Ram air Modification - YZF Thundercat specifically
Banger
PostPosted: 23:20 - 07 Feb 2014    Post subject: Ram air Modification - YZF Thundercat specifically Reply with quote
Has anyone, or does anyone know someone who has, successfully removed the diaphragms / feed funnel set up on a Ram Air fed bike ? Thundercat in this case, which I want to fighter, following a recent prang.
I have done lots of reading on various sites of the negative effects of straight removal of the Ram Air induction parts.
Many recommend an Air box mod that involves routing the central carb breather pipe back into the front of the airbox and claim this counteracts the lousy engine performance caused by removal of the Ram set up.
Wondering if anyone on here has any experience with this mod as opinions online of its effectiveness are conflicted . . or indeed whether there will be much effect on performance with air just flowing through the frame ports alone.
The other option is whether I could fit the funnels from something like a Speed Four to get around the issue.
Any and all input / thoughts / info will be appreciated. Thumbs Up
You only get one lap of lifes track . . . . so make it a fast one !
Yamaha . . Keyboards to biking nirvana.
el_oso
PostPosted: 01:15 - 08 Feb 2014    Post subject: Re: Ram air Modification - YZF Thundercat specifically Reply with quote
I have heard that ram air makes almost no difference at normal nsl speeds. It only becomes effective at very high speeds. No scientific explanation or reasoning behind. Take this post like you would a post in the daily mirror. It could be overhyped bullshit. Or there could be an element of truth.
Duke 390
Car: Jeep Wrangler 4.0L
Major Doss
PostPosted: 01:59 - 08 Feb 2014    Post subject: Reply with quote
lousy engine? hmm. Thumbs Down fookin' quick if I remember right, for a 600.
Antisocial phucker.
jjdugen
PostPosted: 02:24 - 08 Feb 2014    Post subject: Reply with quote
True 'ram air' on a carbed bike is extremely difficult to do. Its not just a case of forcing air into the airbox and balancing the overpressure with breather tubes into the airbox, that is just advertising bunkum. Done properly, the whole fuel system has to be a closed chamber and that includes the tank as well. Last time I looked, the T'cat has a normally aspirated tank. (As do the Kawasaki's et. al).
With fuel injection, however, you can make gains by force feeding the throttle bodies with pressurised air.
What I think you are referring too is is the removal of the airbox, usually replaced by 'pod' filters. The airbox is a vital and integral component of the engine as a whole and should be retained.
That's not to say that some airboxes don't have restrictors in them, usually for noise testing reasons. These can be discarded or altered.
Banger
PostPosted: 11:14 - 08 Feb 2014    Post subject: Reply with quote
I am not looking to remove the air box, more modify it to accept the supposed mod and remove all the ram air feed bits forward of the frame. . .
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 46.83 Kb
