Additional Bike Lighting
Commuter_Tim
PostPosted: 21:21 - 25 Jan 2014    Post subject: Additional Bike Lighting Reply with quote
Ive been looking around for something to light up my bike in the dark as the headlight is piss poor for making me visible, people seemingly try to kill me on a daily basis at roundabouts.
I wanna buy some of these https://www.amazon.co.uk/Pack-WHEEL-VALVE-CAPS-LIGHTS/dp/B008IY6806/ref=sr_1_17?ie=UTF8&qid=1390660969&sr=8-17&keywords=valve+lights
But apparently you cant legally have flashing lights on your vehicle? nor blue lights, or red to the rear...
So my question is, Does anything legal exist so that I can prevent fuckers from trying to flatten me in the dark? (I could give a fuck If it looks daft, staying alive is the priority here)
I did search several "police forums" and the likes on this topic, but they were as much use as a chocolate cock, So I turn to you BCF! Very Happy
I ride a Bandit 600... badly.
wr6133
PostPosted: 21:27 - 25 Jan 2014    Post subject: Reply with quote
Big LED strips? (like cars use for underlighting). Run down either side you'd be like a mobile Blackpool illuminations.
Skudd
PostPosted: 21:29 - 25 Jan 2014    Post subject: Reply with quote
No matter how many lights, or how much hi-viz you wear there will always be people who don't see you.
Nip down to Halfords and get their £30 spot lights, go on to ebay and get a motorbike switch loom (£5) use the power from your head light and the earth to the battery earth. Jobs all good.
WD Forte
PostPosted: 21:48 - 25 Jan 2014    Post subject: Reply with quote
Lights have one of two purposes
to 'see by' as in headlights or 'see me'
I guess you want 'see me' lights ?
A CG wont have much power to spare so I'd go for leds
As said, you could be lit up like a christmas tree and some daft sod still wont see you so never assume you're safer, but strategically placed
high brightness leds may help.
Honda did a test some years ago where they found lights spread over an area were better percieved by drivers than say a brighter single light.
Cant find the Honda one but this one says similar things
https://hal.archives-ouvertes.fr/docs/00/86/60/62/PDF/doc00015712.pdf
bikers smell of wee
mgh0
PostPosted: 22:09 - 25 Jan 2014    Post subject: Reply with quote
https://www.ebay.co.uk/itm/290784783352?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
https://www.ebay.co.uk/itm/2pcs-3W-LED-Eagle-Eye-Car-Back-Up-Reverse-Tail-Light-Lamp-Daytime-Running-Light-/390572893964?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5aeff5670c
https://i298.photobucket.com/albums/mm265/megah0/A13614B2-CE97-4CA7-9434-BDE7B5F701F2_zpsylrjgkhp.jpg
£6.34 plus some aluminium strip I had around to make some simple L brackets which attach to the engine mounts, could also have used the indicator stems.
Crap camera makes the LEDs look different colours, they are both white.
"Courage is not defined by those who fought and did not fall, it is defined by those who fell and rose to fight again." Adrienne Rich.
recman
PostPosted: 22:16 - 25 Jan 2014    Post subject: Reply with quote
Everyone, yes everyone loves these-
https://www.demon-tweeks.co.uk/motorcycle/headlights/bike-it-dominator-headlight .
Don't let them tell you any different.
Commuter_Tim
PostPosted: 04:37 - 26 Jan 2014    Post subject: Reply with quote
Sadly anything wired in to my CG would be just as useless as the headlight/indicators, its all wired in through the engine so the moment I let loose the throttle it all dims to next to nothing.
Vincent, what sort of angles can the turret bike fire at? I need to be able to target these bastards while cornering, so at least 90 degree range of motion is optimal Very Happy
So as far as legality (in the UK) if its not blue, red, or flashing, am I allowed to fit it to the bike?
BrownTrousers
PostPosted: 08:45 - 26 Jan 2014    Post subject: Reply with quote
What about one of those high vis vests with strips of little LEDs built in?
Should avoid the problem of using bike's power, and should be visible from the side a bit more easily (plus removable, usable on different bikes etc.).
Commuter_Tim
PostPosted: 17:40 - 26 Jan 2014    Post subject: Reply with quote
I'm liking your thinking, then technically the law cant come into play, as its something I'm wearing, not fitted to the vehicle surely...
Plus I already strap a high-vis jacket to my backpack in the pitch black on the way back from work so it wouldn't take any extra effort.
Cheers dude Thumbs Up
PostPosted: 17:47 - 26 Jan 2014    Post subject: Reply with quote
I do no like point light sources. They MAY make it easier to see something is somewhere, but they can also make it harder to judge vector; position, direction of travel and speed.
In the past I've added extra LED strips as running lights (white front, red rear) With the front ones on muffs and the rear ones on the topbox.
I've also added additional amber LED strips to work with the indicators.
It does seem to make a decent difference - it should make it easier to judge vector and just looks 'different' to what you normally see in the mirrow when driving - ie one or two bright points of light, which could be a car a long way away.
Loud exhausts DO help.
I got a load of 'neon string' to put on my bike - the idea being that I would cover visible bits in so it was obvious, but didn't provide a single bright point source.
Never got around to it as I didn't have the commute anymore, but there's an idea of what it could have looked like, in this case as a festive window decoration Smile.
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-prn1/17869_231540160688_5852519_n.jpg
Finally, if you are going for point sources, the triangle pattern pictured above makes sense. Trains in the US have lights like this because it's been proven to make it easier to judge vector - however on a train they can be a bit further apart, of course.
Commuter_Tim
PostPosted: 20:14 - 26 Jan 2014    Post subject: Reply with quote
Cheers for the further advice
I did laugh at the loud exhaust on a CG bit though Very Happy
My powerhouse of a vehicle is clearly enough on its own!
So am i best to put red lights on it if its going on a backpack then?
PostPosted: 20:23 - 26 Jan 2014    Post subject: Reply with quote
No reason you can't have a loud exhaust on a CG125 - pitbikes make a decent bit of sound from a similar capacity.
It really hit home when for a few days I seemed to have less people noticing me. Realised it happened after a put a baffle in the full race system on my tuned zx9 for MOT. Took baffle out and it was back to normal.
Even more people noticed me riding JD's GSXR 6 which had a racefit 'can' (basically a little bit of pipe to make the mid-pip look better.)
mgh0
PostPosted: 20:26 - 26 Jan 2014    Post subject: Reply with quote
https://www.amazon.co.uk/Glowing-Strobing-Luminescent-Luminous-Lighting/dp/B005UCLS9K/ref=pd_sim_k_h_b_cs_2
wonder if this would work
PostPosted: 20:31 - 26 Jan 2014    Post subject: Reply with quote
The FSM pictured above is made of that stuff. It's not as bright as the LED string stuff I had, but you get longer sections of it that are smaller, so can be more creative with it Smile.
PostPosted: 20:55 - 26 Jan 2014    Post subject: Reply with quote
I'm running with adhesive LED strips stuck up on the mirrors.
Commuter_Tim
PostPosted: 22:09 - 26 Jan 2014    Post subject: Reply with quote
Nice idea, did you have to do to much to waterproof the cabling and connectors?
PostPosted: 22:36 - 26 Jan 2014    Post subject: Reply with quote
Not a thing. I just spliced them into the wiring for my dipped beam bulb, stuck them on the mirrors and stalks, whipped a couple of small cable ties around for belt-and-braces, job done.
stuarthouston
PostPosted: 00:29 - 27 Jan 2014    Post subject: Reply with quote
If I was going to add more light to my CG, I'd be tempted to wire it straight to the battery via a fuse, with a relay to the existing switch so that they come on with the dipped beam. In fact, I've been tempted to re-wire my existing head and tail lamps in this way to stop the dimming effect you mention, but I haven't worked out if that would cause too much drain on the battery. Shouldn't be too much of an issue with LEDs though.
I'm almost certain the previous owner of my bike has scooped the innards out of the exhaust. Seems louder than I *think* it ought to be, but then I've never heard another CG running outwith the realms of YouTube to compare. Happy to leave it that way, though. MOT man never mentioned it, and if it makes people more aware of me, all the better. Thumbs Up
'96 Honda CG125 BR-T
mgh0
PostPosted: 14:09 - 27 Jan 2014    Post subject: Reply with quote
When I had my CG the single best thing I did to it was change out the lead acid battery for a motobatt AGM battery, cost < £30 and it made a huge difference to light output, whipped it out once a week for an overnight charge just in case the bike wasn't keeping it topped up.
Marmalade
PostPosted: 14:45 - 27 Jan 2014    Post subject: Reply with quote
This was brought up in live chat the other night.
I suggested a pair of cree led cycle headlights Like these at £15.60 connected to the bike by a voltage dropper 8v3Ah.
I have one running off the supplied battery and it is really bright.
I do use LED adhesive strips on motorbike, they are bright and as rogerborg does, putting them on mirrors, fairing or forks creates an unusual pattern that might help people to see you.
Up front, the led link is my shop, you can of course get these strips in many places.
Cree headlight in use.
https://i881.photobucket.com/albums/ac17/Marmalade43/cycles/474C7F81-8AD6-4A8D-87DC-44A1E3E6D436_zpslqxasigd.jpg
PostPosted: 14:55 - 27 Jan 2014    Post subject: Reply with quote
Note that for any normal bike use a flood lead acid (normal) should do just as well as AGM.
However, a cheap or knackered old lead acid would obviously be outshone by a new decent quality AGM (or lead acid) battery.
AGMs can be damaged by the float charge some vehicles have.
map
Mr Calendar
PostPosted: 15:06 - 27 Jan 2014    Post subject: Re: Additional Bike Lighting Reply with quote
Commuter_Tim wrote:
...apparently you cant legally... blue lights,
One of my pet projects. If blue lights not flashing then the way I read the regulations they're ok. Others differ. Yet blue light must be part of a beacon. Beacons can flash, in fact must emit flashing light and no other sort (so not a constant light then). So the way I read it ok to have a fixed blue led light.
The Road Vehicles Lighting Regulations 1989 wrote:
Restrictions on fitting blue warning beacons, special warning lamps and similar devices
16. No vehicle, other than an emergency vehicle, shall be fitted with–
(a) a blue warning beacon or special warning lamp, or
(b) a device which resembles a blue warning beacon or a special warning lamp, whether the same is in working order or not.
the interpretation section of ROAD VEHICLE LIGHTING REGULATIONS 1989 wrote:
...a special warning lamp is defined as:
"A lamp, fitted to the front or rear of a vehicle, capable of emitting a blue flashing light and not any other kind of light."
On topic a friend of mine drilled and fitted yellow leds on the rear mudguard and side panels. This to make more obvious at junctions. These are perfectly legal.
PostPosted: 15:19 - 27 Jan 2014    Post subject: Re: Additional Bike Lighting Reply with quote
Yea, I always used to think they were illegal, but reading up on them a few years ago for a post on here, I'd agree that they likely are legal.
The last post was made 12 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 138.38 Kb
