| frostage |
 frostage Borekit Bruiser
 Posted: 12:12 - 11 Feb 2014 Post subject: Datatool Veto Evo Problem (GSXR 750) |
Well today I went to start my gixxer after a few months of being sat there in the garage.
I'd had the trickle charger on since last night to liven up the battery, and it seems ok.
As soon as I plug the battery in, the datatool alarm goes off (an absolutely maddening racket), but the problem is that the disarm button (the O button) does not disarm the alarm. The issue is complicated, so here goes my best explanation.
Basically when the O button is pressed, rather than going "beep" to signify the alarm disarming, all I hear is a nasty sounding screech. Sometimes the alarm will stop sounding, others it just carries on, but if it does stop it just starts back up again after 1-20 seconds (vague right?).
If the alarm doesn't start back up straight away and I try starting the bike, I just get a sound which seems to be the injectors squirting (pumpish sound, I could be wrong) but no relay click or seemingly any attempt to actually start.
If the alarm doesn't start back up straight away and I press the O button again, I get the screech followed immediately by the alarm going off again.
I have tried:
New battery in fob
New battery in bike
Jumping bike from car battery
Bump starting the bike
disconnecting the internal battery in the alarm/reconnecting
I am pulling my hair out over this, and the sound of the alarm is the sort of sound that makes you seethingly angry with it in a matter of seconds, so you can imagine my mood after 3 hours of fiddling.
Any help would be GREATLY appreciated. My only local dealer is a daylight robbery specialist. ____________________ 2000 Gixxer 750
1995 RM 250 |
| TwoWheelsDail... |
 TwoWheelsDail... Scooby Slapper
 Posted: 12:22 - 11 Feb 2014 Post subject: |
Not sure if this will help but when i had my car it had an aftermarked alarm/imobiliser.
Basically it broke, no idea why. It was doing the same thing as your bike. I took the fuse for the alarm out and it worked. Just couldnt use the alarm.
This could be a temp fix? ____________________ Suzuki GSR 750 - 33BHP (Restriction Ends 17/12/2014)
KTM Duke 125 - SOLD
www.facebook.com/TwoWheelsDaily | www.twitter.com/TwoWheelsDaily | www.instagram.com/TwoWheelsDaily |
| slow |
 slow L Plate Warrior
| mattd |
 mattd Scooby Slapper
| CBRHerms |
 CBRHerms L Plate Warrior
| andys675 |
 andys675 World Chat Champion
 Posted: 21:24 - 11 Feb 2014 Post subject: |
have you tried resetting it?
remove bike battery and alarm internal battery, or let the alarm run flat if you can't remove the internal battery, once flat it will start again fresh
or de-spike it, follow instructions here https://old.datatool.co.uk/pdfs/veto_evo_ds.pdf ____________________ Some people feel the rain, others just get wet. |
The last post was made 12 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
