 prawny1 World Chat Champion
 Posted: 18:54 - 05 Feb 2014 Post subject: cheap skulltrail set up on ebay/ also lga771-775 conversion |
https://www.ebay.co.uk/itm/Intel-Skulltrail-D5400XS-Motherboard-with-2x-QX9775-Extreme-3-2-GHz-CPUs-/121269500063?pt=UK_Computing_LaptopMotherboards_CPUs_CA&hash=item1c3c39b89f
I came across that bundle whilst looking into available lga771 cpu's for a lga771-775 conversion.
It turns out that the lga771 (xeon) is almost identical to the lga775 (core2) with just two pins reversed and the notches on the edges of the cpu orientated differently, it is otherwise electrically compatible.
Using this stick on adaptor
https://www.ebay.co.uk/itm/Adapter-LGA771-Xeon-to-LGA775-MOD-Q9650-Q9550S-Q9450-Q9400-Q9300-Q8400-Q8300-/400641787055?pt=CPUs&hash=item5d481c84af
and removing the two plastic tabs on the socket itself, you can fit lga771 cpu's into almost any lga775 motherboard (x38+48 chipsets from asus evidently don't work), many later revision motherboard apparently have the correct microcode information in their bios and will identify the xeon chips just like any other new cpu you might fit.
Some boards however need that microcode adding to the bios manually using editing programs and reflashing the bios.
I am hoping the board I am using is the former as it has phoenix secure core bios and I have no way of editing them as of yet.
I have just bought a xeon e5450 slbbm, 3ghz 80w quad core 45nm e0 stepping cpu and an adaptor sticker to test,
the cpu was just £28 posted the nearest lga775 cpu is the q9650 95w chips but they fetch nearer £150.
If It works I can retire my trusty e8400, if it doesn't I might just buy a proper dual cpu board and a second e5450 for an 8 core set up and a stupid amount of ram. ____________________ hellkat wrote:
Some people are only alive cos its against the law to kill them. |
 Seb World Chat Champion
