Anyone Keep chickens/built a chicken coop?
PostPosted: 13:08 - 10 Feb 2014    Post subject: Anyone Keep chickens/built a chicken coop? Reply with quote
My girlfriend wants to keep chickens, I said I reckon I could build a chicken coop, now I have to build a chicken coop. Laughing
Just wondering if anyone has any pointers?
My basic plan in my head was a to build a frame with four 'legs' then a a square about a 3rd of the way up to support the floor and a square at the top to support the roof. I also figured on a slanted roof.
A few questions.
Where is good for cheap wood? I image B&Q etc will rip you off.
Is there a guide for sizes? I think shes wants 3-4 chickens.
How big should the opening for them to get in and out be?
Would the wood rot to shit with them crapping/scratching etc. should I get a certain type of wood or is there a varnish/pain/seal I can use?
For the nests is there anything special needed? I was thinking about just splitting the back wall into 4 with a shelf across the middle and one from top to bottom then each and be filed with hay.
How big should each nest be?
For the entrance/exit to the run would it be better to have this in the side of the coop or the bottom?
What sort of size should it be? I want it to be fairly tight to keep out predators if they get in the run, but large enough for the birds can get in.
For the run will standard chicken wire keep out foxes? is there anything I can do to help protect them?
hedgehugger
PostPosted: 13:33 - 10 Feb 2014    Post subject: Reply with quote
They poo a lot so it needs to be easy and accessible to clean.
When they are in the coop, most will perch and the guidelines are a foot per bird.
I have 3 and they all share a nest box, sometimes at the same time. If I had known they would want to lay at the same time, I would have had 2 nest boxes Smile
As big a run as you can make. If you have a garden and they free range, your grass will take a permanent holiday, but the chickens will be happy Smile
Foxes love chickens, chicken wire is to keep chickens in, not foxes out.
We used welded mesh for our run.
https://www.hillsofdevon.co.uk/aviary-mesh.html
was the cheapest we could find.
inch by half inch sizing was what we bought.
I know you want to make one, but I read horror stories about wooden coops and something called red-mite Shocked
So I opted for a plastic bought jobby.
https://www.solwayrecycling.co.uk/recycled-shop/pig-poultry/hen-houses/eco-hen-loft
hedgehugger
PostPosted: 13:42 - 10 Feb 2014    Post subject: Reply with quote
We had an old chain link metal fence, which we put in the ground under where we built the run. The idea behind that was it would keep a fox out. No doubt it would, but it didn't keep rats out. The little bastards kept digging in and helping themselves to the chicken food.
We ended up digging the earth base up and laying welded mesh on the ground as well to keep the little gits out.
Sabs
PostPosted: 14:17 - 10 Feb 2014    Post subject: Reply with quote
We have two bantoms and I'd second what hedge has said but will echo the ruining the garden part, they will ruin the grass and every plant/flower you have, and shit everywhere. They do look nice wandering round though.
You can get spray to get rid of the red-mite and other bugs. Just a quick squirt when you clean them out.
If you want to make your own, take a look on ebay for ideas, there's plenty on sale there and I think they give measurements. As for wood, either a local wood place or Homebase, B&Q etc etc.
mogstar
PostPosted: 14:19 - 10 Feb 2014    Post subject: Reply with quote
As said try and engineer something easy to clean out - they make a mess and red mite hide in crevices and are difficult to get rid of.
Swat up on parasites/treatments. Red mite, scaley leg mite, avian lice etc. You will need to be able to recognise symptoms etc. bad infestations can stop them laying and even kill them. You will also need to worm them periodically. Some treatments taint the eggs so bear this in mind.
I think it's better to keep the coop off the ground. Helps reduce damp and stops rodents nesting under the coop (they are attracted to the ready supply of feed).
Don't keep too many as they are nasty bullies if closely confined. They will attack the weakest and draw blood or worse.
You can get ex battery hens for next to nothing.. https://www.bhwt.org.uk/cms/re-home-some-hens/
We get hay as bedding, a local farmer charges us about £4 a bale. We get layers pellets and corn (which we mix) from an agricultural supplier.
Loads of info online including coop building. You can also look at commercial coops and build a DIY version. We started with a wooden home made coop but now have an Omlet Cube because it is easy to hose out and dry.
PostPosted: 14:21 - 10 Feb 2014    Post subject: Reply with quote
We are going to build it one I think mainly to keep costs down but also to make it fit the certain area. I had a quick read about red mite and it seems like it can be avoided with proper cleaning and keeping an eye on them.
Welded mesh seems like a good idea, my missus was an archaeologist so is used to digging. Laughing
What do you reckon dig down 4" lay some mesh and put the sides on then cover it?
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
panrider_uk
PostPosted: 16:11 - 10 Feb 2014    Post subject: Reply with quote
I used a cheap shed from one of the diy stores.
Cut a hatch in the side to give them a ramp in and out.
Divided the interior into 2 - half for the chickens and half for all the feed, grit, mucking out tools etc.
Plenty of nesting boxes.
They seemed to like it Smile
yambabe
PostPosted: 17:36 - 10 Feb 2014    Post subject: Reply with quote
We bought a flat-pack one off ebay and then built it ourselves.
At first we just had the coop, but it wasn't really big enough and as has been previously mentioned giving them the run of the whole garden was ano-no cos they do make a mess.
We compromised by using a piece of old goal net alongside the fence which is held to the ground by big metal u-shaped staples. It's been fox-proof so far but we do see rats occasionally. Having 4 cats means that we mostly see dead rats these days......
https://i12.photobucket.com/albums/a229/Yambabe/Facebook/Mobile%20Uploads/425946_10150576179680940_1071428383_n.jpg
That's our run. You can just see the corner of the coop to the left of the picture.
https://i12.photobucket.com/albums/a229/Yambabe/Facebook/Mobile%20Uploads/535173_10150630652030940_1542614085_n.jpg
We do sometimes still let them out for a peck around the rest of the garden!
https://i12.photobucket.com/albums/a229/Yambabe/Facebook/Mobile%20Uploads/552541_10150905055350940_1762484854_n.jpg
You can see the coop in the background on this pic. It's not massive, we have 3 birds in there but could probably fit another couple due to the size of the run.
birdyboyuk
PostPosted: 19:20 - 10 Feb 2014    Post subject: Reply with quote
I used to have chickens and used a lean to shed and the side of another. We had 8 in total.
The only treatment I gave the wood was the cuprinol weather stuff, whatever that stuff does... Rolling Eyes
To reduce the issues with foxes, place paving slabs around the edge...will stop them digging down.
We kept ex-battery hens, to give some new lease of life! Worked out about £2.50 each.
Pics below to give you some idea!
https://i37.photobucket.com/albums/e90/birdyboyuk/Chicken%20House/18022008370.jpg
Perch at the top was an old curtain rail.
https://i37.photobucket.com/albums/e90/birdyboyuk/Chicken%20House/08032008407.jpg
https://i37.photobucket.com/albums/e90/birdyboyuk/Chicken%20House/08032008409.jpg
https://i37.photobucket.com/albums/e90/birdyboyuk/Chicken%20House/08032008405.jpg
Shit catchers
https://i37.photobucket.com/albums/e90/birdyboyuk/Chicken%20House/14032008411.jpg
Plastic sheet for rain cover!
https://i37.photobucket.com/albums/e90/birdyboyuk/Chicken%20House/15032008412.jpg
Ding! Dong! Avon calling...
https://i37.photobucket.com/albums/e90/birdyboyuk/Chicken%20House/15032008419.jpg
This site is worth looking into as well - https://www.downthelane.net/Page_7.php
I do have more pics, but not really much different to the above.
If you wanted a modern looking coop, you could always go to gardening places that sell these, grab some measurements and build it yourself!
Best of luck with it! Chickens are great to keep and fun!
PostPosted: 11:19 - 11 Feb 2014    Post subject: Reply with quote
Thanks everyone, I have a loose plan in my head now I'll draw it up then where the weather gets better take a couple of days off and build it. She said she wanted ex battery hens too. Thumbs Up
PostPosted: 14:47 - 11 Feb 2014    Post subject: Reply with quote
Make sure she knows however good the rest of their life, ex battery hens are never going to lay many eggs. We used to have 2 ex battery and 2 young layers. That used to give a reasonable egg supply for 2 people.
The last post was made 12 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 80.68 Kb
