Bit of a project.
gavbriggs
PostPosted: 19:19 - 08 Feb 2014    Post subject: Bit of a project. Reply with quote
I've been thinking about this all week.
On modern ish bikes the headlights come on with the key. That's all well and good but then you need extra power to start the thing.
Could a relay be fitted so the head lights only came on when the engine was running?
I want this specifically for my 1200s k4 bandit. Is there a signal wire on the alternator and where could I put this relay?
Islander
PostPosted: 19:37 - 08 Feb 2014    Post subject: Reply with quote
If you have an electronic tach, you could tap into the pulse feed , buffer it off and integrate (smooth) it to provide a control voltage.
Or just turn the lights off. Razz
gavbriggs
PostPosted: 20:05 - 08 Feb 2014    Post subject: Reply with quote
But the lights come on with the key! So all that buffering and smoothing etc won't help.
Just want to know where the signal is from the alternator so I can tap in and then cut into the headlight circuit. Install a relay and bobs ya dad's brother! Not hard just don't know where to go cut!
lihp
PostPosted: 20:17 - 08 Feb 2014    Post subject: Reply with quote
It is hard when you have no clue what you're doing.
If you can't start the bike with headlight on, then you have a battery/charging/starting issue
Islander
PostPosted: 21:54 - 08 Feb 2014    Post subject: Reply with quote
Erm, buffering the tach signal and integrating it will produce a control voltage when the engine is running, so yes, if you really want to faff about with this, it will help.
You could use the output of the alternator as well - the output from the reg/rec would do. You'd need to separate it from the battery output but a simple diode would do that.
I gave the first answer as a tongue in cheek solution because the bike is designed to work the way it is. Keep it in maintenance and it won't give you any problems. You're overthinking it so I provided an overthought solution.
Loses its effect when it has to be explained. Rolling Eyes Laughing
Islander
PostPosted: 21:55 - 08 Feb 2014    Post subject: Reply with quote
Oh and this. ^^^^^^
mikesaa309
PostPosted: 22:02 - 08 Feb 2014    Post subject: Reply with quote
I'm no expert but could you not just wire it into a wire that has power when the engine starts up? I doubt you could wire it directly to the alternator unless maybe connecting it to the wires leading out of the engine casing.
My bikes the opposite, my lights come on once the engine is started. I've thought about rewiring it to come on with the ignition. However I can't think of anything else that would only produce power once the engine is started.
So from the top of my head, I don't think it can be done. I think I'm right in saying that my head lights are directly wired into the alternator which won't be easy to do.
That said I wouldn't think that it would loose much power if any if the lights are on. It's designed to work that way so doubt it'll be much of an issue.
gavbriggs
PostPosted: 22:37 - 08 Feb 2014    Post subject: Reply with quote
The bike starts fine, well it does now I've sorted the carbs/dodgy fuel/electrical connector issues I've had.
But while I was sorting those issues I had to use my jump battery (120ah heavy duty 4x4 type) that I keep topped up just in case I should need it to assist the bike. Obviously the bike battery isn't powerful enough for multiple starts.
That's what got me thinking that if an issue did arise it would be helpful not to have the headlamp drawing power, which could be the difference between riding home or pushing home.
I did however unplug the headlight bulb so I would just do that I suppose if the need arose! Rolling Eyes
mikesaa309
PostPosted: 22:42 - 08 Feb 2014    Post subject: Reply with quote
You could wire in a switch relatively easily. That way it will stop the power from getting to the light bulb (obviously) the same as just removing the head light bulb. The only issue is making the switch easily accessible. Maybe you could get one of those push button toggle switches and drill a hole through the instrument panel for easy push on/push off action. Will also be easy to operate with bike gloves on.
I agree the headlights on whilst trying to start it will drain power quite a bit. When my mate first got his VT shadow 125 his battery was fucked and couldn't start the bike at all if the lights were on.
WD Forte
PostPosted: 22:43 - 08 Feb 2014    Post subject: Reply with quote
there are various ways of doing it.
Dont know the bandit but many bikes have a disable function to
cut power to the lights when cranking.
Others will only turn on running lights at first and use a tap into one of the alternator output cables to power a relay which will turn on the lights after the engine has started.
This tap has to be rectified of course.
the lights will turn off when the engine stops.
A manual switch is another and probably the simplest option
bikers smell of wee
gavbriggs
PostPosted: 23:13 - 08 Feb 2014    Post subject: Reply with quote
The bandit has the two rear lights = 2x5w, the front sidelight = 5w plus the front headlight = 50w
Just wondered if nocking the 50w out would save a bit of wear on the battery.
It'd definitely be a relay to the main beam. As I would forget a switch and I think the auto front lights on system is a massive safety improvement over the optional lights of old!
misscrabstick
PostPosted: 00:15 - 09 Feb 2014    Post subject: Reply with quote
My MT09 has no lights on/off switch, however when i turn the ignition on only the sidelamps come on and the headlamp comes on when the engine is started. Some sort of battery voltage sensitive relay control i guess.
The last post was made 12 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 73.72 Kb
