Author |
wots |
![](images/spacer.gif) wots World Chat Champion
![](images/avatars/495527450539370385dc2b.jpg)
Joined: 30 Aug 2012 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif)
Back to top |
You must be logged in to rate posts![](images/spacer.gif) |
![](templates/standard/images/spacer.gif) |
spikenipple |
![](images/spacer.gif) spikenipple Crazy Courier
![](https://i.imgur.com/zBaVXt4.jpg)
Joined: 20 Nov 2007 Karma : ![Good Karma (Level 3)](/images/karma/green_9.gif) ![Good Karma (Level 3)](/images/karma/green_9.gif) ![Good Karma (Level 3)](/images/karma/green_9.gif) ![Good Karma (Level 3)](/images/karma/green_8.gif)
Back to top |
wots |
Back to top |
spikenipple |
Back to top |
wots |
Back to top |
P. |
![](images/spacer.gif) P. Red Rocket
Joined: 14 Feb 2008 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_9.gif)
Back to top |
misscrabstick |
![](images/spacer.gif) misscrabstick Crazy Courier
Joined: 05 Jul 2013 Karma : ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_1.gif)
Back to top |
wots |
Back to top |
P. |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 21:53 - 28 Jan 2014 Post subject: |
Might be that switch.
One way to find out, ride it and see if you get a sudden kick in power. Pull over then flick the switch. If its different in the mid range onwards then you've found the magical switch for power ![Laughing](images/smiles/icon_lol.gif) |
Back to top |
wots |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 21:56 - 28 Jan 2014 Post subject: |
Paddy. wrote: | Might be that switch.
One way to find out, ride it and see if you get a sudden kick in power. Pull over then flick the switch. If its different in the mid range onwards then you've found the magical switch for power ![Laughing](images/smiles/icon_lol.gif) | As I mentioned, whatever that is, it's had all it's wires chopped. That may have been the pikey conversion rather than what he did previously. There is more of the loom there than I thought, but a lot has been spliced.
Clutch is fooked, but gearbox is fine, runs up and down through the gears and you can see the sprocket changing speed. Chain arrived, but I'll have to look at the clutch first, there is no feel at the lever. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
_Iain_ |
![](images/spacer.gif) _Iain_ Banned
![](images/avatars/125235041853eb29080a4d6.jpg)
Joined: 01 Feb 2012 Karma : ![Appaling Karma](/images/karma/black_9.gif) ![Appaling Karma](/images/karma/black_9.gif) ![Appaling Karma](/images/karma/black_9.gif) ![Appaling Karma](/images/karma/black_9.gif) ![Appaling Karma](/images/karma/black_9.gif)
Back to top |
wots |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 22:02 - 28 Jan 2014 Post subject: |
Back to top |
_Iain_ |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 22:25 - 28 Jan 2014 Post subject: |
Perhaps an aftermarket part designed to replace the original powervalve setup?
The box you link to should be mounted above the cylinder head, and has two cables that link to a pulley, which should be where that mystery component is!
Short term i'd rotate the powervalve to fully open and leave it, long term look at replacing the YPVS system on the bike - note that it appears to be missing it in the wheelie photo from the previous owner? ____________________ Please be aware that the above post may be full of complete nonsense.
Back to top |
wots |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 14:57 - 29 Jan 2014 Post subject: |
Lots of stuff arrived yesterday/today. Other things to arrive in the next few days. In theory everything to make it road legal (with some work), mostly genuine parts with some that are close enough. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
wots |
Back to top |
Fizzer Thou |
![](images/spacer.gif) Fizzer Thou World Chat Champion
![](images/avatars/5468125664e4462d8da77c.jpg)
Joined: 06 Aug 2011 Karma : ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_5.gif)
Back to top |
P. |
Back to top |
wots |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 17:21 - 30 Jan 2014 Post subject: |
Tank looks fabulous and in the right colour too, I'll definitely have that off you.
Regarding the power valve, can the whole automatic system be retrofitted, rather than just the fix it open or shut affair.
There is an american guy who has literally stripped a YZ125 and it is so easy, so I might strip clean and powder coat. I wasn't going to do this, because a) I'm impatient and b) I didn't think I'd do a good enough job. It will look fabulous when finished though. Iain's CR hasn't taken that much to do.
Also, I have a swing arm with disc setup (and shortly to have another too) including everything back to the master cylinder and possibly pedal. Would you (could you) fit this or leave as is, on a bike like this I think the drum would be easier to maintain. However, if I changed to disc I'd have two rears with disc, so swap out to knobblies would be easy. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Back to top |
P. |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 17:27 - 30 Jan 2014 Post subject: |
I'm sure you could retrofit the disk stuff, unsure how rear caliper mounts so you might need to use the dedicated swing arm, Fizzer again is probably the guy to confirm. Bloody wizard ![Laughing](images/smiles/icon_lol.gif) |
Back to top |
Fizzer Thou |
Back to top |
wots |
Back to top |
Fizzer Thou |
Back to top |
wots |
Back to top |
Nemo |
![](images/spacer.gif) Nemo Could Be A Chat Bot
![](images/avatars/199039577355216a6da979f.jpg)
Joined: 30 Apr 2010 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_6.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 20:38 - 30 Jan 2014 Post subject: |
Late posting, still trying to get over iain touching me the whole way in the van...
Looks like you're cracking on with it, shouldn't be much longer till we see a video of it with the ktm and cr
and me siting on the side line like a pussy ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
Back to top |
wots |
Back to top |
![](/images/spider_left.gif) |
The last post was made 10 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
![](/images/spider_right.gif) |
