people who drive cars too... Reply with quote
I just want to know for people who ride bikes and drive a car, do you find you overtake on a bike more than you do in a car? My dad drives a car a rides a bike and although hasn't got a powerful car and he also has a Honda CX500 so not an overly powerful bike compared to today's 500's but he says that a car just doesn't have the same amount of acceleration than a bike does even though his bike isn't overly that powerful. Do you find this with your cars too, maybe if you have a more powerful car like an Audi does it accelerate as well as your bike?
I also think another reason cars don't overtake is because they can't easily merge back into traffic with traffic like bikes can. I've managed to overtake an Aston Martin for this reason.
NooBish-AbbZ
PostPosted: 23:39 - 24 Jan 2014    Post subject: Reply with quote
Lifesavers? Do them. I also ride a 125, and also overtake when the opportunity arises, and also do what you do as in get a run-up to the car before overtaking sorta thing.
If you think there isn't enough time to do a lifesaver between checking mirrors and moving out then check your mirrors earlier. In fact if you've only got time to do one, you're probably going to see more if you do a lifesaver over your shoulder(not just to the side)
NooBish-AbbZ
PostPosted: 23:41 - 24 Jan 2014    Post subject: Reply with quote
As my post says above i ride a 125 and have had my car license for 4 years althoguh haven't drove in over 18 months due to cost of insurance, I'd say bikes obviously do have much better acceleration than cars (with the odd exception, e.g Highly tuned cars), and not only that but they're much slimmer so can overtake on wide roads even if there are cars coming the other way
petechett
PostPosted: 00:10 - 25 Jan 2014    Post subject: Reply with quote
If theres one habit you should get into thats checking your mirrors, im constantly doing it, you need to know what around you. And remember to perform a lifesaver check whenever you manouver, especially lane changes & overtaking etc.
bamt
PostPosted: 00:21 - 25 Jan 2014    Post subject: Re: For people who drive cars too... Reply with quote
My car is a Jaguar XJ8 - pretty powerful with masses of torque. Kick it down to do an overtake, even close to the speed limit (because I wouldn't do an overtake that would push me over the limit, would I?), and it'll push you solidly back into the seat as it roars forwards.
My bike is an XJ900 Diversion - not light, and not particularly powerful as 900s go. The car may have a higher top speed, but the bike will leave it for dead on an overtake. Power to weight is probably 3-4 times higher on the bike, plus it's easier to drop back into a gap.
I do overtake more on the bike, but that's also partly because there is more point. It's easier on the bike to advance up a line of say 10 cars and get to clear road ahead. In a car, that's pretty tricky so you end up advancing one or two cars at a time and pissing everybody off, probably to not get to the head of the line before you're back into a 30 zone.
mikesaa309
PostPosted: 00:32 - 25 Jan 2014    Post subject: Re: For people who drive cars too... Reply with quote
If you could drag race your bike and your car against each other how fast do you reckon the bike would go before the Jaguar catches it up and overtakes? I presume due to power to weight ratio the Diversion would beat it off the line although that said with the car having more traction you'd have to be able to pull away quick on the bike without pulling a wheelie or wheel spinning. But how soon do you reckon your car would take the lead again? I'm not sure on the 0-60 times on either the Jag or Diversion although I've been on the back of a diversion 900 and the rider took it up to 115 mph and it got there pretty quick from around 60 mph. Do you think the Jag would start to catch up at 60 or do you think the bike could be flat out before the Jag takes the lead with the higher top speed?
bamt
PostPosted: 00:38 - 25 Jan 2014    Post subject: Reply with quote
My gut feeling is that the bike would get pretty close to flat out before the car went past. Nothing scientific to back it up though, just knowing how it feels getting either up to cruising motorway speed on entering an empty motorway (so not dodging traffic).
mic
PostPosted: 01:29 - 25 Jan 2014    Post subject: Reply with quote
tl;dr
overtake everything. get a bigger bike if you have to. lifesavers are cool.
zzr600
-Matt-
PostPosted: 02:04 - 25 Jan 2014    Post subject: Reply with quote
https://assets.diylol.com/hfs/a00/0f2/c69/resized/too-damn-high-meme-generator-that-paragraph-is-too-damn-long-ffcbca.jpgThat being said Wink
Plenty of cunts in audi's, bmw's and similar will still give you a run for your money for the sake of preserving testosterone.
Always life saver IMO - mirror checks are precautionary - life savers are to confirm what the mirrors show. It is only a matter of time before you pull out in front of some speeding/nearby vehicle the mirrors didn't show otherwise.
Personally my opinon is, presuming you have a reasonable sense of awareness and self preservation - no amount of life savers, calculations, training and advice will help at the end of the day. Go by your instinct. If you don't feel totally safe and confident to overtake, wait and hold back - are you in that much of a rush to risk an accident thats even slightly avoidable.
If you're confident and evaluate the situation each time - go for it when you feel safe to, thats all there is to it. You overtake - no one else will decide for you.
clancy
PostPosted: 02:30 - 25 Jan 2014    Post subject: Reply with quote
On the talk of lifesavers, in all honesty I pretty much never do them. I have very good observations on the road so I'm aware of anything behind me that may be an issue at some point, I'll only do a lifesaver if something behind me is concerning me.
Before people start having a whinge, my reason for this is if your behind someone about to pull out to overtake and you look away, you have no idea what they are doing in front. I know someone who has crashed cus the car in front slammed the brakes on when they where doing a lifesaver, ironic, I also know a few people on here have crashed because of it.
So far, never caused a problem
KLX 300r
-Matt-
PostPosted: 02:39 - 25 Jan 2014    Post subject: Reply with quote
Not disagreeing nescessarily, but if the time it takes to do a life savers causes an accident, maybe they were too close to what was in front of them? I'm sure theres always an exception but i'd much rather take my chances with a sudden rear end than overtake 'blind' relying on only mirror checks.
clancy
PostPosted: 03:25 - 25 Jan 2014    Post subject: Reply with quote
Possibly yeah i cant say as i dont know. Yeah I know what you mean, just depends what you feel is safer, I feel safer not doing them in general
KLX 300r
PostPosted: 09:55 - 25 Jan 2014    Post subject: Re: Overtaking? Reply with quote
One of the points in Police Roadcraft which I happen to agree with is that the smart way to do it is to move up to the vehicle, then move to the right of the road at the same speed (and FFS, do a lifesaver, the clue is in the name), and only then decide whether to commit to the overtake.
https://www.safespeed.org.uk/sketch002.gif
You'll have trouble doing that on a 125. Well, sucks to be you. It's your risk and your choice.
Dafuq are you still on a 125 then?
bamt
PostPosted: 10:04 - 25 Jan 2014    Post subject: Reply with quote
Or being too slow with the look or turning the head too far? It only needs a quick flick of the head to confirm that the situation is as you thought in your immediate vicinity (anything further back would be in your mirrors), not a complete five second scan from the horizon back to you.
The last post was made 12 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.24 Sec - Server Load: 1.51 - MySQL Queries: 13 - Page Size: 135.36 Kb
