| Codemonkey |
 Codemonkey Crazy Courier
| Codemonkey |
| totalllama82 |
 totalllama82 Crazy Courier
 Posted: 12:47 - 08 Feb 2014 Post subject: |
Raise the front of the bike up and try to spin the wheel. It should slow to a stop after a couple of rotations. I'd maybe take it up and down the road a few times first to get a little heat into them - mine tend to drag more when cold.
If it doesn't spin or you get a quarter turn out of them, you're going to be a busy boy  ____________________ Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F |
| brains_t |
 brains_t Nitrous Nuisance
| Codemonkey |
 Posted: 14:41 - 08 Feb 2014 Post subject: |
Thanks all. I'll drop the callipers off and spin the wheel to check the bearings, I'm pretty sure its the brakes though. Just popped out and got some red rubber grease and brake cleaner so I'm all set for a fun day in the garage  ____________________ Test Passed 10/05/2011 Current bike: XJ6-N |
| Codemonkey |
 Posted: 14:44 - 08 Feb 2014 Post subject: |
Spot on, thanks  ____________________ Test Passed 10/05/2011 Current bike: XJ6-N |
| Codemonkey |
 Posted: 17:50 - 08 Feb 2014 Post subject: |
Well, I got bored so decided to go and have a go at sorting it. I stripped everything down as per the video posted by brains_t and gave everything a good clean. The pistons were not that bad really, I think the problem was caused by a metal clip that the ends of the pads slide against.
There was a bit of a build up of salt & crap behind one of them resulting in the pad being a very tight fit. Once pushed towards the disk they simply didn't move back.
Cleaned everything and greased up the pistons with red rubber grease, then copper grease on the other bits, reassembled and now its much better
Cheers all! ____________________ Test Passed 10/05/2011 Current bike: XJ6-N |
The last post was made 12 years, 250 days ago. Instead of replying here, would creating a new thread be more useful? |
