finding cable for a specific circuit
stranger12
PostPosted: 19:09 - 09 Feb 2014    Post subject: finding cable for a specific circuit Reply with quote
Hi Guys,
I am not very good at electrics etc but I need to figure out a why to know the function of each cable.
For instance I want to know which of the 10/15 wires going all the way to the rear is for the brake light, I am happy to make a small cut and use multimeter , is it possible then to press the brake so the light then comes up and presumable the multimeter value changes to tell me that is the cable that I need ?
if so how do I connect the multimeter, negative to ? positive (red) to ?
should it be on V setting ?
Does the same apply to car?
Many thanks
SV650 Red
R6 Red
anthony_r6
PostPosted: 19:15 - 09 Feb 2014    Post subject: Reply with quote
I would start by finding the wiring diagram to your bike first. It'll be colour-coordinated so you can see exactly which wire is what, and what colour it is.
Edit : to answer your question. I'd have it set to 20v and you press the red on the lead you want to check and earth the black on some bare metal.
I think rear brake lights are permanent lives. So if there is power, you should pick something up without having to press the brake light.
stranger12
PostPosted: 19:30 - 09 Feb 2014    Post subject: Reply with quote
thank you , can I connect the black to body of the car/bike or negative terminal ? sorry if this sound stupid.
I know with some cars they have different pulsation to distinguish between indicator or brake light etc so you may end up only having one wire which is carrying the signal for 2/3 different things, is that right ? can you check this using the above method ?
SV650 Red
R6 Red
anthony_r6
PostPosted: 19:57 - 09 Feb 2014    Post subject: Reply with quote
You can earth it off on bare metal, or the negative terminal.
As for the single wire/multi function thing, I've heard of it, but I'm not up on it. Again, I'd start with the manual and a wiring diagram. I imagine (though don't quote me) that if a wire can carry multiple signals then you should see an increase in voltage or a pattern (such as spikes when the indicators light up, then drop as they go off)
uberkron
PostPosted: 08:20 - 10 Feb 2014    Post subject: Reply with quote
Use a testlight. You wont ruin anything. Earth it on the body. Lets you see power. Meters will show stray current and miliamp leakage.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
WD Forte
PostPosted: 16:10 - 10 Feb 2014    Post subject: Reply with quote
Sounds like you're talking about CANbus where multiple devices pass data to each other in modern vehicles
If so the answer is no.
You'd need more than a multimeter to examine these signals
It sounds like you need to start at the beginning and get a manual with
wiring diagram for the vehicle first, plus a multimeter which is always handy, if not vital, anyway.
The manual should tell you
A if it uses Canbus and
B how much of it is Canbus controlled
Then you'll know how much you can reasonably expect to debug using a meter.
bikers smell of wee
iooi
PostPosted: 18:50 - 10 Feb 2014    Post subject: Re: finding cable for a specific circuit Reply with quote
stranger12 wrote:
Hi Guys,
Many thanks
Well on a bike. Simply go to rear light and look at the cables connecting to it. Then follow them back through the loom.
Making small Shocked cuts into a std bike cable is asking for problems later on.
stranger12
PostPosted: 13:50 - 13 Feb 2014    Post subject: Reply with quote
thanks all.
did sort out the issue using multimeter
SV650 Red
R6 Red
The last post was made 12 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 56.85 Kb
