Kawasaki GT550 bearing shell/bushing
sawarduk
PostPosted: 19:02 - 03 Feb 2014    Post subject: Kawasaki GT550 bearing shell/bushing Reply with quote
Hello,
I’m currently rebuilding the engine on my Kawasaki GT550 (1991 Z550 G7 I think), as it was knocking. Hopefully I've found the issue, looks like the shell bearings on the connecting rods have been starved of oil. All eight look like this:
https://imageshack.com/a/img812/1203/d6p8.jpg
I've had a search around the internet for some replacements but can’t find anywhere that supplies them. I have found them here and here, although at €10 each, it’s bit steep.
Can anyone recommend a cheaper solution?
OEM Number: 13034-1067
Product Number: 130341067
Cheers!
The Artist
PostPosted: 19:05 - 03 Feb 2014    Post subject: Reply with quote
No help but jesus, they look like they were about to totally give way. How long had it been running bad?
temeluchus
PostPosted: 19:32 - 03 Feb 2014    Post subject: Reply with quote
you might get lucky with a bearing factor, but for such a critical component I would be wary not using OEM parts.
sawarduk
PostPosted: 21:05 - 03 Feb 2014    Post subject: Reply with quote
I bought the bike for £200 with understanding that there was a knocking. I can only assume a previous owner has neglected to put oil in it. It's my first project, so abit of fun and a learning curve.
Thanks for the tips guys, I'll be sure to look up Partzilla and bearing factor option.
andys675
PostPosted: 21:56 - 03 Feb 2014    Post subject: Reply with quote
ask for a discount from your local kawasaki dealer? you could get 10% off if you ask
only ones I can find for sale on ebay are 17 euros each
you have to watch stuff from the US as it seems cheap until they hit you with import duty, plus the std post office fee to take the import duty
Paddy Blake
PostPosted: 22:30 - 03 Feb 2014    Post subject: Reply with quote
Is the crankshaft worn as well.?
How are the main bearings.?
Do you know how to Check the bearing sizes.?
sawarduk
PostPosted: 23:59 - 03 Feb 2014    Post subject: Reply with quote
I don't know how to check the bearing sizes, is this something I can do?
I've taken a few more pictures to hopefully give a better idea. I can see the 'notches?' on the some of the shells have sheared off, leading me to believe the shells have slipped too.
https://imagizer.imageshack.us/v2/320x240q90/843/gk64.jpg
https://imagizer.imageshack.us/v2/320x240q90/607/drwk.jpg
https://imagizer.imageshack.us/v2/320x240q90/199/h77n.jpg
I've found a set of shells and rods for Kawasaki GPZ 550, as far as I can see these are the same parts used on the gt550, unless anyone can tell me otherwise?
Paddy Blake
PostPosted: 01:04 - 04 Feb 2014    Post subject: Reply with quote
Don't by anything until you have a manual.
Each conrod is matched to the crank with the right size shell bearing.
You can't just take them from another engine and swop them over to your crank or just order bearings and put them in.
Paddy Blake
PostPosted: 01:17 - 04 Feb 2014    Post subject: Reply with quote
Also the oil going to the main bearings gets there the same root as the big end so they will need to be checked.
It would be worth thinking about getting an engine if you can as the cost of parts and gaskets will run up.
ZRX61
Victor Meldrew
PostPosted: 07:26 - 04 Feb 2014    Post subject: Reply with quote
Do you own a micrometer?.. & can you read one?
They're not one night stands, they're auditions.
DMCpro
PostPosted: 10:46 - 04 Feb 2014    Post subject: Reply with quote
You probably need to measure bearing clearance using plastigauge
You will probably need a manual if you want to get it right also you might be able to download one
Honda CB-1, TS125X
VW Golf Estate
andys675
PostPosted: 16:40 - 04 Feb 2014    Post subject: Reply with quote
manual and plastigauge time
you may need a reconditioned crank, but adding to a recon crank new gaskets, then look at your camshaft journals, pistons / rings / bores, and the time required to build all that, sorry to say a used engine might be cheaper in the long run
davebike
PostPosted: 16:48 - 04 Feb 2014    Post subject: Reply with quote
From Kawasaki 7.98 + VAT each
I say used engine is a better bet
These days it is seldom financially viable to rebuild engines
I look really closely at that crank
Dave
Dave
NC750Xdct + others at work !
[email protected]
sawarduk
PostPosted: 14:35 - 07 Feb 2014    Post subject: Reply with quote
Just a little up date: thanks for all the comments so far.
I found the correct OEM parts on a site called Full Throttle Projects for £3.50 each. Way cheaper than anywhere else! So I'm just awaiting for them to arrive and the engine can start going back together.
Ed Case
PostPosted: 21:52 - 07 Feb 2014    Post subject: Reply with quote
Looking at the state of that 'shell' the corresponding crank journal has to be in poor shape, The bearing clearances the Japs use are measured in Microns and much off the original specifications and any 'repairs' that you make could be very short lived. I'd be ringing around the local breakers for availability and prices of another complete 'lump'.
Paddy Blake
PostPosted: 01:57 - 08 Feb 2014    Post subject: Reply with quote
Did you know how to match a conrod to crank before ordering parts.?
Have you read advice in this thread.?
The last post was made 12 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 95.92 Kb
