Is silicone needed between the exhaust & silencer?
Bonneville63
PostPosted: 15:18 - 08 Feb 2014    Post subject: Is silicone needed between the exhaust & silencer? Reply with quote
I'm going to be changing the silencers on the Bonneville. It's a relatively easy job so I'll be doing it myself. The only question I have is should I be using some sort of silicon or lubricant to connect the silencer to the exhaust system? Or is it ok just to connect them bare?
If so, what should I be using?
Cheers.
https://www.youtube.com/user/TheBonneville63/videos
Bonneville63
PostPosted: 15:27 - 08 Feb 2014    Post subject: Reply with quote
Something like this for example:
https://www.amazon.co.uk/V-tech-Clear-Silicone-Gasket-Sealant/dp/B00442MGVQ/ref=sr_1_6?ie=UTF8&qid=1391869567&sr=8-6&keywords=silicone+RTV
Is 250c ok?
EDIT: after a bit more research I've come across Permatex. But it's damn expensive!
I guess in an ideal world I'd just use a bit from the bike shop.
andys675
PostPosted: 15:31 - 08 Feb 2014    Post subject: Reply with quote
you may find there was some sealant on from the factory, but they won't supply it
just some normal clear silicone will do, but they will pop and bang like you have an air leak anyway
Stalk
PostPosted: 17:43 - 09 Feb 2014    Post subject: Reply with quote
Exhaust jointing paste, silicone will burn off
Stalk
PostPosted: 17:46 - 09 Feb 2014    Post subject: Reply with quote
https://reviews.halfords.com/4028/741520/reviews.htm
PostPosted: 17:54 - 09 Feb 2014    Post subject: Reply with quote
Flue sealant from a plumber's merchant, if you have to use something.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:59 - 09 Feb 2014    Post subject: Reply with quote
My exhaust came with a recommendation to use silicon sealant, but I used gun gum.
Silicon sealent is flexible but (relatively) low temperature.
Gun gum is for high temperatures, but isn't particularly flexible.
Try one. If it's no good, try the other. Each one will cost about £2-3 for more than enough.
Note: If you aren't planning on using it for anything else, use the aerosol (hair-mousse) type of silicon sealent rather than the 'gun' style.
Triumph Sprint ST 1050
Bonneville63
PostPosted: 19:28 - 09 Feb 2014    Post subject: Reply with quote
Cheers Stalk. Looks like good stuff. Going to have a chat with the guy that makes the exhaust tomorrow and see what he says.
The last post was made 12 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 55.82 Kb
