Ktm 300 stalling
rhys1005
PostPosted: 10:59 - 04 Feb 2014    Post subject: Ktm 300 stalling Reply with quote
Hi BCF
Took my ktm 300 green laning sunday with another member off here and it preformed well (not like it'd matter - I'm not exactly the most skilled rider Embarassed ) apart from the fact as soon as I let the clutch out it bike would stall every single time and even sometimes if I was riding slow on technical stuff in first gear. It was really frustrating and meant I had to keep it in first gear to prevent it from stalling.. Leading to me hitting the powerband when it wasn't exactly wanted Laughing
Is this just a 2 stroke thing or is it a problem with the bike?
PostPosted: 14:01 - 04 Feb 2014    Post subject: Reply with quote
Were you actually revving it? My 200 likes to have some decent throttle and slipping of clutch Thumbs Up
rhys1005
PostPosted: 15:53 - 04 Feb 2014    Post subject: Reply with quote
Trying to but this was on steep downhills where eve rolling was a bit too quick for me. Can the 2 stroke enduros not rely on the little engine braking they have? Even accelerating if the revs were low enough it would stall.
Could a loose chain cause this? My chain is very loose at the moment, maybe not having enough tension means at low rpm the engine isn't under enough load if that makes sense? Or maybe the idle/mixture? Idk maybe it is the nature of the bike Confused
Dischord
PostPosted: 16:01 - 04 Feb 2014    Post subject: Reply with quote
You will know if you have a loose chain as you will hear chainslap - a kind of knocking/tapping noise when accelerating from low RPM. It's really common on KTMs and it's important not to overtighten the chain. With the amount of suspension travel these have you can easily damage the countershaft. Just see how tight your chain gets when you sit on the bike to see the effect Thumbs Up
I don't think your problem is a loose chain though, I would say it is fueling, the 300 should have more than enough torque to chug off from really low speeds in most gears.
I would start by removing the float bowl off the carb and thoroughly cleaning the main and pilot jets. Does the bike idle ok? and if you rev it fast off idle does it bog down at all?
2012 KTM EXC 250
PostPosted: 16:21 - 04 Feb 2014    Post subject: Reply with quote
Engine braking = closed throttle = no lube.
PostPosted: 18:23 - 04 Feb 2014    Post subject: Reply with quote
It sounds like Paddy's 200 does need a bit of poking.
My 200 didn't pull that well at low revs, but unless you were in top gear, it still pulled smoothly.
The 300 should pull VERY well from low revs. I'd say it was better than my Husaberg 501 and definitely better than the high-geared KTM 690 (but that engine started as a road bike engine.)
Downhill on a competition bike I tend to pull the clutch, or make sure it gets an occasional blip to ensure it gets some oil.
First thing I'd do is clean the carb.
Then I'd consider whipping the head off and seeing what that looks like - very easy to do on a smoker.
stevo as b4
PostPosted: 18:56 - 04 Feb 2014    Post subject: Reply with quote
Id think a 300cc 2smoker that's properly jetted and set up, and running on ok fuel (not stale or got water in it from standing etc) should pull like a tractor from low rpm.
Whats your idle speed set to? and has anyone ever played with the pilot jet or airscrew. I'd be checking all the carb settings and the float height etc, and give it another go.
Really big 2strokes generally have got not much bottom end or top end power, but a mountain in the middle, but I'd not expect a KTM300 to be that extreme like say an old open class MX'er.
Fladdem
PostPosted: 19:00 - 04 Feb 2014    Post subject: Reply with quote
I've rode a TY250, OK not a high strung enduro bike, an old school trials bike, but that thing pulled better than my TTR does. I should imagine other people would have a better idea, but I would guess jetting too, try a plug check.
I wish I'd made it on sunday. Sad
rhys1005
PostPosted: 22:39 - 04 Feb 2014    Post subject: Reply with quote
It idles fine, infact really well in neutral and on the road it feels like it has a decent bit of low down power. But say for example if I was rolling downhill with the cluth out, it would stall very easy.. Even without pressing the rear/front brakes.
I will mess with the mixture settings and idle tomorrow aswell as cleaning the float out etc and see if it helps. I adjusted the 'power valve spring thing' today as it was screwed all the way out, I screwed it all the way in and noticed the front felt a lot lighter when pinning it.. Not sure exactly what it did though but it was fun Very Happy
Reason I noticed it so much aswell is because I heard even from just idling it can move along nicely Shocked kinda why I bought the bike.. Oops..
PostPosted: 00:23 - 05 Feb 2014    Post subject: Reply with quote
Oh; don't go down long hills with the throttle off - you're also starving the crank and piston of oil.
This is the main disadvantage for 2 strokes to my mind - but well made up for by being lighter, more flicable and so on.
It may be that the revs are being forced too low if you're in a highish gear.
Fizzer Thou
PostPosted: 10:44 - 05 Feb 2014    Post subject: Reply with quote
I have seen it mentioned on https://www.ktmforum.co.uk/forum.php about how a frayed reed valve can cause all sorts of fuelling problems - and about how the OEM plug cap gives no end of ignition problems.
On my 450EXC I replaced the OEM plug cap with one from NGK and have never had an ignition problem again,unlike several people that I know with similar bikes.Their starting and running issues were solved by replacing the plug caps with the better quality NGK item Thumbs Up
Always have a 'Plan B'
The last post was made 12 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 75.04 Kb
