| kawashima |
 kawashima World Chat Champion
 Posted: 15:07 - 25 Jan 2014 Post subject: twin head lights |
Twin head lights on motorcycles seem to me, usually only one light lights up with normal beam, both lights only with full beam.(my TDM too). If both lights light up with normal and full beam, it will make your view better.. I wonder why bike makers doesn't do this.
Does your bike have twin head lights and how is yours? ____________________ own:2020 Serow 250
owned: 2012 YB125SP, 2008 TDM900, 2005 W650, 2002 LS125R, 2002 CB400SF, NS50F, C50 / Trip to UK(2009), Hokkaido touring(2013) |
| metalangel |
 metalangel World Chat Champion
 Posted: 15:14 - 25 Jan 2014 Post subject: |
SV, both headlights were all the time.
Fazer:
https://www.bkmoto.com/image/cache/data/FZ6/FZ6%20Angel%20Eyes%20-600x400.jpg
Two small outer lights and the left headlight all the time, right one was the fullbeam one (left and right from rider's perspective) ____________________ Previous: 2002 Honda CB500 (sold), 2007 Suzuki SV650SK6 (crashed), 2005 Yamaha FZ6 Fazer (sold). Currently bikeless
"A faired bike will get you 10x more clunge than a unfaired one." -Marlboro Matt |
| kawashima |
 Posted: 15:20 - 25 Jan 2014 Post subject: |
Thanks! SV had both lights! I didn't know this.
Fazer's ring lights looks so cool! ____________________ own:2020 Serow 250
| G |
 G The Voice of Reason
| c-m |
 c-m World Chat Champion
| Copycat73 |
 Copycat73 World Chat Champion
| kawashima |
 Posted: 16:24 - 25 Jan 2014 Post subject: Re: twin head lights |
| G wrote: | Pretty much all the bikes I've had with twin lights have both with twin-filament bulbs. NSR125, SV650, R6, ZX6R, ZX9R all have two.
There are some advantages to one each side - you may get a better view on full beam as you get both dip and main beam patterns at once - you shouldn't run both beam patterns together for extended periods if you have a twin filament for heat and possibly power issues I believe.
The reflectors can be specifically designed to work on the dip/main beam (though of course some may use twin bulbs and relfectors each side - zzr1400 an obvious example).
To some degree the size of the reflector often has more impact on how much illumination you get - around 2000 a lot of bikes had pretty big reflectors - it seems like that was about the zenith for decent illumination.
If you want more light, there's always options like HID.
I can see LEDS getting used more - I've got a 12x T6 LED torch that is certainly considerably brighter in the centre than my truck headlights and it could run a lot brighter than it does with a better driver. I could see these getting used for the full beam at least - they can be compact while providing pretty decent illumination forward, then maybe a more conventional dipped beam bulb. |
There were so many two lights bikes not only SV650!
I was not thinking about design and size of reflectors, and did not
know there were some advantages to one each side type. This was really informative for me thanks!
My TDM head light is not so dark compared to off road bikes like XR250, it may be why it has bigger reflectors each side.
When I push full beam button, it gets double brighter, and I wanted the brightness all the time but it may be greedy.
HID kit is expensive and still can't decide to go on it.
| c-m wrote: | Most older bikes with twin headlights use H4 twin filament bulbs meaning both will be on during both high beam and low beam.
Newer bikes tend to use H7 bulbs which are more efficient. However they require a separate bulb for high beam and low beam.
Personally I'm not convinced that twin headlights perform any better then a single headlamp. It's all about the quality of the reflector.
Often twin headlight bikes have a smaller less effective reflector, so all you're really doing is just consuming an extra 60w of power.
Best headlights I've come across in the past few years are the Aprilia Falco (single headlight), and VFR800 (twin head light)
LEDs are on the way, but they aren't that efficient compared to HID or even a regular H7 bulb. You'd want minimum of 2000 lumens, and at that output you're going to need 35-55w plus a ballast pack (similar to HID) and cooling. You also need to contend with the fact they don't often project as well. |
Thanks for letting me know about bulbs, that H7 bulbs used for newer models are more efficient than H4 twin filament bulbs. It may be better having bright one light than dark two lights all the time.
VFR800 seemed to have four lights for me, that was why! Aprilia Falco has large reflector too. It may be better for Full fairing models to have larger reflectors.
I find many HID kit users here, but haven't seen any LED kit users yet.
edit : LED bulbs were sold here too! I didn't know about it  ____________________ own:2020 Serow 250
| kawashima |
 Posted: 16:38 - 25 Jan 2014 Post subject: |
This was very informative for me. Thanks for letting me know about this stinkwheel. This is really a negative point for rider's safety at night, thinking about this(other road user regards me as a distant car) is really scary!
It reminded me of your post that "when approaching a crossing, you should make a zig-zag so that driver think you are on a bike". I'm sometimes doing this.
| Copycat73 wrote: | | kawashima wrote: |
Does your bike have twin head lights and how is yours? |
both my R1 & ZZR14 have a twin headlight set-up,
both work well & give better wider illumination than a single bulb. |
I'm just envious you have R1 and ZZR14! Both R1 and ZZR14 has projector head lumps and looks cool too
Only top end range models can have such nice light systems regardless of manufacturing costs  ____________________ own:2020 Serow 250
| c-m |
| stonesie |
 stonesie World Chat Champion
 Posted: 18:33 - 25 Jan 2014 Post subject: |
Every bike I have had since the CG has twin H4 headlights in pretty damned good reflectors, and you can definitely tell when one bulb blows.. But you have another so can ride on at night  |
| Polarbear |
 Polarbear Super Spammer
| FergieinFranc... |
 FergieinFranc... Borekit Bruiser
 Posted: 19:12 - 25 Jan 2014 Post subject: |
My Sprint, when l bought it (off a policeman) here in France, had single dip and single full beam.
He said that European regs dictated it, because at night, viewed from a distance with twin lights, it could be mistaken for a car some way off, and could result in a vehicle pulling out in front of you. That's the theory....however, it didn't stop me buying a pair of relays, plugging then into the loom and having both twin dip and twin main, as per normal UK.spec. Day time riding with just one dip beam can be just as dangerous if the bulb blew, you've no back up, thats my reason for having the twin set up, and I've not been pulled..yet ____________________ Prendre garde au temps entre le chien et le loup
You don't scare me....I've got a daughter... |
| chickenstrip |
 chickenstrip Super Spammer
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 20:02 - 25 Jan 2014 Post subject: |
I also have 2 lights on the ZXR, one for low beam and one for high beam. I did one night run and it was not good at all. I'm gonna change the bubls and will see. I already got new high beam, it's 100w , the original was 55w I think, I couldn't get yellow 55w. If it won't be any good then I'm gonna put in an average 55w bulb and yellow foil over the light.
I like the idea, having separate headlights to reduce the power consumption and still having the option to turn the second light on.
My mate has a '99 CBR900RR, there are two BIG lamps with H4 bulbs and his bike really brightens up the road, even with low beam. Once, he went couple of meters behind me I turned off my headlight and there was no difference. I tried OFF, low beam and high been, nothing, it was the same. The GPz was the worst, when I had to ride it at night.
https://i970.photobucket.com/albums/ae184/RhynoCZ/ZX7R/DSC02253_zpscf43e97f.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
 Posted: 20:15 - 25 Jan 2014 Post subject: |
I fitted twin 8" diameter Cibie conical projector spots on my MZ. They took H1 bulbs.
I had one for dip with an 85w bulb which was dipped off to the left. The other had a 100W bulb and was aimed straight down the middle. Both on for full beam. I had one of those polychromatic projector fog lights for a position light.
Had to replace all other bulbs with LED to reduce the draw on the charging system.
Oddly, one flash was sufficient to make any oncoming vehicle dip its lights.
Don't have any pictures of that bike other than this one (which doesn't really show the lights).
https://i48.photobucket.com/albums/f216/stinkwheel/Glentrool_2005_15.jpg
The problem was, under heavy braking, the forks dived so much you couldn't see anything on dip. If it hadn't been stolen, I was planning to fit a pressure switch on the front brake line that would put the full beam on under heavy braking. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
| c-m |
 Posted: 20:34 - 25 Jan 2014 Post subject: |
| FergieinFrance wrote: | My Sprint, when l bought it (off a policeman) here in France, had single dip and single full beam.
He said that European regs dictated it, because at night, viewed from a distance with twin lights, it could be mistaken for a car some way off, and could result in a vehicle pulling out in front of you. That's the theory....however, it didn't stop me buying a pair of relays, plugging then into the loom and having both twin dip and twin main, as per normal UK.spec. Day time riding with just one dip beam can be just as dangerous if the bulb blew, you've no back up, thats my reason for having the twin set up, and I've not been pulled..yet |
Why would a vehicle pull out in front of a car? |
| G |
| dextersaurus |
 dextersaurus World Chat Champion
| kawashima |
 Posted: 02:20 - 26 Jan 2014 Post subject: |
| stonesie wrote: | Every bike I have had since the CG has twin H4 headlights in pretty damned good reflectors, and you can definitely tell when one bulb blows.. But you have another so can ride on at night  |
I agree. I want another bulb for insurance too.
I experienced having one bulb blew on one light bike. It was daytime and I was lucky.
Triumph sprint of UK spec had both twin dip and twin main, and European regs are changed into single dip and single full. I didn't know this Thanks!
I sometimes wonder the same thing, if my single dip blows, I must stick my full beam switch with vinyl tape (and tape on the light).
| RhynoCZ wrote: | I also have 2 lights on the ZXR, one for low beam and one for high beam. I did one night run and it was not good at all. I'm gonna change the bubls and will see. I already got new high beam, it's 100w , the original was 55w I think, I couldn't get yellow 55w. If it won't be any good then I'm gonna put in an average 55w bulb and yellow foil over the light.
My mate has a '99 CBR900RR, there are two BIG lamps with H4 bulbs and his bike really brightens up the road, even with low beam. Once, he went couple of meters behind me I turned off my headlight and there was no difference. I tried OFF, low beam and high been, nothing, it was the same. The GPz was the worst, when I had to ride it at night.  |
CBR900 has huge reflectors but it has such a bright light!
I didn't know there was such a difference between two bikes.
But ZXR750 really looks like a racer especially for that small lights
| stinkwheel wrote: | I fitted twin 8" diameter Cibie conical projector spots on my MZ. They took H1 bulbs.
The problem was, under heavy braking, the forks dived so much you couldn't see anything on dip. If it hadn't been stolen, I was planning to fit a pressure switch on the front brake line that would put the full beam on under heavy braking. |
It has huge head lights
LED bulbs are also good for reducing the electricity and still so bright!
It's shame someone stole your bike
This light system must be so bright! It's sad normal off road bikes usually have dark head lights. Honda should make Baja again.
Thanks for posting the pic of your bike with the projector on. It looks much brighter than I was thinking. ____________________ own:2020 Serow 250
| kramdra |
 kramdra World Chat Champion
 Posted: 11:11 - 26 Jan 2014 Post subject: |
https://i1133.photobucket.com/albums/m593/Kramdra/IMG_20130705_145542_zpsbdcd39ae.jpg
Left - Suzuki DL650, Right, CBR600F 2002
The DL650 has dual filament bulbs sharing a reflector. I would guess half the light is wasted. CBR6 has a dedicated reflector for each beam and is far brighter than the DL650, which uses twice as much power
I also think the DL650 is ugly and also quite confusing when its behind me, trying to decide if its a car or bike (the rider is slow, often waiting for him to catch up).
Big, dedicated reflectors with H7 bulbs win imo. Newer bikes seem to have got smaller reflectors, probably for looks. |
| kawashima |
 Posted: 13:01 - 26 Jan 2014 Post subject: |
| kramdra wrote: | https://i1133.photobucket.com/albums/m593/Kramdra/IMG_20130705_145542_zpsbdcd39ae.jpg
Thanks for you picture. CBR600 has huge reflectors!
Large CBR series seem to have bright head lights.
I noticed that my TDM900 also have H7 bulbs(55W*2).
I might be a little bit greedy for the brightness. ____________________ own:2020 Serow 250
| Fizzer Thou |
 Posted: 13:14 - 26 Jan 2014 Post subject: |
Both the Exup1000 and the R1 have twin H4 bulbs fitted.But for daytime riding I disconnect the left bulb and ride with just the single headlight on.I was questioned about this by plod last year when at the Oakdene cafe and I pointed out that if a car was to see two headlights close together they might think that the vehicle was a car and pull out into my path.But if the other vehicle driver was to see a single headlight,they MIGHT...MIGHT think again,thinking 'Motorbike' and stay put.But at night I reconnect the left bulb as the extra illumination is worthwhile.
Many years ago I had a bad experience of a single headlight on my Honda 750,when both filaments blew while riding a bit quickly at night.The Cibie 'Z' beam unit was a worthy investment in those days,but when I was pitched into absolute darkness I was lucky that my brother was riding with me and he saved the situation by switching his lights to main beam.Not long afterwards I fitted a twin headlight fairing to the bike
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Honda%20750/BikesBikesBikes294.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Honda%20750/BikesBikesBikes163-1.jpg ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
The last post was made 12 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
