zx4 vs zxr400 parts and maintenance
xorxorxor
PostPosted: 12:20 - 08 Feb 2014    Post subject: zx4 vs zxr400 parts and maintenance Reply with quote
Hey everyone!
Just picked up my first bike!
So, I thought I was getting the Kawasaki ZXR400 (got it from a mate), but I just figured out that it's a ZX400, from 1988. It's white/green/blue with single headlight, unlike the ZXR400 H model from 89 which has the two separate headlights.
Anyway, the bike has been sitting for some years untouched and refuses to start. I'm pretty sure its just gunky old fuel in the tank and carbs that's the problem. I put in some redx to see if that helps, no luck yet. I might get this "SeaFoam" stuff from eBay that everyone in USA seems to rave about.
To my question. Does anyone know if I can interchange the parts for my ZX4 with ZXR400 parts? A lot of listings seem to refer to them as the same bike, which is weird. Here's the list of things I'm planning to do to the bike in the next week...some of which need new parts.
Replace the battery (DONE)
Drain fuel tank
Wash/flush inside of fuel tank? (How?)
Replace fuel filter
Flush/add engine coolant (currently completely empty!)
Replace oil (thinking half synth 10w-40)
Replace oil filter
Replace air filter
Replace spark plugs
Find new petcock knob - currently missing so I can't change setting
-Maybe if it still won't start- Get SeaFoam and pour it directly into the carbs. No idea how to do this.
I'd appreciate any input/pointers!
I plan to drain the tank and flush/clean the coolant reservoir today, will need to order and wait for new parts to arrive from eBay for the other jobs.
331X2
PostPosted: 14:37 - 08 Feb 2014    Post subject: Reply with quote
I'd avoid the seafoam to be honest, just strip the carbs and get some carb cleaner through all the jets and galleries and make sure they're all clear. If its been sat, chances are everything will be gobbed up with varnished petrol so best to get it cleaned out completely.
Drain tank and fill with fresh juice, tank it to dilute any remnants of the old fuel, fill the float bowls of the carbs, fill the coolant up and see if it'll run. If it coughs into life then give it a service and run it up to temperature to check for leaks and fan working, much easier to get a bike back on the road when you know it runs Smile
CaNsA
PostPosted: 17:17 - 08 Feb 2014    Post subject: Re: zx4 vs zxr400 parts and maintenance Reply with quote
Pics?
xorxorxor
PostPosted: 20:21 - 08 Feb 2014    Post subject: Re: zx4 vs zxr400 parts and maintenance Reply with quote
CaNsA wrote:
Pics?
https://i.imgur.com/U3zZTx0.jpg
Very Happy
xorxorxor
PostPosted: 20:30 - 08 Feb 2014    Post subject: Reply with quote
Just finished draining the petrol. I've actually taken off the whole tank now, it is SO full of crap/rust so decided it was worth the effort. Going to clean it all out tonight so that it's spotless inside. Might even take this chance to fix up some scratches on its paintwork too.
I actually tried to start it one more time before draining it and it shot out a massive back fire. Had ringing ears for a few minutes because of the tight enclosed garage the bike is in Very Happy
I'll try to get to a shop tomorrow to get coolant, fresh oil, carb cleaner etc. I was really hoping to avoid having to take apart the carbs since I don't know what I'm doing, but I guess its worth the effort. It'll be good knowing they are properly clean and I'll get to learn the process. Just hope I don't mess anything up.
It also seems to be leaking something...not sure what yet, but the floor under the bike is a bit off a mess now. I'll deal with that after I've serviced everything and actually got it running.
About to order a K&N oil filter and a fuel filter, they are listed as zxr400 parts but I think (hope) they will fit. Any tips on what to do with the old oil and coolant? I assume there is a proper procedure rather than throwing it in a bin!
CaNsA
PostPosted: 20:48 - 08 Feb 2014    Post subject: Reply with quote
There are few dudes with a zx400 on the zxr400 forum.
https://www.zxrworld.co.uk/zxr400oc/search.php?keywords=zx400
Join up, say hi, post in the relevant sections. Thumbs Up
The last post was made 12 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 50.48 Kb
