| Shaft |
 Shaft World Chat Champion
 Posted: 21:09 - 06 Feb 2014 Post subject: Which BM Boxer GS? |
Back in May last year, I was asking which Adventure bike for £2500, but my goalposts have moved, so rather than resurrect that thread, I thought a new one would be more appropriate.
Surveying my present fleet and pondering on what I use bikes for and what I would like to do with them in the future, I reckon I could cash the lot in, maybe add a bit to it and end up with one bike that would do 99% of everything I need.
Because I'm dead set on shaft drive, the BM seems to be the only choice within my budget, but which one?
I'm thinking £4-5K and given that I don't care about age, but I don't want something that's been to the moon and back, 1100, 1150 and 1200 versions all fall into the net.
Normally, the obvious thing would be to go for the most up to date version, but perhaps the older, smaller models are better?
Anyone got any thoughts on that? ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Vracktal |
 Vracktal World Chat Champion
 Posted: 22:27 - 06 Feb 2014 Post subject: |
I'd say go for an R1150GS, or early R1200GS as in my opinion they strike the balance between old and simple & new and modern best. The latest GSs are water cooled, earlier ones are much simpler oil-cooled designs. The R1200GS is not bad, but later ones weigh too much and are very reliant on electronics, and have a lot of delicate plastics which get broken if it falls over.
My advice:
Go for a non-abs model- Early BMW ABS bikes have power assist and when this breaks you lose 90% stopping power without warning. Non-ABS models have no power assist so are much safer in this regard. The R1200GS ABS system is non-power assisted, but the ABS pump is prone to failure, and costs an exorbitant amount to fix.
Check the rear wheel for lateral free play, and if you get the chance take it off and inspect the hub that it attaches to the shaft drive by- sometimes these can get cracks which over time weaken the hub until it breaks.
Engine oil is especially important on the GS as it provides all the cooling as well as lubrication. Check the filler window to make sure it's topped all the way up, all the time. Also, the filler window has been known to crack when riding, leaking all the oil out and basically buggering the engine in minutes. If the oil light comes on while riding, even blinks for a second, pull over and check that this isn't happening.
Check the shaft drive for leaks, be suspicious of any fluid in that area. Get the bike on it's centre stand and let it run in first gear, then listen for loud whining noises from the shaft- It makes a bit of noise normally, but the noise when it's knackered is loud enough to be easily noticeable. There is a natural amount of free play in the shaft drive to get used to, when you roll on in a gear there's a slight 'clunk' as all the bits of metal connect- eventually you get used to it and adapt your riding style to minimise it. Also, the shaft has a lot of rotational energy so revving the engine in neutral will rock the bike quite a lot. In gear it's not so noticeable.
Also, the GS bikes have a single-plate dry clutch, much like a car. If the clutch bites high, check the hydraulic pressure is right. If it is, the clutch is probably knackered. It's not an amazingly difficult job to replace but takes a well-tooled garage to do properly. Also, because it uses a single-plate clutch, you have to adapt your riding style slightly- try not to slip the clutch (either have it all the way out or all the way in) as this burns it up, and get into the habit of popping it into neutral and letting the clutch out when stopped at the lights instead of holding the clutch open. If looked after, the clutch will easily last into the 100k miles without issue (guy two doors down from me has an R1150R with 96k on it's first clutch still)
Both the R1150 and R1200 have catalytic converter systems fitted. On the R1150, the system is so big it also acts as a muffler, meaning the big end can on the bike is essentially superfluous. You can remove it and fit a stubby tip with pretty much no change in engine output, MPG or noise level- it's a common mod. The R1200s have a slightly smaller cat, so removing the end can does make it louder, but you can still fit a stubby tip if you don't mind it being louder. The boxer engine by default makes a pretty muted, raspy noise and as far as i've found no exhaust can make it sound sexy like other bikes.
Finally, get used to having to be a lot more careful when filtering- Those pistons & the cylinder head stick put pretty far, more so if they've got the optional crash bars fitted. Also, be prepared to take a ribbing for owning what is basically the BMW X5 of motorbikes. =P ____________________ 2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning |
| Shaft |
 Posted: 00:04 - 07 Feb 2014 Post subject: |
Thanks, that all seems like good advice.
Seeing as I spend entirely too much time playing with cars and their electronic mysteries, simple is definitely better for me, but trying to find one without ABS appears to be on a par with having a beer with Lord Lucan; can it be removed/bypassed if it screws up?
As for worrying about what other people think of my ride, I'm a bit too long in the tooth to be bothering with that crap, besides, I had a full dresser GoldWing in my early 20s, so my pipe and slippers are very comfortable by now  ____________________ Things get better with age; I'm close to being magnificent........
| Vracktal |
| Oldie |
 Oldie Brolly Dolly
| BTTD |
 BTTD World Chat Champion
| Shaft |
 Posted: 20:35 - 07 Feb 2014 Post subject: |
Thanks folks.
Been doing a little reading today and whilst I'm not usually completely paranoid about things I see on the net, this ABS system appears to be almost guaranteed to fail at some point.
Are they really that bad? ____________________ Things get better with age; I'm close to being magnificent........
| Robby |
 Robby Dirty Old Man
| Shaft |
 Posted: 21:21 - 07 Feb 2014 Post subject: |
I prefer to think of it as knowing what I like
Either that or it's because I'm fat and 48, if I was lithe and 21 again, I'm sure I would love the VFR.
And yes, still planning to do the Zed, just making sure I've got the plan and suppliers in place, so I don't get tripped up in the middle of it. ____________________ Things get better with age; I'm close to being magnificent........
| motobiker |
 motobiker Nitrous Nuisance
| Robby |
 Robby Dirty Old Man
| Shaft |
 Posted: 12:18 - 08 Feb 2014 Post subject: |
Looks to me like they've done that favourite trick of car and bike makers, added tech in the name of progress and introduced unreliability and high tariff degree of maintenance difficulty.
Quite fancy doing a clutch on one though, that looks like an interesting job. ____________________ Things get better with age; I'm close to being magnificent........
There is a gap of 351 days between these two posts... |
| MarkComer1 |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
 MarkComer1 L Plate Warrior
 Posted: 08:35 - 26 Jan 2015 Post subject: BMW r1200gs boxer |
The bike is an icon among the other in the BS family. With less price you can ride a great adventure-touring motorbike ____________________ Current Bike = BMW K1600gtle |
| Polarbear |
 Polarbear Super Spammer
 Posted: 09:03 - 26 Jan 2015 Post subject: |
^^^ Is that a form of English^^^  ____________________ Victory Cross Country American tractor. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:21 - 26 Jan 2015 Post subject: |
Thanks for clearing that up for us.  ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 11 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
