New helmet leaking from top vents (even when closed)
LaurenceR46
PostPosted: 20:01 - 06 Feb 2014    Post subject: New helmet leaking from top vents (even when closed) Reply with quote
Hi all,
My new Shark S900C helmet which is only a few weeks old is leaking from top vents even when they are closed.
This means raindrops get not only on the inside of my visor, annoying blocking vision but also not helping with misting (I have a pinlock). It also ends up on my nose and all over the sun shade. The vents are quite large compared to my last Shark Vision R, but hey people do ride in the rain!!
I have tested it in the shower and it doesn't appear to be leaking from the visor seal.
Is this acceptable? I don't think it is but I thought I'd ask on here first.
Pigeon
PostPosted: 20:10 - 06 Feb 2014    Post subject: Reply with quote
tl;dr Have you tried using the chin deflector for you lid? Assuming there is one.
Are you 100% sure its the vents?
Reason I ask is because my Shoei does the same thing. I can put the lid on inside/under cover, leave the visor closed except maybe putting it on the 2mm open notch. All vents closed. Ride around in the rain and after 30mins the inside of the visor has many little rain droplets.
After 2.5 years of wobbling about and ignoring it, I sat down and tried to figure out why my cheaper £90 Nolan lid from 20yrs ago never leaked. The only difference I could see was the Nolan had a chin curtain / wind deflector fixed in place.
Dug out the Shoei chin deflector attachment, stuck it on and suddenly no droplets of rain inside the visor. Smile
LaurenceR46
PostPosted: 20:13 - 06 Feb 2014    Post subject: Reply with quote
Thanks for your reply.
I have tried both a curtain style one which my last helmet had and the tiny mesh one which is included with the helmet.
I am using a shower head and even if I just direct it into the top vents it flows inside around to the top of the visor area where the flip down sun shade is.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:20 - 06 Feb 2014    Post subject: Reply with quote
Stick some electricianss tape over the vents...
Triumph Sprint ST 1050
LaurenceR46
PostPosted: 20:37 - 08 Feb 2014    Post subject: Reply with quote
Not so sure about that with a brand new helmet?? And even if I was out in the sun with no tape and there was a sudden rain shower I'd get wet...
Has anyone else got this helmet?
PostPosted: 20:39 - 08 Feb 2014    Post subject: Reply with quote
Take it back and ask where you got it from.
-Matt-
PostPosted: 21:06 - 08 Feb 2014    Post subject: Reply with quote
Take it back for a refund - a new helmet shouldn't be leaking like that. If theres no external marks and damage and the interior padding etc isn't damaged I can't see them being able to refuse easily.
Rogue_Shadow
PostPosted: 21:52 - 08 Feb 2014    Post subject: Reply with quote
I have a Caberg Ego
https://www.twowheel.co.uk/images/detailed/12/caberg-ego-vented-helmet-black-4.jpg
It's got a fecking sunroof & still hasn't leaked Laughing
Take it back Thumbs Up
Suntan Sid
PostPosted: 22:01 - 08 Feb 2014    Post subject: Reply with quote
My Shark lid is exactly the same, leaks through the top air vent!
Gaffer tape for the street racer look! Mr. Green
-Matt-
PostPosted: 22:06 - 08 Feb 2014    Post subject: Reply with quote
Good for cheese-grating careless flys to dust Razz
Ariel Badger
PostPosted: 23:49 - 08 Feb 2014    Post subject: Reply with quote
Rogue_Shadow wrote:
I have a Caberg Ego
Does having a huge square hole in your helmet mean the top of your head is not protected in the case of an off? Does it carry a Gold ACU sticker?
Dave70
PostPosted: 00:56 - 09 Feb 2014    Post subject: Reply with quote
Hi.
I have the exact same lid and have done since April last year. I've never had the problem you describe or any other problem with it tbh. I ride practically every day, come rain or shine and have ridden in some very heavy downpours.
Are you certain that it's not coming in through a gap in the visor? I only ask, as my original visor got a little warped in the summer, through hanging around in some pretty high temperatures, which left it not sealing properly.
I replaced it with a new visor and it has been perfect.
Maybe your one has some sort of fault. I would certainly get in touch with Shark and see what they recommend/say.
Keep us posted, as I'd be interested in what their customer service is like. Thumbs Up
LaurenceR46
PostPosted: 11:48 - 09 Feb 2014    Post subject: Reply with quote
Dave70 wrote:
Hi.
Cheers guys
Is yours the S900C? I understand the S900 had different vents which has been around longer.
Well it seems to be making a seal around the visor but who knows what is happening on the bike. I understand a shower head isn't the same as actually riding. I have tried bending out the seals around the visor to give a better seal as well.
I'd be very happy with the lid if it didn't leak - perhaps I will ask for another.
It's happened since it came out of the box - 2nd day of ownership, trust me no high temps have happened around here Sad haha...
Dave70
PostPosted: 12:00 - 09 Feb 2014    Post subject: Reply with quote
^^^Yep...mine's the S900C, the one with the air pump built in.
I'd say that it sounds as though there is some sort of fault if yours is letting in water. Take it back and exchange it for another.
LaurenceR46
PostPosted: 12:57 - 09 Feb 2014    Post subject: Reply with quote
Thank you, that's the same one. I'll ask for a replacement first of all.
Thanks all for your help - I'll update on how it goes.
Clanger
Stirrer
PostPosted: 15:28 - 09 Feb 2014    Post subject: Re: New helmet leaking from top vents (even when closed) Reply with quote
Dig out the receipt and take it back and complain. Get your money back and go and get yourself another lid. Cool
johnsmith222
PostPosted: 15:41 - 09 Feb 2014    Post subject: Reply with quote
I won't buy a lid with an internal sunvisor for this reason.
It's probbably very safe, but the space taken up by the sun visor had to come out of somewhere, and the only thing I can see to chop away is the EPS liner. Would rather have it that bit thicker! Same reaon I dont use flippy uppy things unless its the loan lid & i'm popping a few doors up the road for a bulb. I cant see that adding a hinge is going to help saftey.
Bleh. Need to get with the times Rolling Eyes
I agree with you here. I think simple full face with a double d ring strap is best. I've crashed in a caberg flip front before, and although it held out ok, I don't want to risk a flip front again.
Wonko The Sane
PostPosted: 21:56 - 09 Feb 2014    Post subject: Re: New helmet leaking from top vents (even when closed) Reply with quote
No, it's not acceptable to wear a helmet in the shower.
On a serious note, my Shark helmet's visor hadn't gone on quite right when I first put it back on after fitting the pinlock, you have tried taking the helmet off and putting it back on again?
LaurenceR46
PostPosted: 14:28 - 30 Apr 2014    Post subject: Reply with quote
Whoops, I said I'd update this on how it goes.
Well I took it back to the shop who then sent it off back to Shark to be repaired. They sent it back with a helpful note saying not to have the vents open in the rain (duh) and that they have gave it a full service. They also seem to have buggered the pinlock which never sealed again so I went back to the shop who were very helpful and gave me a new visor/pinlock which works great.
Well, after using it in the rain - no difference I have noticed small drops appearing over the inside of the visor - very annoying but not too bad, but when you do a lifesaver above 30mph that's when the floodgates open! It is so bad I ended up riding with the visor up, the inside of the helmet was soaked all over and the visor. After looking at the helmet and comparing it to my last one I can see that there is no side sealing for the visor, you know the little rubber bead. This means that when you do a lifesaver all the water comes flying in from all around the visor to inside of the visor.
Not happy... Poor design no repair is going to fix that.
Yamaha R6 (R46) Rossi Replica Edition
MuffinMenace
PostPosted: 14:39 - 30 Apr 2014    Post subject: Reply with quote
Take it back again and explain it's still not fixed, if the goods aren't up to standard (and lets face it a leaking helmet is not up to UK standards) then ask for a full refund.
'96 DC2 & K5 650 Blandit
Dave70
Just looked at my lid and youre correct about the lack of rubber beading at the sides but, I have to say that I have never encountered the problems you're having with it leaking. It would appear that there is an issue with your lid as it is. Confused I really don't know what to suggest. Sad
CaNsA
PostPosted: 14:50 - 30 Apr 2014    Post subject: Reply with quote
Rogue_Shadow wrote:
I have a Caberg Ego
Has that got a slidey type bit that goes over the top vents?
LaurenceR46
PostPosted: 14:54 - 30 Apr 2014    Post subject: Reply with quote
So you have no water come in when doing lifesavers at say 30-40mph+? Very weird because I get so much rain coming in - and the visor has been changed too.
I even bought a windjammer because of the really terrible helmet noise this helmet also suffers from - that got rid of all of the noise and I thought it may help if by any chance the rain was coming from under the helmet but nope it has not helped.
I like the helmet now apart from the leaking but it just seems poor and as MuffinMenace says not up to UK standards because of the rain we get!!
I'll take it back and see what they recommend bloody annoying.
CaNsA it looks like it has some kind of slide on it - transparent one.
Dave70
PostPosted: 17:54 - 30 Apr 2014    Post subject: Reply with quote
No problems at all with it leaking but, then again I don't do life savers. (Joking btw) Laughing
The only issue I've had is with smalI cracks appearing around the pinlock pins after a couple of months. It happened with the first visor, so I bought a new one, along with a new pinlock and the same thing is starting to happen with that one.
Otherwise, I have found it good value for money and the best lid I own but, I can only compare it against a Nitro and a Caberg that I have used in the past.
The last post was made 12 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 134.66 Kb
