Adjusting the chain on a TZR125
Bomberman
PostPosted: 02:05 - 31 Dec 2004    Post subject: Adjusting the chain on a TZR125 Reply with quote
Hey all,
Right. Bike was sounding really clanky when changing down gears, and I decided its a loose chain. So I checked it, and my lord it was looooose Rolling Eyes
So out comes the Haynes. Seems straight forward enough, loosen spindle nut, adjust adjusters. Fine. Except I cannot move the damn spindle nut. At all Evil or Very Mad Am I just doing it wrong? Is there a trick to it? I swear I was going to lift the bike up before it moved Thumbs Down Or are they really just that stiff and need real work to get loose?
Thanks in advance Very Happy
satans_BIG_helper
PostPosted: 02:48 - 31 Dec 2004    Post subject: Reply with quote
A trick i found was to try and tighten the nut just a touch before u attempt to undo it sometimes just needs the little bit of tightening to free any cr@p in the threads... or alternatively get a bit of bar that fits over ur spanner/socket and use that for leverage usually works..
mchaggis
PostPosted: 03:07 - 31 Dec 2004    Post subject: Reply with quote
As a last resort, get a large ring spanner, and give it a tap or two with a hammer. Alternatively, you just need a spanner with enough length to get the leverage. If it can fit, putting the spanner so that its shaft is pointing forwards will push the bike into the ground when you undo it.
It's likely that the road salt and general crap and corruption about at this time of year has helped everything seize up. I'm sure it'll be interesting when it comes to adjusting the chain on mine. Embarassed
On an attached topic, what's the best way to free up stiff links? I'm vaguely assuming it's a case of cleaning and liberally oiling?
I must not be a troll...
Mmmm, Guinness
PostPosted: 10:35 - 31 Dec 2004    Post subject: Reply with quote
Also check that there is not a split pin in there, possibly a bit squashed and difficult to see.
Bomberman
PostPosted: 12:49 - 31 Dec 2004    Post subject: Reply with quote
Heh, no I saw that and pulled it out Very Happy So the consensus seems that its just a stiff bastard eh? Fair D. I'll give it a proper go in a bit. Cheers all Very Happy
PostPosted: 13:01 - 31 Dec 2004    Post subject: Reply with quote
Well, spray a load of WD40 round the nut a leave it to stand for a bit.
Bomberman
PostPosted: 15:51 - 31 Dec 2004    Post subject: Reply with quote
Well, its done Thumbs Up Took a 3 foot length of iron pole (from an old car jack) on the end of the ratchet but it went in the end Very Happy And what a difference it made Shocked The bike is so much more responsive Thumbs Up, as I suppose you'd expect, but I was surprised how much. And changing gear no longer feels mushy and clanky. All good, and cheers all for the advice and suggestions Thumbs Up Very Happy
The last post was made 21 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 56.1 Kb
