CB500 Performance 25kw vs 35kw Restriciton
Icon
PostPosted: 18:32 - 01 Feb 2014    Post subject: CB500 Performance 25kw vs 35kw Restriciton Reply with quote
Hi, I'm currently on the A2 licence and have a CB500 with a 25kw restrictor.
I'm wondering would I get much of an improvement in performance if I replaced it with a 35kw restrictor?
Would it increase acceleration or just top speed?
I still have a year and a half of restriction left.
RhynoCZ
PostPosted: 18:38 - 01 Feb 2014    Post subject: Reply with quote
Both, not much though. Thumbs Up
Icon
PostPosted: 18:49 - 01 Feb 2014    Post subject: Reply with quote
It's in theory a 40% increase in power. Would I not get more out of that?
PostPosted: 18:53 - 01 Feb 2014    Post subject: Re: CB500 Performance 25kw vs 35kw Restriciton Reply with quote
Why would you?
Even going restricted (which is barely more in reality) doesn't make a massive difference in feel of the engine.
Icon
PostPosted: 19:01 - 01 Feb 2014    Post subject: Reply with quote
I asked the same question on a CB500 forum:
https://www.cb500club.net/t2368-restricted-vs-unrestricted-performance
Are they wrong then?
PostPosted: 19:13 - 01 Feb 2014    Post subject: Reply with quote
I wouldn't trust the opinions of people that don't comment when you ask them to 'cum' on' Laughing.
I had ridden restricted and unrestricted 500s and there generally doesn't feel like there is much in it, as I've said.
I don't see comments from people having ridden both there.
As one person did mention, their stock bike makes under the required power when going by rwhp. That was about my expectation - a restriction really shouldn't do much, even if it is going by crank hp.
Icon
PostPosted: 19:24 - 01 Feb 2014    Post subject: Reply with quote
So restriction mainly effects top speed and there's little difference in acceleration?
PostPosted: 19:42 - 01 Feb 2014    Post subject: Re: CB500 Performance 25kw vs 35kw Restriciton Reply with quote
Do you? How would do you know?
Do you have a piece of paper saying so?
If so, then you'd still have a piece of paper saying that it's making 25kW even if it turns out that it's not restricted, or if the restrictor washers were to... fall out.
If you don't have the piece of paper, then what makes you think that it's restricted, and how would you convince an insurer or copper of that?
See what I'm saying?
The piece of paper is the important thing, just don't get caught doing 120 on it.
Icon
PostPosted: 19:55 - 01 Feb 2014    Post subject: Re: CB500 Performance 25kw vs 35kw Restriciton Reply with quote
I have the restriction cert.
Do many people on the A2 licence ride unrestricted bikes?
Would I get away with it?
PostPosted: 20:23 - 01 Feb 2014    Post subject: Reply with quote
Little difference in both I'd say, though I haven't tried a top speed run - but you don't have much power and as the speed goes up an unfaired bike really isn't going to do to well. You're not talking many mph extra.
You may notice more of a difference, as I came from riding bikes with 3x the power. However 500cc owners seem to confirm.
As the people in your other thread noted - it's quite likely your bike makes under the power without the restricters in.
PostPosted: 21:05 - 01 Feb 2014    Post subject: Re: CB500 Performance 25kw vs 35kw Restriciton Reply with quote
Seven-twelve million. Or maybe three.
Are you an adult? Then make your own decision.
clancy
PostPosted: 21:18 - 01 Feb 2014    Post subject: Reply with quote
My old rvf was restricted then derestricted, made sod all difference apart from the last 1-2k of revs pulled better derestricted, added about 20 mph on top speed
All in all, unless belting It down a dual carriageway it made very little difference. I'd say yours would probably be the same as the both not very powerful bikes in the first place
KLX 300r
PostPosted: 21:27 - 01 Feb 2014    Post subject: Reply with quote
It will affect both acceleration and top speed, if you use the revs.
If the washer type then they just restrict air flow after the carb, in much the same way as the throttle does. However at lower revs you are getting a minimal benefit from opening the throttle the last bit extra. At lower revs the difference from the restrictor will be minimal, with the difference going up as revs increase. If you just use large throttle openings and change gear early the gain will be pretty much non existent until you are having to use the revs as you can't change up any further (ie, top speed). Use the revs properly, changing up late and you will gain plenty of acceleration.
As an aside the power restriction is for 'net power output', which as best anyone can make out is crank hp. So that guy with 45hp at the rear wheel has more than that as far as the law is concerned. Given about 10% is about average loss from the crank to the rear wheel that makes about 49.5hp, over the 35kW limit.
Jason12
PostPosted: 14:55 - 20 Apr 2014    Post subject: Reply with quote
I'm currently taking my A2 test and one of my instructors is a police biker, so I asked him about restrictors and he said that it was down to the rider to prove that the bike is restricted, and not the police to prove that it's unrestricted.
Also he said it can be tested by him riding the bike and seeing if the revs "bounce back" before it redlines. I may not have quoted him perfectly but he definitely knows what he's talking about.
PostPosted: 15:01 - 20 Apr 2014    Post subject: Reply with quote
Nope, no he doesn't.
I would love to see him do his 'test' and try and make it stand up in court. Plenty of restricted bikes will rev out.
Also, he seems to have a basic misunderstanding of 'innocent until proven guilty'.
Not sure he can be a 'police biker' AND an A2 instructor.
Maybe he WAS a police biker and got kicked out for not having a clue on the basics of his job?
smegballs
PostPosted: 15:02 - 20 Apr 2014    Post subject: Reply with quote
Jason12 wrote:
down to the rider to prove that the bike is restricted, and not the police to prove that it's unrestricted. .
I'd like to see that put into practice in a court of law.
PostPosted: 15:52 - 20 Apr 2014    Post subject: Reply with quote
I bet he's in the SAS as well, he's just not allowed to talk about it. Shhh!
moonzoomer
PostPosted: 17:01 - 20 Apr 2014    Post subject: Reply with quote
I doubt if a CB500 makes much more than 35 kw to start with other than very optimistic advertising by Mr Honda.
RhynoCZ
PostPosted: 20:40 - 20 Apr 2014    Post subject: Reply with quote
Honda says 44kw, so there is like 33kw on the back wheel. Thumbs Up
clancy
PostPosted: 21:54 - 20 Apr 2014    Post subject: Reply with quote
My rvf would max out on the revs when it was restricted. His test is invalid and he doesn't know what he's on about
If the police wanted to prosecute it's up to them to prove it's restricted....otherwise they have no evidence
Just take them out, no one will know. I don't personally know of anyone who had their bike checked. Nearly everyone I knew on restricted liscences did not have their restrictions in after a few months
KLX 300r
moonzoomer
PostPosted: 22:05 - 21 Apr 2014    Post subject: Reply with quote
I was able to draw a direct comparison between an old 1984 VT500E with 27 k on the clock and a very fresh low mileage CB500 only a few weeks ago, the 30 year old VT500 was the quicker bike through the gears and top end but in the real world only made around 28-30 Kw and had a lot more mid range grunt than the CB500 despite loosing a lot of power via the shaft drive, I often wonder if modern Japanese horses are only little ponies really.
hmmmnz
PostPosted: 00:35 - 22 Apr 2014    Post subject: Reply with quote
i had a 33hp restricted gs500, i left it in there for a couple of weeks until i figured out how to de-restrict it,
it didnt feel like much more power to me when it was de-restricted,
maybe 10mph on the very top, and possibly a little more responsive,
but that could have been in my head mixed with the large dose of snake oil i'd taken in the morning,
who knows,
remove them and go for a ride and see, its not exactly a complicated procedure
the humans are dead
I kick arse for the lord
moonzoomer
PostPosted: 01:14 - 22 Apr 2014    Post subject: Reply with quote
who knows,
a GS 500 would not make 33 hp at the crank let alone the back wheel (24 bhp on a good day ) you need to tune not restrict.
hmmmnz
PostPosted: 10:09 - 22 Apr 2014    Post subject: Reply with quote
they make around 40 hp at the wheel
and with decent jetting around 45,
a bad tune will get you 30 at the wheel
facts: check em' fool
https://www.gs500.net/gallery/data/500/AnniesGS500dynoRun.jpg https://eriswerks.com/wp-content/uploads/2012/09/DYNO-Results.jpg
an old rugged non tuned gs https://i171.photobucket.com/albums/u316/starshooter10/1990%20GS500/IMG_0029.jpg stock gs https://sites.google.com/site/aaronjosephwar/_/rsrc/1218597273619/Home/gs500/-modifications/--drilled-exhaust---6182008/dyno2.jpg?height=540&width=840
the humans are dead
moonzoomer
PostPosted: 19:52 - 22 Apr 2014    Post subject: Reply with quote
So a tuned 500cc suzuki twin makes 43 bhp,, V&H exhaust, K&N filter and a dynojet kit, big WOW Laughing should I be impressed?
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 132.2 Kb
