| DooGie96 |
 DooGie96 Derestricted Danger
 Posted: 00:30 - 27 Jan 2014 Post subject: Restricting a 1982 Suzuki GS750t |
Hello, just wondering if anyone can give me some advice on restricting my suzuki gs750t, as i am low on funds and cannot afford the restriction kit costing £180, would it be possible that a suzuki GSX750 restriction kit would work or is there another way of restricting older bikes? any advice or ideas would be much appreciated  |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| dydey90 |
 dydey90 World Chat Champion
 Posted: 12:50 - 27 Jan 2014 Post subject: |
I don't know how similar the GSXR engine is, I'm guessing it's ever so slightly nippier. Unfortunately I couldn't find the exact power curve, so this is going to have to be close enough, until somebody with superior googling skills arrives.
Screw in until you can't go past 6000rpm and you're done.
https://www.surfsidemoto.com/images/TRC_Suz_06_GSXR750_SO_Dyno.jpg ____________________ This post is probably not serious and shouldn't be taken literally.
Past: CBR125,ER6f NINJA 650, ZZR600 Current: VFR750 |
| Rogerborg |
 Rogerborg nimbA
| P.addy |
 P.addy Red Rocket
 Posted: 15:12 - 27 Jan 2014 Post subject: |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 15:26 - 27 Jan 2014 Post subject: |
| dydey90 wrote: | I don't know how similar the GSXR engine is, I'm guessing it's ever so slightly nippier. |
They're pretty dissimilar. The gsxr has got four valves per cylinder, whereas the GS has two, so the total power produced is significantly lower. Also, the GS is oil cooled, whereas the GSXR shown is a water-cooled bike that's almost thirty years newer.
A throttle stop would work, but in order to restrict it to the right amount of power, you're taking off the upper third of the rev range at least. I'd be tempted to try a set of second hand restrictor plates from a different bike that uses the same carbs. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| DooGie96 |
 Posted: 23:09 - 27 Jan 2014 Post subject: |
Okay, so would honda restrictors do the job, im really not sure what bikes use the same carbs, and would it have to be the same year? Thank you for everyone who has replied  |
| Kickstart |
 Kickstart The Oracle
| nowhere.elysium |
| DooGie96 |
 Posted: 00:19 - 28 Jan 2014 Post subject: |
So the best way of restricting is..........? I have no clue on this kinda thing all i know is i can open her up in december but until then im restricted  |
| DooGie96 |
 Posted: 03:31 - 28 Jan 2014 Post subject: |
Right, just researched the specs of the carbs: mikuni 6S32SS, 68bhp and some other stuff, anyone know how or what to do to bring it down to 33bhp which is inexpensive
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:43 - 28 Jan 2014 Post subject: |
Mikuni BS32SS. That's a CV carb, so you can put washers in the inlet rubbers.
That means:
#1 Finding out the internal diameter of the inlet rubbers that go between the carbs and the engine inlet.
#2 Finding washers of that diameter.
#3 Drilling appropriately sized holes in each one.
#4 Putting it all back together, which may not be as easy as it sounds if the rubber has hardened, which it will have.
"Appropriately" is where it gets tricky. Without a dyno, you'd just be guessing. Personally I'd guess at 18mm because of reasons.
The other way of doing it is to literally restrict the amount that the throttle can open. The simplest way to do that would be to clamp something like a fishing float or a cylindrical split sleeve cut to the right size onto the throttle cable next to the carbs.
This will stop the cable from withdrawing into the sleeve, or the throttle actuator on the carbs from opening fully.
Ghetto, but what does either method get you anyway? A bike that may or may make over 25kW at the crank, which will itself be a guesstimate based on Dynomaths.
What will be a lot more good to you in 90% of situations is a credible looking piece of paper or some sort of tag or plate on the engine that says "This bike is restricted to 25kW".
You can print that off yourself for the cost of paper and ink. Came with the bike, innit. ____________________ Biking is 1/20th as dangerous as horse riding.
| DooGie96 |
 Posted: 13:35 - 28 Jan 2014 Post subject: |
and do you think you could find me the link to the "legitimate" papers  |
| Rogerborg |
 Rogerborg nimbA
| DooGie96 |
| P.addy |
 P.addy Red Rocket
| DooGie96 |
 Posted: 14:17 - 28 Jan 2014 Post subject: |
right I'm really stuck with this now, why does the insurance company require this if its not legally needed, and how many people have actually got away with sending in the "legitimate" certificates from Fi?
i really want to get this oldy on the road but its difficult when you're low on funds  |
| davebike |
 davebike World Chat Champion
 Posted: 14:42 - 28 Jan 2014 Post subject: |
It is a legal requirement!
Some think the risk of being caught is so low they will not bother
Probable why some insurers are now asking for proof you are abiding by the terms of your licence
Driving non restricted bike on restricted licence having told insurance co it is restricted
Un- licensed
invalid insurance Lied on application
Possible criminal record for no/invalid insurance
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:02 - 28 Jan 2014 Post subject: |
We're specifically talking about insurers asking for evidence that the bike is restricted. There's no definition in law of what constitutes proof of that. A piece of paper, be it an FI Scamcertificate, a dyno printout, or a self-declaration (including a PaddyCerttm) is just that: a piece of paper. It says nothing about what state the bike is in at the time it's being ridden.
| DooGie96 wrote: | why does the insurance company require this if its not legally needed |
That would be a question for them.
What situation are you in? Have you already taken out a policy and now you're being asked to send evidence of restriction, or is this theoretical? ____________________ Biking is 1/20th as dangerous as horse riding.
| DooGie96 |
| DooGie96 |
| jb329 |
 jb329 Two Stroke Sniffer
 Posted: 15:54 - 28 Jan 2014 Post subject: |
You never heard of ebay then??
https://www.ebay.co.uk/itm/Suzuki-GSX-750-F-Restrictor-Kit-33-BHP-certificate-/321308450024?pt=UK_Motorcycle_Parts_13&hash=item4acf79dce8
As for any paper work, our local community copper explained it so.
"If you get pulled for suspected drink driving, you will have to blow in the bag.
If you've got a letter from the pub landlord/your mum/your local JP or anyone else, stating that you only drank coke all night, you'll still have to blow into the bag."
If plod think your bike is not restricted, they'll take it off you and get it tested.
They will not phone FI, or anyone else to ask if they stuck some washers in it sometime in the past because even if they did, you could have taken them out 10 minutes ago and be out seeing how much faster it is now, without the washers. |
| jb329 |
| DooGie96 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:44 - 28 Jan 2014 Post subject: |
You're vanishingly unlikely to find anyone who knows - it's not a particularly common bike, and as noted, they share an approximate capacity and that's about it.
How about you put the ball in their court. If they say they want "proof", then ask them exactly what they will accept, and where that is spelled out in the contract of insurance.
If they give you any problems, escalate it by writing to their complaints department and head all correspondence with "COMPLAINT".
Whether or how you actually restrict your bike is another issue. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 12 years, 236 days ago. Instead of replying here, would creating a new thread be more useful? |
