Tire pressures do I need to increase for modern tires?
sidewinder
PostPosted: 15:41 - 06 Feb 2014    Post subject: Tire pressures do I need to increase for modern tires? Reply with quote
Been having a discussion again with a fellow biker in work and something interesting was discussed.when my bike was new the recommended pressures were front 29 psi and rear 33 psi.my buddy said tire technology was not as good as it is now newer tires have a slightly softer compounds.so I was told to increase my pressures by 2-3 psi to compensate for this.now is there any truth in this and should I increase them or not? I don't see any need but some of what he said made sense Very Happy
Thank you
PostPosted: 15:46 - 06 Feb 2014    Post subject: Reply with quote
I would say no. There have been massive improvements in the tyre compound, tread etc but not any that would make any difference to the amount of air needed for your bike. But I am not knowledgeable about such things.
sidewinder
PostPosted: 15:50 - 06 Feb 2014    Post subject: Reply with quote
I have no clue now getting confused on this one need a tire expert Very Happy
iooi
PostPosted: 15:52 - 06 Feb 2014    Post subject: Reply with quote
Take a trip to tyre manufactures site and see what they recommend.....
But many of us do play around with PSI to find something that suits our riding style better.
sabian92
PostPosted: 16:08 - 06 Feb 2014    Post subject: Reply with quote
Most tyres recommend higher pressures if your a fat bugger but aside from that you should be fine. The YBR manual recommends 29 front/rear for less than 90KGS of load and 29/41 for over that (up to the maximum which is 200KGS IIRC).
I've run the same pressure on all my sports based bikes, 36/42.
125s usually 31/30.
It is like OCD to me Sad
WD Forte
PostPosted: 16:37 - 06 Feb 2014    Post subject: Reply with quote
mmm, it depends
What bike, what tyres, load, how you ride etc
As said. check specs and experiment.
I find slightly higher pressures suits me
bikers smell of wee
davebike
Not knowing the bike /tyres you fitted I say up the pressures
I find as tyre s move on and improve they work better if they maintain there shape
Most older bikes fitted with more modern tyres need a little more pressure
Lower pressure more total grip but less predictable and tends to snap from grip to slide Steering tends to be heavy
Hight pressure slightly less total grip but more predictable, steering tends to be lighter
Watch out converting old inch size tyre (3.50 etc) to modern MM sizes (90/90) as some all conversion table give the largest size of the options and can give poor handling slow steering and tank slapping wobbles
Dave
Dave
NC750Xdct + others at work !
[email protected]
davebike
PostPosted: 16:40 - 06 Feb 2014    Post subject: Reply with quote
Dave
Dave
[email protected]
daverave999
PostPosted: 17:17 - 06 Feb 2014    Post subject: Reply with quote
I found using the tyre pressures listed on the Pirelli site for my tyres (rather than those specified in the bike manual) felt like it gave more feedback.
Given I replaced squared off tyres of unknown age at 29/36 (bike manual figures), with the same model (went from 140 to standard 130 at back) at 33/41 (tyre manufacturer's figures), I can't really comment on how the pressures have affected handling as too many variables have changed. I prefer them like this though!
2007 Versys 650 2001 Yamaha XJ600S Diversion
HT: Imagine a bike......A bike designed by way of crude polls, assembled by cretins using the finest hammers that Lidl had on offer.
sidewinder
PostPosted: 17:50 - 06 Feb 2014    Post subject: Reply with quote
Dave
The bike in question is my 1998 600 divvy running conti go's Thumbs Up
daverave999
PostPosted: 18:06 - 06 Feb 2014    Post subject: Reply with quote
The Continental website just says to use manufacturer's recommendations... Experiment a bit to see what you like?
69.9mph
PostPosted: 19:41 - 06 Feb 2014    Post subject: Reply with quote
Unless you're a septic, it's tyres not tires.
Go with the tyre or bike manufacturers recommendations as a starting point and adjust a couple of pounds at a time each way to find your personal settings.
-Matt-
PostPosted: 19:47 - 06 Feb 2014    Post subject: Reply with quote
I've always just gone with the bike manual pressures regardless of tyres. Never had any problems i'm aware of - but no idea if i'd be better off with them adjusted a bit either.
Prefer to play it safe n' boring Wink
sidewinder
PostPosted: 00:57 - 07 Feb 2014    Post subject: Reply with quote
I will just keep the tyres pressures as stated for now.and maybe have a play with them when it finally gets a drier Thumbs Up
The last post was made 12 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 84.72 Kb
