So who knows about C++ ?
 Topic moved: from Dear Auntie BCF... to The Geek Zone by G (12 Feb 2014 - 16:10)
Lord Percy
PostPosted: 22:35 - 11 Feb 2014    Post subject: So who knows about C++ ? Reply with quote
I'm pretty sure a fair few people on here know a hell of a lot about this kind of thing, so here is a homework question I simply can't do. The original problem is below.
There are 5 things wrong in this code:
#include <string>
int main() {
std::string * strPtr = new string('hello");
std::cout << &strPtr << std::endl;
delete[] strPtr;
std::cout << *strPtr << std::endl;
Find the five wrong things and correct them.
I actually got it working, and now I've changed something and it isn't working any more. So I'm starting over and putting it out to BCF.
I have a reasonable grasp on most aspects that I've learned so far, but something here has thrown me and now I feel like I don't know anything at all.
If anyone is feeling kind/nerdy enough to fix this and explain each fix, that'd be great.
Well I'm fairly sure I know a couple of errors already:
- Needs #include<iostream>
- 'hello" has the wrong quotation mark at the start.
- delete[] is wrong because there is no array in there.
I think the thing that's really messing things up is my grasp of pointers and references. Am I even remotely on the right track?
Thanks all Thumbs Up
SQL
PostPosted: 22:52 - 11 Feb 2014    Post subject: Reply with quote
Repost it in Geek Zone you will get better replies.
Lord Percy
PostPosted: 23:09 - 11 Feb 2014    Post subject: Reply with quote
I thought I'd get better coverage in this section Embarassed
Anyway it looks like I've done it, and I think I actually had already done it all along.
The real problem was some shitty underlying computer issue. While messing around with the code, I'd told it to draw info from an unused bit of memory which caused it to basically have a stroke and not tell me about it. No matter what I did after that, even the most basic bit of coding would crash. After restarting the computer, everything works again, woohoo!
Very Happy
PostPosted: 13:12 - 12 Feb 2014    Post subject: Reply with quote
5 6 fixes.
Code:
#include <string>
#include <iostream> // #1 Need iostream for cout
int main()
    std::string * strPtr = new std::string("hello"); // #2 Mismatched '", #3 needs another std::
    std::cout << *strPtr << std::endl; // #4 We want the object that strPtr points to, not the address of it
    delete strPtr;  // #5 Not an array, don't use array delete[]
    //std::cout << *strPtr << std::endl; // #6 Don't use the object again after deleting it
Stowelly
PostPosted: 16:18 - 12 Feb 2014    Post subject: Reply with quote
Rogerborg wrote:
5 6 7 fixes.
Code:
#include <string>
int main()
    return 0;  //#7 int return type is expected 0 is success
Lord Percy
PostPosted: 18:23 - 12 Feb 2014    Post subject: Reply with quote
Rogerborg wrote:
5 6 fixes.
Code:
#include <string>
int main()
Great stuff, I got all those Thumbs Up. And yeah I saw 6 too.
Well, I kind of saw 6. Point #3 was a thing I didn't quite understand, I fixed it in a roundabout kind of way by adding 'using namespace std' and just deleting all the std bits, but I hadn't spotted the actual root of the error.
All makes sense now Karma
barrkel
PostPosted: 20:07 - 12 Feb 2014    Post subject: Reply with quote
Stowelly wrote:
Code:
Technically, main returns 0 if there is no explicit return.
ISO/IEC 14882:2003 § 3.6.1 paragraph 5:
A return statement in main has the effect of leaving the main function (destroying any objects with automatic storage duration) and calling exit with the return value as the argument. If control reaches the end of main without encountering a return statement, the effect is that of executing
Code:
return 0;
Stowelly
PostPosted: 20:20 - 12 Feb 2014    Post subject: Reply with quote
barrkel wrote:
Stowelly wrote:
Code:
Code:
return 0;
ha, makes sense, I guess its quite rare to have an entry point where there is zero chance of failure at any point though, have just become accustomed to having it return success. been programming c++ for 12 years, and still learn new things about the language every day!.
gfrancisdev
PostPosted: 20:57 - 12 Feb 2014    Post subject: Reply with quote
Well if you're being pedantic
Code:
int main(int argc, char** argv);
ybr125(07 silver)-killed 2013/4/3 on some ice
ybr125(06 blue), KE100(89 green-black-puke)
Stowelly
PostPosted: 21:11 - 12 Feb 2014    Post subject: Reply with quote
Code:
as were quoting the standard now
An implementation shall not predefine the main function. This function shall not be overloaded. It shall have a return type of type int, but otherwise its type is implementation-defined. All implementations shall allow both the following definitions of main: int main() and int main(int argc, char* argv[])
Clanger
Stirrer
PostPosted: 21:15 - 12 Feb 2014    Post subject: Re: So who knows about C++ ? Reply with quote
In the world of bus passes, the C+ sign is for a disabled person to take a travel companion on the bus free of charge. As for anything else, I'm afraid I cannot help. I am only a geek in that I buy and read graphic novels / comics. Cool
PostPosted: 21:20 - 12 Feb 2014    Post subject: Reply with quote
https://bookriot.com/wp-content/uploads/2013/03/3879_-_animated_gif_chuck_norris_dodgeball_thumbs_up.gif
C++ is so last millennium, all the hep cats are using D now.
Not actually joking, I rather like it.
el_oso
PostPosted: 12:33 - 15 Feb 2014    Post subject: Reply with quote
What kind of usage is C/C++/D seeing in industry nowadays. JIT compliers (C# mainly because everyone still uses windows) seem to be used most heavily. They no longer seem to be slow languages and often outperform languages like C++. I do still see some C++ in with C# applications, however it's usually small bits that are very maths intense.
Duke 390
Car: Jeep Wrangler 4.0L
J.M.
PostPosted: 16:08 - 15 Feb 2014    Post subject: Reply with quote
The last company that I interviewed for told me that they were now straying away from C++, in favour of other languages like Java. They still use it, just not as much.
2004 R1 & 2018 XSR900
Stowelly
PostPosted: 18:45 - 15 Feb 2014    Post subject: Reply with quote
L
I'm in the games industry, and can't see it changing for the triple A games any time soon. It's still king for performance and memory critical code. Plus a lot of studios have 20 year code bases that are refined and basically impossible to rewrite in anything else
Dalemac
PostPosted: 21:00 - 15 Feb 2014    Post subject: Reply with quote
I haven't actually ever used c++. Maybe I should give it a go one day.
The majority of the work I do is for the web so i'm usually using either C# or PHP.
YBR125 -> GPZ500S -> SL1000
barrkel
PostPosted: 02:27 - 16 Feb 2014    Post subject: Reply with quote
I first learned C++ in about 96, then started reading Herb Sutter's GotW, and realized that C++ was like a fractal; the more you studied it, the more flaws came out of the woodwork, and the more you had to know to write bulletproof code. The hilarious interactions that lead to e.g. std::stack<T>::pop() not being able to return the item popped, function try blocks (hahahaha!), Turing-complete templates (infinite wankery for the dedicated nerd), right up to C++11 switchable lambdas (capture by reference or value? either, you choose!). The sheer amount of knowledge you need to write exception-safe code - even with RAII to hand - is ridiculous.
Stroustrup never met a language feature he didn't covet. That leaves it up to individual people, teams, companies to choose the acceptable bits. And there are a bunch of subsets that interact sanely. Trouble is, everybody has different subsets, and library interaction suffers because the libraries aren't always lowest common denominator (at which point, they might as well be C). C++ has never had the kind of rich third-party library ecosystem its popularity would seem to merit.
You're right that it still has its niche. But Go and Rust are starting to creep into mindshare at the elite level. Personally, I hope C++ dies in a fire.
Stowelly
PostPosted: 09:46 - 16 Feb 2014    Post subject: Reply with quote
those GOTW articles are quite interesting, is a hell of a lot of gotchas with the language! wouldnt quite agree with hoping it dies in a fire. it definitely has its uses (if only to keep people employed!!). but at the same time ive been doing a lot of erlang programming the last couple of years and finding it does a lot of things just so much better. but i guess its a completely different paradigm solving different problems
barrkel
PostPosted: 15:40 - 16 Feb 2014    Post subject: Reply with quote
It has its uses because there are no hardened, popular alternatives with wide platform support. When there are - and there will be within the next 10 years, now that LLVM has democratized access to an optimizing back end - it should take only another 10 or 20 years for C++ to die.
So I'd put a bet on C++ being in the minority for its current niche in 30 years time. I wish it could happen sooner, but it's unlikely.
The last post was made 12 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.27 - MySQL Queries: 18 - Page Size: 113.32 Kb
