Worth changing the front sprocket on YBR 125?
simonjb
PostPosted: 14:43 - 01 Feb 2014    Post subject: Worth changing the front sprocket on YBR 125? Reply with quote
Hi there BCF, not a technical query as such, but still figure this is the place to post it.
The question is, is it worth changing the front sprocket on my YBR 125 from a 14t to a 13t as JT offer both? The calculations suggest about a 7-8% increase in torque. I haven't found a piece of road around here that's straight and flat enough without traffic to actually see if I can get it to the red line (which I doubt), so not sure what the top speed reduction will be.
Just want some opinions on whether it's worth it as I don't spent that much time on dual carriageways.
Current Bike: 2008 Yamaha YBR 125
PostPosted: 14:49 - 01 Feb 2014    Post subject: Re: Worth changing the front sprocket on YBR 125? Reply with quote
In some cases downgearing can actually increase top speed - if it can't top out and is at 7/10th revs at 65mph say - it may be the extra thrust at the rear wheel can overcome the air resistance because it reaches peak power at 65mph and pushes on to 70mph.
If you're changing sprockets anyway, I'd give it a go - though it probably won't be massively noticeable.
The Artist
PostPosted: 15:23 - 01 Feb 2014    Post subject: Reply with quote
Gearing is simple.
More teeth on the front > less on back = Higher top speed, less torque. You will still have a power limit so top speed may actually drop if you go too far as you won't be able reach the correct RPM range.
More teeth on rear > less on front = More torque but you will get through to top gear pretty quickly. Top speed may be reduced as you will reach redline in top gear depending how far you go.
Will be more fun to ride around town with a smaller front sprocket though.
PostPosted: 15:38 - 01 Feb 2014    Post subject: Reply with quote
Give it a go, but you're unlikely to notice much difference to performance either way.
What you will notice is that your gears are closer together and you'll be changing gear more. I went to a larger front sprocket to get the opposite effect.
bladerunner
PostPosted: 01:23 - 02 Feb 2014    Post subject: Reply with quote
I'd be tempted to go larger on the front not smaller as if your not even getting it to 65 mph then you will benefit from less gear changes. If you want to see what it's like with the lower gearing your thinking about...ride it for a day without using top gear! If you want the extra torque then drop it down a gear....really that's it! A bigger front sprocket however will allow you to use lower revs for the same speed so possible to get extra mpg or extra few mph in downhill/ tail wind situations
simonjb
PostPosted: 13:46 - 02 Feb 2014    Post subject: Reply with quote
Problem is, the YBR is underpowered, even for a 125. In the majority of situations, especially up hill or with a headwind, it'll only pull off around 55; whilst the revs will be higher with a 13t, the extra torque should pull it up to around 60. Well that's the plan anyway! For the sake of ten quid, I've decided it's worth a shot. Thanks all, will post results once I've had a chance to change it.
Edit: I don't think you can get a 15t front for the YBR, it'd be too large, if I decide I need to go the other way, I can always reduce the teeth on the rear sprocket in future.
DangerousSpot
PostPosted: 01:35 - 26 Apr 2014    Post subject: Reply with quote
Hi, I am new to this forum and this is my first post.
I have a YBR 125 2012 model and was looking into increasing the acceleration of it by changing the sprockets and I looked on the actual JT website and saw that they have a 13T front and 45T rear sprocket kit which is exactly what I need. However, they do not do sales on their website and I don't know where I can purchase it from?
Does anyone have any suggestions to where I can buy it?
Thanks
janner_10
PostPosted: 06:06 - 26 Apr 2014    Post subject: Reply with quote
Thanks
SPROCKETS
RhynoCZ
PostPosted: 07:50 - 26 Apr 2014    Post subject: Reply with quote
I wouldn't touch it, the engine is too small to benefit from that. Thumbs Up
simonjb
PostPosted: 11:00 - 28 Apr 2014    Post subject: Reply with quote
You can get them on ebay at a decent price, just make sure they are actually JT. Or you could just find other online shops.
Note from me: I tried this, and it did give me better acceleration and more torque, BUT it did noticeably reduce my top speed, and I found myself revving it higher compared to before, and hence my MPG dropped.
If you don't do any roads faster than 45 mph regularly, and you spend most time in traffic or just around town, then its worth trying out. But if you do, then its better to explore other avenues!
I've actually gone back to a 14t now, but by doing an oil change, replacing the air filter, properly cleaning and lubing the chain, and replacing the spark plug with an NGK Iridium, it's much better on the 14t.
You're better off just revving it higher by changing down a gear on hills or in headwind IMO, but I had to try it out myself first!
The last post was made 12 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.12 - MySQL Queries: 13 - Page Size: 67.4 Kb
