scalextric cars
mic
PostPosted: 20:03 - 04 Feb 2014    Post subject: scalextric cars Reply with quote
Ello
Picked up an old scalextric set today. Been stored for a few years. Took the power bit out and some track and went to see if the cars still work.
First car - just put the front bit in the groove, wheels spun for a few seconds then stopped. The motor whirs but wheels no longer move
2nd car - wheels never spun but can hear motor spinning
3rd car - has wires disconnected so will need opening and fettling with
Assume it's gonna be a quick fix, anyone fiddled with em before?
zzr600
Shaft
PostPosted: 20:41 - 04 Feb 2014    Post subject: Re: scalextric cars Reply with quote
mic wrote:
Ello
Yep.
Back in my youth, I used to sell them, fix them, tune them and scratch build them.
You say you can hear the motor, definitely spinning or humming?
They are incredibly simple, just a motor with a plastic pinion on the output spindle, meshing into a plastic gear on the axle.
If the motor is turning but the wheels aren't, then the pinion and gear aren't meshing, either because the pinion has worn/broken up or the axle has dislodged.
Good model shops that stock slot racing sets should sell you pinions and gears, or the net will probably sort you out.
If the motor is humming, it's probably jammed up with dust and fluff; replacement motors are cheap, or you can strip them down and rebuild them with new brushes.
metalangel
PostPosted: 22:25 - 04 Feb 2014    Post subject: Reply with quote
Is there any advantage to the way Scalextric models use brushes for collection vs the Aurora AFX set I also had that used sprung shoes/rails?
Something I always wondered about.
Lord Percy
PostPosted: 23:01 - 04 Feb 2014    Post subject: Reply with quote
Sounds like both did exactly the same job? Just a loose connection held together by a form of material elasticity/stiffness.
In the brushes it'll be a Young modulus jobby, in the springs it'll be a spring modulus jobby. Generally the same thing under different names. Same end result - material deformed but wants to return to its original shape, hence connections stay pushed against track.
Yay science Very Happy .
Shaft
PostPosted: 23:44 - 04 Feb 2014    Post subject: Reply with quote
As LP says, different design, same result, except braids don't have tiny springs that can pop out, never to be seen again!
The main difference with AF/X was the introduction of 'Magnatraction', where the motor magnets were exposed, causing them grip the track and leading to things like loops and very high speed banking.
In practice, this meant you could drive them at full throttle everywhere and it tended to take all the skill out of racing.
Edit: Thinking back, there was an advantage to braids; shoes had a tendancy to build up of a layer of carbon, so you had to clean them regularly, otherwise the cars went slower.
Braids just wore away, so you bent them down a bit more and carried on.
metalangel
PostPosted: 00:15 - 05 Feb 2014    Post subject: Reply with quote
I don't know when Magnatraction came out, but both sets were about 1979 (indeed, I still have the catalog that came with the Scalextric which has the March Ford six-wheeler among other classics) presumably bought by my dad realizing he was going to be a dad before he was 30. Laughing
Now that you mention it, there was some kind of cleaning brush thing for the AFX cars and I do remember a spring sproinging out and escaping, but generally the AFX stuff worked better than the bigger, heavier Scalextric cars as the braids would tend to become flattened against the bottom of the car and no longer contact the track.
Shaft
PostPosted: 00:26 - 05 Feb 2014    Post subject: Reply with quote
IIRC Magnatraction was introduced in 1975.
This is going to sound terribly snobbish, but Aurora was never considered to be a serious contender, if you were properly into slot racing.
The progression was Scalextric, tuned Scalextric, then scratch built, with vacformed bodies, brass plate chassis, foam tyres and home made controllers.
groovylee
PostPosted: 07:40 - 05 Feb 2014    Post subject: Reply with quote
As already said, pinions on the first two cars. I got some from fleabay for a bout £5 for two Thumbs Up just count the number of teeth and buy accordingly.
Cheers,
Lee
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
mudcow007
PostPosted: 08:42 - 05 Feb 2014    Post subject: Reply with quote
i had a afx track, i wrecked it though putting washing up liquid on the tyres of the cars so i could do power slides trough the corners
oooh just remembered i had a Scalextric too, porsche turbo challenge or something
mic
PostPosted: 09:08 - 05 Feb 2014    Post subject: Reply with quote
had a look. both cars the same under the body. you can hear the motor doing something but it doesnt turn the prop with the white gear. lights dont work either but assume that it needs to be powering the cars to work.
from Le Mans 24 hour
https://i547.photobucket.com/albums/hh470/mic8310/Mobile%20Uploads/IMG_00001293_zps07cb72e2.jpg
zzr600
metalangel
PostPosted: 14:34 - 05 Feb 2014    Post subject: Reply with quote
I agree. The AFX set was fine for me as a little kid (if I recall we had two Corvette C1s, a C4 which fishtailed like crazy and a 70s Camaro) while I was only told about and allowed to play with the Scalextric when I was older.
Apart from a crappy MASK set, never had any other slot cars, they were too expensive and I preferred trains anyway.
Poseidon
PostPosted: 16:50 - 05 Feb 2014    Post subject: Reply with quote
My formula1 scalextric cars used to eat the little white cogs. They'd sort of split on the shaft, but look okay to the naked eye. The split would prevent the motor turning. They were 5p to replace (mid to late 90s) and I used to buy a quids worth at a time.
This'un...
https://www.bikechatforums.com/files/car.jpg
1977 Honda CG125
mic
PostPosted: 17:05 - 05 Feb 2014    Post subject: Reply with quote
Ok cheers will see about finding replacement and see how it goes
zzr600
Poseidon
PostPosted: 17:10 - 05 Feb 2014    Post subject: Reply with quote
Take the little cog off and see if the motor spins freely. Saves ordering a replacement incase it isn't that
1977 Honda CG125
andys675
PostPosted: 20:32 - 05 Feb 2014    Post subject: Reply with quote
as a kid I had handed down from a neighbour a shit load of track and those red cars with the removeable heads that are worth a fortune now, god knows what happened to them afterwards, they must have been from 1970....
Still got a more modern set on top of the wardrobe, old shape mini's with green track Thumbs Up
Wonko The Sane
PostPosted: 21:16 - 05 Feb 2014    Post subject: Reply with quote
I had those cars as a kid,
the porsche was a bit problematic.
headlights should be on when running, rear lights are brake lights (that's what the capacitors are for) and come on when the power cuts off.
I remember the chassis being different on the jag and the porsche tho.
The last post was made 12 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 95.12 Kb
