PSU question, why so much revs?
RhynoCZ
PostPosted: 10:54 - 10 Feb 2014    Post subject: PSU question, why so much revs? Reply with quote
Hello, I recently got a gelid tranquillo CPU cooler to OC it a bit and I've noticed that PSU gets much warmer and louder than it used to be. Is something going wrong? Intake and exhaust fans run quiet, CPU fan is also quite. The PSU is even louder than my old ATA HDD. Confused
I've set everything back to the factory settings and it's still the same. Is there anything I could do about the heat and noise of the PSU? It's 600w and I don't even use like 60% of it so it shouldn't get that warm. Confused
CaNsA
PostPosted: 11:07 - 10 Feb 2014    Post subject: Reply with quote
Cleaned it out?
James83
PostPosted: 11:21 - 10 Feb 2014    Post subject: Reply with quote
If cleaning it out doesn't help, check if the PSU fan is dying, would explain it being both louder and hotter. Just remember to discharge the thing properly if you are going to open it up and replace the fan.
RhynoCZ
PostPosted: 12:15 - 10 Feb 2014    Post subject: Reply with quote
I'll try to clean it. Thumbs Up
Scotsman37
PostPosted: 18:08 - 10 Feb 2014    Post subject: Reply with quote
Just like the last person stated it could be getting louder due to the bearings within the fan are starting to wear out making it more noisy, and therefore then fan's motor is working much harder to turn fan without much success to reach it's optimum speed to keep it cool properly!
RhynoCZ
PostPosted: 22:03 - 10 Feb 2014    Post subject: Reply with quote
Well, I ''only'' cleaned the PSU, since I don't have a new fan to put in. The noise is less noticeable and the temp dropped a bit. It still produces quite a lot of heat and noise though. Thumbs Down
The fan might be at the end of it's life. 6 years of hard work and it's about to be gone. Crying or Very sad
Q: Would any 120x120m fan be alright?
By the way, the whole PC acts like it's about to die. GPU/CCC does not cooperate even in fresh instal of the OS, one HDD makes quite unpleasant grinding noise every now and then and so on. 6 years seems to be quite enough for a personal computer.
PostPosted: 22:24 - 10 Feb 2014    Post subject: Reply with quote
Join the super computer revolution. Thumbs Up
I assume that if you remove the overclock then the PSU still makes the same bad noises?
RhynoCZ
PostPosted: 09:44 - 11 Feb 2014    Post subject: Reply with quote
Oddly enough, the OC'ing does not effect the system at all. Temps are the same for the whole case, CPU 42°, System 37° on idle when at 2.4GHz and the same when at 3.0GHz. Ram gets OC'd from 800MHz to 940MHz automatically with the CPU ''thanks'' to the EPU chip on the MB.
CaNsA
PostPosted: 10:09 - 11 Feb 2014    Post subject: Reply with quote
Just because you have overclocked the cpu it doesnt mean it is running at the speed..... find out if your CPU has stepping.
RhynoCZ
PostPosted: 13:12 - 11 Feb 2014    Post subject: Reply with quote
I turned the ''Enhanced Halt State'' (C1E) off, which should mean it won't drop the frequency. Thumbs Up
RhynoCZ
PostPosted: 23:37 - 02 Mar 2014    Post subject: Reply with quote
So the same thing again, the PSU is still clean like brand new, but the fan runs way faster than usual. I was thinking, could it be the result of the quite big CPU cooler I put in there, in terms of proper air flow? Confused
PostPosted: 00:39 - 03 Mar 2014    Post subject: Reply with quote
Larger cooler is heavier. Might be un-seating off the CPU slightly causing poor thermal transfer.
Shinigami
PostPosted: 09:34 - 03 Mar 2014    Post subject: Reply with quote
that would show in the form of cpu temp though surely? whereas OP says his cpu temp is fine
Jayy
Mr. Ponzi
PostPosted: 22:12 - 03 Mar 2014    Post subject: Reply with quote
Alarm bells are ringing. Your PSU sounds like it's fux0red and on its way out.
I'm running a pretty high end rig with a 1000w Coolermaster Silent Pro and it is just that, quiet and cool as fuck. If it was making loads of noise and getting hot, I would be looking to Coolermaster to replace it under their 5 year warranty.
Most of the decent PSU's come with a gold/silver rating now that usually includes a 5 year warranty, which would suggest that they're quality made to come with such a long warranty.
Another reason why I bought Intel SSD's, they came with 5 year warranties over the standard 2/3.
Long warranties say to me, manufacturers are willing to put their money where their mouth is and stand behind their products.
RhynoCZ
PostPosted: 18:54 - 06 Mar 2014    Post subject: Reply with quote
Can't say I'd fall for that. The money intel asks for their SSD's is mental. Doh!
lihp
PostPosted: 20:33 - 06 Mar 2014    Post subject: Reply with quote
Or they have a good legal team with nice escape routes.
The last post was made 12 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 90 Kb
